PMSTA05,115
PMSTA05,115
    NEXPERIA(安世)
    SOT-323
    500毫安NPN通用晶体管
PMSTA05,115 数据手册
PMSTA05; PMSTA06 500 mA NPN general-purpose transistors Rev. 3 — 22 July 2010 Product data sheet 1. Product profile 1.1 General description NPN general-purpose transistors in a SOT323 (SC-70) very small Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number PMSTA05 Package PNP complement Nexperia JEITA SOT323 SC-70 PMSTA55 PMSTA06 PMSTA56 1.2 Features and benefits „ High current (max. 500 mA) „ Collector-emitter voltage: ‹ 60 V (PMSTA05) ‹ 80 V (PMSTA06) „ AEC-Q101 qualified „ Very small SMD plastic package 1.3 Applications „ Primarily intended for telephony and professional communication equipment 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter VCEO Min Typ Max Unit PMSTA05 - - 60 V PMSTA06 - - 80 V - - 500 mA 50 - - 50 - - collector-emitter voltage IC collector current hFE DC current gain Conditions open base VCE = 2 V; IC = 10 mA VCE = 1 V; IC = 100 mA [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 2. Pinning information Table 3. Pinning Pin Description 1 base 2 emitter 3 collector Simplified outline Graphic symbol 3 3 1 1 2 2 sym021 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PMSTA05 SC-70 plastic surface-mounted package; 3 leads SOT323 PMSTA06 4. Marking Table 5. Marking codes Type number Marking code[1] PMSTA05 *1H PMSTA06 *1G [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China PMSTA05_06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 2 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VCBO collector-base voltage open emitter VCEO Min Max Unit PMSTA05 - 60 V PMSTA06 - 80 V - 60 V collector-emitter voltage open base PMSTA05 PMSTA06 - 80 V - 4 V collector current - 500 mA ICM peak collector current - 500 mA IBM peak base current Ptot total power dissipation Tj VEBO emitter-base voltage IC open collector - 500 mA - 200 mW junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Tamb ≤ 25 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB). 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Rth(j-a) [1] PMSTA05_06 Product data sheet Conditions thermal resistance from junction to ambient in free air [1] Min Typ Max Unit - - 625 K/W Device mounted on an FR4 PCB. All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 3 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PMSTA05 VCB = 60 V; IE = 0 A - - 100 nA PMSTA06 VCB = 80 V; IE = 0 A - - 100 nA IEBO emitter-base cut-off current VEB = 3 V; IC = 0 A - - 500 nA hFE DC current gain VCE = 2 V; IC = 10 mA ICBO collector-base cut-off current 50 - - VCE = 1 V; IC = 100 mA [1] 50 - - - VCEsat collector-emitter saturation voltage IC = 100 mA; IB = 10 mA [1] VBEsat base-emitter saturation voltage IC = 100 mA; IB = 10 mA [1] VBE base-emitter voltage IC = 100 mA; VCE = 1 V fT transition frequency VCE = 2 V; IC = 10 mA; f = 100 MHz [1] 250 mV - 900 mV - - 1.2 V 100 - - MHz Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 2.2 1.8 1.1 0.8 0.45 0.15 3 2.2 1.35 2.0 1.15 1 2 0.4 0.3 0.25 0.10 1.3 Dimensions in mm Fig 1. PMSTA05_06 Product data sheet 04-11-04 Package outline SOT323 (SC-70) All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 4 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PMSTA05 Package Description SOT323 Packing quantity 4 mm pitch, 8 mm tape and reel 3000 10000 -115 -135 PMSTA06 [1] For further information and the availability of packing methods, see Section 14. 11. Soldering 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) Fig 2. sot323_fr Reflow soldering footprint SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Fig 3. PMSTA05_06 Product data sheet Wave soldering footprint SOT323 (SC-70) All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 5 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PMSTA05_06 v.3 20100722 Product data sheet - PMSTA05_06_2 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 1 “Product profile”: amended Section 3 “Ordering information”: added Section 4 “Marking”: updated Section 8 “Test information”: added Figure 1: superseded by minimized package outline drawing Section 10 “Packing information”: added Section 11 “Soldering”: added Section 13 “Legal information”: updated PMSTA05_06_2 19990429 Product specification - PMSTA05_06_1 PMSTA05_06_1 19970616 Product specification - - PMSTA05_06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 6 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PMSTA05_06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 7 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PMSTA05_06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 22 July 2010 © Nexperia B.V. 2017. All rights reserved 8 of 9 PMSTA05; PMSTA06 Nexperia 500 mA NPN general-purpose transistors 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features and benefits . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Test information . . . . . . . . . . . . . . . . . . . . . . . . . Quality information . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 July 2010 1 1 1 1 1 2 2 2 3 3 4 4 4 4 5 5 6 7 7 7 7 8 8 9
PMSTA05,115 价格&库存
很抱歉,暂时无法提供与“PMSTA05,115”相匹配的价格&库存,您可以联系我们找货
PMSTA05,115
    • 10+0.34798
    • 100+0.27843
    • 300+0.24365
    • 3000+0.21752
    • 6000+0.19656
    • 9000+0.18620
    库存:971
    PMSTA05,115
      PMSTA05,115
        PMSTA05,115
        • 1+1.675781+0.21604
        • 10+1.0417610+0.13431
        • 100+0.64523100+0.08319
        • 500+0.46997500+0.06059
        • 1000+0.412851000+0.05323
        库存:2700
