SR320-SR3200
3.0 AMP. Schottky Barrier Rectifiers
DO-201AD
Features
Low power loss, high efficiency.
High current capability, Low VF.
High reliability
High surge current capability.
Epitaxial construction.
Guard-ring for transient protection.
For use in low voltage, high frequency
inventor, free wheeling, and polarity
protection application
Mechanical Data
Cases: DO-201AD molded plastic
Polarity: Color band denotes cathode
Higho temperature soldering guaranteed:
260 C/10 seconds/.375”,(9.5mm) lead
lengths at 5 lbs., (2.3kg) tension
Weight: 1.2grams
Dimensions in inches and (millimeters)
Maximum
Ratings and Electrical Characteristics
o
Rating at 25 C ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol SR SR SR SR SR SR SR SR SR Units
320 330 340 350 360 390 3100 3150 3200
VRRM 20 30 40 50 60 90 100 150 200
V
VRMS 14 21 28 35 42 63 70 105 140
V
VDC
V
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
See Fig. 1
I(AV)
Maximum Instantaneous Forward Voltage @3.0A
Maximum D.C. Reverse Current @ TA=25 oC
at Rated DC Blocking Voltage
@ TA=125 oC
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance (Note 1)
Operating Junction Temperature Range
Storage Temperature Range
Notes:
Revision:20170301-P1
VF
IR
Cj
RθJA
RθJC
TJ
TSTG
3.0
0.55
0.70
0.5
10
200
-65 to +125
5
130
50
15
A
0.85
0.95
0.1
2.0
72
-65 to +150
-65 to +150
V
mA
mA
pF
o
C/W
o
C
C
o
1. Mount on Cu-Pad Size 16mm x 16mm on P.C.B.
2. Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C.
ht t p : //
www.lgesemi .c o m
mail:lge@lgesemi.com
SR320-SR3200
RATINGS AND CHARACTERISTIC CURVES
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
100
PEAK FORWARD SURGE CURRENT
AMPERES
AVERAGE FORWARD CURRENT.
AMPERES
4
3
R3
0-S
35
SR
S
40
R3
0-S
32
SR
S
2
1
50
75
100
125
150
FIG.2- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
60
40
8.3ms Single Half Sine Wave
JEDEC Method
80
1
2
4
6 8 10
NUMBER OF CYCLES AT 60Hz
o
50
40
60 80 100
FIG.4- TYPICAL REVERSE CHARACTERISTICS
10
SR
S
320
-SR
340
360
-SR
350
R
S
S
1.0
SR
S
0.1
.2
-S
R3
10
SR
S
50
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
.3
.4
.5
.6
.7
FORWARD VOLTAGE. (V)
.8
.9
1.0
INSTANTANEOUS REVERSE CURRENT. (mA)
Tj=125 0C
10
1000
JUNCTION CAPACITANCE.(pF)
FIG.3- TYPICAL FORWARD CHARACTERISTICS
600
400
.10
SR
S
100
80
60
SR
S
40
SR
S
39
.2
.4
1.0
2
4
10
REVERSE VOLTAGE. (V)
0-S
32
35
R3
0-3
40
100
60
100
Tj=25 0C
ht t p : //
SR320-340
SR350-3150
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
FIG.6- TYPICAL TRANSIENT THERMAL
CHARACTERISTICS
10
1
0.1
Tj=75 0C
.01
.001
200
10
1.0
FIG.5- TYPICAL JUNCTION CAPACITANCE
TRANSIENT THERMAL IMPEDANCE. (OC/W)
INSTANTANEOUS FORWARD CURRENT. (A)
LEAD TEMPERATURE. ( C)
0.01
0.1
1
10
T, PULSE DURATION. (sec)
www.lgesemi .c o m
100
很抱歉,暂时无法提供与“SR340”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42973
- 100+0.34574
- 300+0.30375
- 1250+0.26526
- 5000+0.24009
- 10000+0.22745
