5KP7.0A
5KP7.0A
    LEIDITECH(雷卯电子)
    R-6
    雷卯 R-6 5000W 7V
5KP7.0A 数据手册
5KP Series 5000W Transient Voltage Suppressor DESCRIPTION: The 5KP series of high current uni/bi-directional transient suppressors are designed for A.C. line protection and high power DC bus clamping applications. These devices offer uni/bi-directional port protection from 5.0 volts to 250 volts. They provide a clamping voltage lower than the avalanche voltage. Therefore, any voltage rise due to increased current conduction is contained to a minimum, providing the best possible protection level. They can also be connected in series and/or parallel to create very high capacity protection solutions. FEATURES:           Low zener impedance. Excellent clamping capability. JEDEC R-6/P-600 Molded Plastic. Repetition rate (duty cycle): 0.01%. Color band denoted cathode except bidirectional. High temperature soldering: 260℃/10s at terminals. Glass passivated chip junction in R-6/P600 package. 5000W Peak Pulse power capability at 10×1000μs waveform. Fast response time: typically less than 1.0ps from 0V to VBR min. AEC-Q101 qualified. Symbol ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit PPP 5000 W IPP See next table A PM(AV) 8 W TSTG, TJ -55 to +125 ℃ IFSM 400 A Peak pulse power dissipation on 10/1000μs waveform Peak pulse current of on 10/1000μs waveform Steady state power dissipation at TL=75℃ Operating junction and Storage temperature range Peak forward surge current, 8.3ms single half sine-wave Rev : 01.06.2014 1/5 www.leiditech.com 5KP Series 5000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A 5KP5.0A 5KP5.0CA 5.0 150 6.40 7.00 10 9.2 544.0 5KP6.0A 5KP6.0CA 6.0 100 6.67 7.37 10 10.3 486.0 5KP6.5A 5KP6.5CA 6.5 50 7.22 7.98 10 11.2 448.0 5KP7.0A 5KP7.0CA 7.0 20 7.78 8.60 10 12.0 417.0 5KP7.5A 5KP7.5CA 7.5 10 8.33 9.21 1 12.9 388.0 5KP8.0A 5KP8.0CA 8.0 10 8.89 9.83 1 13.6 367.0 5KP8.5A 5KP8.5CA 8.5 10 9.44 10.40 1 14.4 347.0 5KP9.0A 5KP9.0CA 9.0 10 10.00 11.10 1 15.4 325.0 5KP10A 5KP10CA 10.0 5 11.10 12.30 1 17.0 294.0 5KP11A 5KP11CA 11.0 5 12.20 13.50 1 18.2 275.0 5KP12A 5KP12CA 12.0 2 13.30 14.70 1 19.9 252.0 5KP13A 5KP13CA 13.0 2 14.40 15.90 1 21.5 233.0 5KP14A 5KP14CA 14.0 1 15.60 17.20 1 23.2 216.0 5KP15A 5KP15CA 15.0 1 16.70 18.50 1 24.4 205.0 5KP16A 5KP16CA 16.0 1 17.80 19.70 1 26.0 193.0 5KP17A 5KP17CA 17.0 1 18.90 20.90 1 27.6 181.0 5KP18A 5KP18CA 18.0 1 20.00 22.10 1 29.2 172.0 5KP20A 5KP20CA 20.0 1 22.20 24.50 1 32.4 155.0 5KP22A 5KP22CA 22.0 1 24.40 26.90 1 35.5 141.0 5KP24A 5KP24CA 24.0 1 26.70 29.50 1 38.9 129.0 5KP26A 5KP26CA 26.0 1 28.90 31.90 1 42.1 119.0 5KP28A 5KP28CA 28.0 1 31.10 34.40 1 45.4 110.0 5KP30A 5KP30CA 30.0 1 33.30 36.80 1 48.4 103.0 5KP33A 5KP33CA 33.0 1 36.70 40.60 1 53.3 93.9 5KP36A 5KP36CA 36.0 1 40.00 44.20 1 58.1 86.1 5KP40A 5KP40CA 40.0 1 44.40 49.10 1 64.5 77.6 5KP43A 5KP43CA 43.0 1 47.80 52.80 1 69.4 72.1 5KP45A 5KP45CA 45.0 1 50.00 55.30 1 72.7 68.8 5KP48A 5KP48CA 48.0 1 53.30 58.90 1 77.4 64.7 5KP51A 5KP51CA 51.0 1 56.70 62.70 1 82.4 60.7 Rev : 01.06.2014 2/5 www.leiditech.com 5KP Series 5000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A 