PMSTA92
PNP high-voltage transistor
16 May 2019
Product data sheet
1. General description
PNP high-voltage transistor in a very small SOT323 (SC-70) Surface-Mounted Device (SMD)
plastic package.
NPN complement: PMSTA42
2. Features and benefits
Very small package
High voltage
AEC-Q101 qualified
3. Applications
Primarily intended for use in telephony and professional communication equipment.
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
-300
V
IC
collector current
-100
mA
hFE
DC current gain
30
VCE = -10 V; IC = -30 mA
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
B
base
2
E
emitter
3
C
collector
Simplified outline
Graphic symbol
3
C
B
E
sym132
1
2
SC-70 (SOT323)
PMSTA92
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
PMSTA92
Name
Description
Version
SC-70
plastic surface-mounted package; 3 leads
SOT323
7. Marking
Table 4. Marking codes
Type number
Marking code[1]
PMSTA92
%2D
[1]
% = placeholder for manufacturing site code
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
-300
V
VCEO
collector-emitter voltage
open base
-300
V
VEBO
emitter-base voltage
open collector
-5
V
IC
collector current
-100
mA
ICM
peak collector current
-200
mA
IBM
peak base current
-100
mA
Ptot
total power dissipation
200
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-65
150
°C
Tstg
storage temperature
-65
150
°C
[1]
single pulse; tp ≤ 1 ms
Tamb ≤ 25 °C
[1]
Refer to SOT323 (SC-70) standard mounting conditions.
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
[1]
Conditions
thermal resistance from in free air
junction to ambient
[1]
Min
Typ
Max
Unit
625
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
PMSTA92
Product data sheet
All information provided in this document is subject to legal disclaimers.
16 May 2019
Nexperia B.V. 2019. All rights reserved
2/8
PMSTA92
Nexperia
10. Characteristics
Table 7. Characteristics
Tamb = 25 °C, unless otherwise specified
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = -200 V; IE = 0 A
-100
nA
IEBO
emitter-base cut-off
current
VEB = -3 V; IC = 0 A
-100
nA
hFE
DC current gain
VCE = -10 V; IC = -1 mA
40
VCE = -10 V; IC = -10 mA
40
30
IC = -20 mA; IB = -2 mA; pulsed; tp ≤
300 µs; δ ≤ 0.02; Tamb = 25 °C
-250
mV
-900
mV
VCEsat
collector-emitter
saturation voltage
VBEsat
base-emitter saturation
voltage
Cc
collector capacitance
VCB = -20 V; IE = 0 A; ie = 0 A;
f = 1 MHz
1.9
3.5
pF
Ce
emitter capacitance
VEB = -5 V; IC = 0 A; ic = 0 A; f = 1 MHz
pF
fT
transition frequency
VCE = -20 V; IC = -10 mA; f = 100 MHz
50
MHz
PMSTA92
Product data sheet
16 May 2019
3/8
PMSTA92
Nexperia
11. Package outline
Plastic surface-mounted package; 3 leads
SOT323
D
B
E
A
X
HE
y
v M A
3
Q
A
A1
1
c
2
e1
bp
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.8
0.1
0.4
0.3
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT323
Fig. 1.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
SC-70
Package outline SC-70 (SOT323)
PMSTA92
Product data sheet
16 May 2019
4/8
PMSTA92
Nexperia
12. Soldering
2.65
1.85
1.325
solder lands
solder resist
2
2.35
0.6
(3×)
3
solder paste
1.3
occupied area
0.5
(3×)
1
Dimensions in mm
0.55
(3×)
Fig. 2.
sot323_fr
Reflow soldering footprint for SC-70 (SOT323)
4.6
2.575
1.425
(3×)
solder lands
solder resist
occupied area
1.8
3.65 2.1
09
(2×)
Dimensions in mm
preferred transport
direction during soldering
sot323_fw
Fig. 3.
Wave soldering footprint for SC-70 (SOT323)
PMSTA92
Product data sheet
16 May 2019
5/8
PMSTA92
Nexperia
13. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMSTA92 v.4
20190516
Product data sheet
PMSTA92 v.3
Modifications:
Marking: Marking code corrected
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
PMSTA92 v.3
20010220
Product data sheet
PMSTA92_93 v.2
PMSTA92_93 v.2
19990601
Product data sheet
PMSTA92_93 v.1
PMSTA92_93 v.1
19961209
Product data sheet
PMSTA92
Product data sheet
16 May 2019
6/8
PMSTA92
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
PMSTA92
Product data sheet
16 May 2019
7/8
PMSTA92
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 2
10. Characteristics............................................................ 3
11. Package outline.......................................................... 4
12. Soldering..................................................................... 5
13. Revision history..........................................................6
14. Legal information........................................................7
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 16 May 2019
PMSTA92
Product data sheet
16 May 2019
8/8
很抱歉,暂时无法提供与“PMSTA92,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.834911+0.36593
- 10+1.7512310+0.22605
- 100+1.09257100+0.14103
- 500+0.80649500+0.10411
- 1000+0.713761000+0.09214
- 国内价格
- 1+2.34170
- 5+1.82185
- 10+1.56073
