BCP56; BCX56; BC56PA
80 V, 1 A NPN medium power transistors
Rev. 9 — 25 October 2011
Product data sheet
1. Product profile
1.1 General description
NPN medium power transistor series in Surface-Mounted Device (SMD) plastic packages.
Table 1.
Product overview
Type number[1]
Package
Nexperia
JEITA
JEDEC
BCP56
SOT223
SC-73
BCP53
BCX56
SOT89
SC-62
TO-243
BCX53
BC56PA
SOT1061
BC53PA
[1]
PNP complement
Valid for all available selection groups.
1.2 Features and benefits
High current
Three current gain selections
High power dissipation capability
Exposed heatsink for excellent thermal and electrical conductivity (SOT89, SOT1061)
Leadless very small SMD plastic package with medium power capability (SOT1061)
AEC-Q101 qualified
1.3 Applications
Linear voltage regulators
Low-side switches
Battery-driven devices
Power management
MOSFET drivers
Amplifiers
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
80
V
IC
collector current
1
A
ICM
peak collector current
single pulse; tp 1 ms
2
A
hFE
DC current gain
VCE = 2 V; IC = 150 mA
[1]
63
250
[1]
63
160
[1]
100
250
hFE selection -10
hFE selection -16
[1]
Pulse test: tp 300 s; = 0.02.
Nexperia
2. Pinning information
Table 3.
Pin
Pinning
Description
Simplified outline
Graphic symbol
SOT223
1
base
2
collector
3
emitter
4
collector
2, 4
4
1
1
2
3
3
sym016
SOT89
1
emitter
2
collector
3
base
2
3
3
2
1
1
sym042
SOT1061
1
base
2
emitter
3
collector
3
3
1
2
1
sym021
2
Transparent top view
3. Ordering information
Table 4.
Type number[1]
Name
Description
Version
BCP56
SC-73
plastic surface-mounted package with increased
heatsink; 4 leads
SOT223
BCX56
SC-62
plastic surface-mounted package; exposed die pad for
good heat transfer; 3 leads
SOT89
BC56PA
HUSON3 plastic thermal enhanced ultra thin small outline
package; no leads; 3 terminals; body 2 2 0.65 mm
[1]
BCP56_BCX56_BC56PA
Product data sheet
Package
SOT1061
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 22
Nexperia
4. Marking
Table 5.
BCP56_BCX56_BC56PA
Product data sheet
Marking codes
Type number
Marking code
BCP56
BCP56
BCP56-10
BCP56/10
BCP56-16
BCP56/16
BCX56
BH
BCX56-10
BK
BCX56-16
BL
BC56PA
AZ
BC56-10PA
BK
BC56-16PA
BL
3 of 22
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
100
V
VCEO
open base
80
V
VEBO
emitter-base voltage
open collector
5
V
IC
collector current
1
A
ICM
2
A
IB
base current
0.3
A
IBM
peak base current
single pulse;
tp 1 ms
0.3
A
Ptot
total power dissipation
Tamb 25 C
[1]
0.65
W
[2]
1.00
W
[3]
1.35
W
[1]
0.50
W
[2]
0.95
W
[3]
1.35
W
[1]
0.42
W
[2]
0.83
W
[3]
1.10
W
[4]
0.81
W
[5]
1.65
W
single pulse;
tp 1 ms
BCP56
BCX56
BC56PA
BCP56_BCX56_BC56PA
Product data sheet
Tj
junction temperature
150
C
Tamb
ambient temperature
55
+150
C
Tstg
storage temperature
65
+150
C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
[4]
Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint.
[5]
Device mounted on an FR4 PCB, 4-layer copper, tin-plated, mounting pad for collector 1 cm2.
4 of 22
Nexperia
006aac674
1.5
006aac675
1.5
(1)
(1)
Ptot
(W)
Ptot
(W)
(2)
1.0
(2)
1.0
(3)
(3)
0.5
0.5
0.0
–75
–25
25
75
0.0
–75
125
175
Tamb (°C)
–25
25
75
125
175
Tamb (°C)
(1) FR4 PCB, mounting pad for collector 6 cm2
cm2
(2) FR4 PCB, mounting pad for collector 1 cm2
(3) FR4 PCB, standard footprint
Fig 1.