5KP54A 5KP54CA 54.0 1 60.00 66.30 1 87.1 57.5 5KP58A 5KP58CA 58.0 1 64.40 71.20 1 93.6 53.5 5KP60A 5KP60CA 60.0 1 66.70 73.70 1 96.8 51.7 5KP64A 5KP64CA 64.0 1 71.10 78.60 1 103.0 48.6 5KP70A 5KP70CA 70.0 1 77.80 86.00 1 113.0 44.3 5KP75A 5KP75CA 75.0 1 83.30 92.10 1 121.0 41.4 5KP78A 5KP78CA 78.0 1 86.70 95.80 1 126.0 39.7 5KP85A 5KP85CA 85.0 1 94.40 104.0 1 137.0 36.5 5KP90A 5KP90CA 90.0 1 100.0 111.0 1 146.0 34.3 5KP100A 5KP100CA 100.0 1 100.0 111.0 1 162.0 30.9 5KP110A 5KP110CA 110.0 1 111.0 123.0 1 177.0 28.3 5KP120A 5KP120CA 120.0 1 122.0 135.0 1 193.0 26.0 5KP130A 5KP130CA 130.0 1 133.0 147.0 1 209.0 24.0 5KP150A 5KP150CA 150.0 1 144.0 159.0 1 243.0 20.6 5KP160A 5KP160CA 160.0 1 167.0 185.0 1 259.0 19.3 5KP170A 5KP170CA 170.0 1 178.0 197.0 1 275.0 18.2 5KP180A 5KP180CA 180.0 1 189.0 209.0 1 292.0 17.5 5KP190A 5KP190CA 190.0 1 211.0 233.0 1 310.0 16.5 5KP200A 5KP200CA 200.0 1 224.0 247.0 1 329.2 15.5 5KP210A 5KP210CA 210.0 1 237.0 263.0 1 349.5 14.6 5KP220A 5KP220CA 220.0 1 246.0 272.0 1 371.1 13.7 5KP250A 5KP250CA 250.0 1 277.0 306.0 1 425.0 12.0 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR:Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR:Reverse Leakage Current Rev : 01.06.2014 3/5 www.leiditech.com 5KP Series 5000W Transient Voltage Suppressor RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) F IG .1:V - I cu rve ch aracteristics (U n i-d irectio n al) F IG .2:V - I cu rve ch aracteristics (B i-d irectio n al) IP P V V C V BR V R IT IR V C VBR VR V IR IT VF V R V BR V C I PP IP P FIG.4: Pulse derating curve FIG.3: Pulse waveform P PP derating in percentage(%) 100 IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 50 T A (℃ ) 75 100 125 150 175 SOLDERING PARAMETERS Reflow Condition +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow tp Critical Zone TL to TP Ramp-up tL TS(max) -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev : 01.06.2014 FIG.5: Reflow condition -Temperature Min (Ts(min)) 4/5 Temperature Pre Heat Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time www.leiditech.com 5KP Series 5000W Transient Voltage Suppressor MARKING & ORDERING INFORMATION 5KP XX C A (1) (2) (3) (4) (1)Series:5000 watts series (2)Reverse Stand-off Voltage (3)Bi-directional (4)5% V BR Voltage tolerance Cathode Band Logo Product Type 5KPxxCA PACKAGE MECHANICAL DATA Dimensions A B A Ref. Min. C D Millimeters Inches Max. Min. Max. - 25.40 - A 1.000 B 0.339 0.370 8.60 9.40 C 0.048 0.052 1.20 1.40 D 0.340 0.360 8.60 9.10 Part Number Case Type Quantity Packing Option 5KPXXCA/A R6/P600 300 Box Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 5/5 www.leiditech.com
5KP7.0A
物料型号:5KP系列,包括5KP5.0A至5KP250A等不同型号,分别对应不同的工作电压。
器件简介:5KP系列瞬态电压抑制器设计用于交流线路保护和高功率直流总线钳位应用。它们提供5.0伏至250伏的单/双向端口保护,具有较低的钳位电压,以提供最佳保护。
引脚分配:文档中未明确提供引脚分配信息,但通常这类器件会有阳极和阴极两个引脚。
参数特性:包括低zener阻抗、优秀的钳位能力、JEDEC R-6/P-600封装、重复率、高温焊接能力、玻璃钝化芯片结构、5000W峰值脉冲功率能力、快速响应时间、AEC-Q101认证等。
功能详解:5KP系列能够将由于电流增加引起的电压上升控制在最低限度,并且可以通过串联和/或并联连接来创建高容量的保护解决方案。
应用信息:适用于交流线路保护和高功率直流总线钳位。
封装信息:JEDEC R-6/P-600封装,具体尺寸和包装选项在文档中有详细说明。
5KP7.0A 价格&库存
很抱歉,暂时无法提供与“5KP7.0A”相匹配的价格&库存,您可以联系我们找货