Power derating curves SOT223
Fig 2.
Power derating curves SOT89
006aac676
2.0
Ptot
(W)
(1)
1.5
(2)
1.0
(3)
(4)
0.5
(5)
0.0
–75
–25
25
75
125
175
Tamb (°C)
(1) FR4 PCB, 4-layer copper, mounting pad for collector 1 cm2
(2) FR4 PCB, single-sided copper, mounting pad for collector 6 cm2
(3) FR4 PCB, single-sided copper, mounting pad for collector 1 cm2
(4) FR4 PCB, 4-layer copper, standard footprint
(5) FR4 PCB, single-sided copper, standard footprint
Fig 3.
Power derating curves SOT1061
BCP56_BCX56_BC56PA
Product data sheet
5 of 22
Nexperia
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-a)
thermal resistance from
junction to ambient
in free air
[1]
192
K/W
[2]
125
K/W
[3]
93
K/W
[1]
250
K/W
[2]
132
K/W
[3]
93
K/W
[1]
298
K/W
[2]
151
K/W
[3]
114
K/W
[4]
154
K/W
[5]
76
K/W
BCP56
16
K/W
BCX56
16
K/W
BC56PA
K/W
BCP56
BCX56
BC56PA
Rth(j-sp)
BCP56_BCX56_BC56PA
Product data sheet
junction to solder point
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
[4]
[5]
6 of 22
Nexperia
006aac677
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10–1
10–5
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 4.
Transient thermal impedance from junction to ambient as a function of pulse duration for SOT223;
typical values
006aac678
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
0.1
10
0.05
1
10–1
10–5
0.02
0.01
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 5.
typical values
BCP56_BCX56_BC56PA
Product data sheet
7 of 22
Nexperia
006aac679
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
0.1
10
0.05
1
10–1
10–5
0.02
0.01
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 6.
typical values
006aac680
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
0.33
0.2
102
0.1
0.05
10
0.02
0.01
1
10–1
10–5
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 7.
Transient thermal impedance from junction to ambient as a function of pulse duration for SOT89;
typical values
BCP56_BCX56_BC56PA
Product data sheet
8 of 22
Nexperia
006aac681
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
0.33
0.2
102
0.1
10
0.05
0.02
0.01
1
10–1
10–5
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 8.
typical values
006aac682
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.33
0.2
0.1
10
0.05
1
10–1
10–5
0.02
0.01
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 9.
typical values
BCP56_BCX56_BC56PA
Product data sheet
9 of 22
Nexperia
006aac683
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
0.33
0.25
0.2
102
0.1
0.05
10
0.02
1
0.01
10–1
10–5
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 10. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT1061;
typical values
006aac684
103
Zth(j-a)
(K/W)
102
10
duty cycle = 1
0.75
0.5
0.33
0.25
0.2
0.1
0.05
0.02
1
0.01
10–1
10–5
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 11. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT1061;
typical values
BCP56_BCX56_BC56PA
Product data sheet
10 of 22
Nexperia
006aac685
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
0.33
0.25
0.2
102
0.1
10
1
10–1
10–5
0.05
0.02
0.01
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 12. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT1061;
typical values
006aac686
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.25
0.33
0.2
0.1
10
0.05
0.02
1
10–1
10–5
0.01
10–4
10–3
10–2
10–1
1
10
102
103
tp (s)
Fig 13. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT1061;
typical values
BCP56_BCX56_BC56PA
Product data sheet
11 of 22
Nexperia
006aac687
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.25
10
0.1
1
10–1
10–5
0.33
0.2
0.05
0.02
0.01
10–4
10–3
10–2
10–1
1
102
10
103
tp (s)
Fig 14. Transient thermal impedance from junction to ambient as a function of pulse duration for SOT1061;
typical values
7. Characteristics
Table 8.
Characteristics
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = 30 V; IE = 0 A
100
nA
VCB = 30 V; IE = 0 A;
Tj = 150 C
10
A
IEBO
emitter-base cut-off
current
VEB = 5 V; IC = 0 A
100
nA
hFE
DC current gain
VCE = 2 V
DC current gain
Product data sheet
[1]
63
IC = 150 mA
[1]
63
250
IC = 500 mA
[1]
40
VCE = 2 V
hFE selection -10
IC = 150 mA
[1]
63
160
hFE selection -16
IC = 150 mA
[1]
100
250
0.5
V
1
V
VCEsat
collector-emitter
saturation voltage
IC = 500 mA; IB = 50 mA
[1]
VBE
base-emitter voltage
VCE = 2 V; IC = 500 mA
[1]
Cc
collector capacitance
VCB = 10 V; IE = ie = 0 A;
f = 1 MHz
6
pF
fT
transition frequency
VCE = 5 V; IC = 50 mA;
f = 100 MHz
100
180
MHz
[1]
BCP56_BCX56_BC56PA
IC = 5 mA
12 of 22
Nexperia
006aac691
300
006aaa084
1.6
IB (mA) = 50
45
40
35
30
IC
(A)
hFE
1.2
(1)
25
15
(2)
0.8
100
10
5
(3)
0.4
10–4
10–3
10–2
10–1
0.4
0.8
1.2
1.6
2.0
VCE (V)
IC (A)
Tamb = 25 C
VCE = 2 V
(1) Tamb = 100 C
(2) Tamb = 25 C
(3) Tamb = 55 C
Fig 15. DC current gain as a function of collector
current; typical values
006aac692
1.2
VBE
(V)
Fig 16. Collector current as a function of
collector-emitter voltage; typical values
006aac693
1
VCEsat
(V)
(1)
0.8
(2)
10–1
(3)
(1)
0.4
(2)
(3)
0.0
10–1
1
10
102
103
104
IC (mA)
10–2
10–1
1
VCE = 2 V
IC/IB = 10
(1) Tamb = 55 C
(1) Tamb = 100 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 100 C
(3) Tamb = 55 C
Fig 17. Base-emitter voltage as a function of collector
BCP56_BCX56_BC56PA
Product data sheet
10
102
103
104
IC (mA)
Fig 18. Collector-emitter saturation voltage as a
function of collector current; typical values
13 of 22
Nexperia
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
6.7
6.3
3.1
2.9
1.8
1.5
4
1.1
0.7
7.3
6.7
3.7
3.3
1
2
3
0.32
0.22
0.8
0.6
2.3
4.6
Dimensions in mm
04-11-10
Fig 19. Package outline SOT223 (SC-73)
4.6
4.4
1.8
1.4
1.6
1.4
2.6
2.4
4.25
3.75
1
2
1.2
0.8
3
0.53
0.40
1.5
0.48
0.35
0.44
0.23
3
Dimensions in mm
06-08-29
Fig 20. Package outline SOT89 (SC-62/TO-243)
BCP56_BCX56_BC56PA
Product data sheet
14 of 22
Nexperia
1.3
0.65
max
0.35
0.25
1
1.05
0.95
2
0.45
0.35
1.1
0.9
0.3
0.2
2.1
1.9
3
1.6
1.4
Dimensions in mm
2.1
1.9
09-11-12
Fig 21. Package outline SOT1061 (HUSON3)
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type
number[2]
Package
BCP56
SOT223
BCX56
BC56PA
BCP56_BCX56_BC56PA
Product data sheet
Description
Packing quantity
8 mm pitch, 12 mm tape and reel
SOT89
SOT1061
-135
8 mm pitch, 12 mm tape and reel; T1
-115
-135
8 mm pitch, 12 mm tape and reel; T3
[4]
-146
-115
4 mm pitch, 8 mm tape and reel
For further information and the availability of packing methods, see Section 14.
T1: normal taping
T3: 90 rotated taping
4000
-115
[2]
[4]
3000
[3]
[1]
[3]
1000
15 of 22
Nexperia
11. Soldering
7
3.85
3.6
3.5
0.3
1.3 1.2
(4×) (4×)
solder lands
4
solder resist
3.9
6.1 7.65
solder paste
occupied area
1
2
3
Dimensions in mm
2.3
2.3
1.2
(3×)
1.3
(3×)
6.15
sot223_fr
Fig 22. Reflow soldering footprint SOT223 (SC-73)
8.9
6.7
1.9
solder lands
4
solder resist
6.2
8.7
occupied area
Dimensions in mm
1
2
3
preferred transport
direction during soldering
1.9
(3×)
2.7
2.7
1.1
1.9
(2×)
sot223_fw
Fig 23. Wave soldering footprint SOT223 (SC-73)
BCP56_BCX56_BC56PA
Product data sheet
16 of 22
Nexperia
4.75
2.25
2
1.9
1.2
0.2
0.85
solder lands
1.7
1.2
4.6
solder resist
0.5
4.85
solder paste
occupied area
1.1
(2×)
1
(3×)
1.5
Dimensions in mm
1.5
0.6
(3×)
0.7
(3×)
3.95
sot089_fr
Fig 24. Reflow soldering footprint SOT89 (SC-62/TO-243)
6.6
2.4
3.5
solder lands
7.6
0.5
solder resist
occupied area
1.8
(2×)
Dimensions in mm
preferred transport direction during soldering
1.9
1.5
(2×)
1.9
0.7
5.3
sot089_fw
Fig 25. Wave soldering footprint SOT89 (SC-62/TO-243)
BCP56_BCX56_BC56PA
Product data sheet
17 of 22
Nexperia
2.1
1.3
0.5 (2×)
0.4 (2×)
0.5 (2×)
0.6 (2×)
1.05
2.3
0.6
0.55
0.25
1.1
0.25
1.2
0.25
0.4
0.5
1.6
1.7
Dimensions in mm
solder paste = solder lands
solder resist
occupied area
sot1061_fr
Reflow soldering is the only recommended soldering method.
Fig 26. Reflow soldering footprint SOT1061 (HUSON3)
BCP56_BCX56_BC56PA
Product data sheet
18 of 22
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
BCP56_BCX56_BC56PA v.9
20111025
Product data sheet
Modifications:
BC639_BCP56_BCX56 v.8
Type number removed: BC639
Type number added: BC56PA, BC56-10PA and BC56-16PA
Section 1 “Product profile”: updated
Section 2 “Pinning information”: updated
Table 6 and 7: updated according to latest measurements
Figure 1, 2, 4, 5, 7 to 9, 15, 17 and 18: updated
Figure 3, 6, 10 to 14: added
Section 8 “Test information”: added
Section 10 “Packing information”: updated
Section 11 “Soldering”: added
Section 13 “Legal information”: updated
20070622
Product data sheet
BC639_BCP56_BCX56 v.7
20050308
Product data sheet
BC639_BCP56_BCX56 v.6
20050303
Product data sheet
CPCN2004050
29
BC635_637_639 v.4
BCP54_55_56 v.5
BCX54_55_56 v.4
BC635_637_639 v.4
20011010
Product specification
BC635_637_639 v.3
BCP54_55_56 v.5
20030206
BCP54_55_56 v.4
BCX54_55_56 v.4
20011010
BCX54_55_56 v.3
BCP56_BCX56_BC56PA
Product data sheet
19 of 22
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
BCP56_BCX56_BC56PA
Product data sheet
20 of 22
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BCP56_BCX56_BC56PA
Product data sheet
21 of 22
Nexperia
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Thermal characteristics . . . . . . . . . . . . . . . . . . 6
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . 12
Test information . . . . . . . . . . . . . . . . . . . . . . . . 14
Quality information . . . . . . . . . . . . . . . . . . . . . 14
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14
Packing information . . . . . . . . . . . . . . . . . . . . 15
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19
Legal information. . . . . . . . . . . . . . . . . . . . . . . 20
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Contact information. . . . . . . . . . . . . . . . . . . . . 21
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Date of release: 25 October 2011
