P6SMB36A
P6SMB36A
    LEIDITECH(雷卯电子)
    SMB(DO-214AA)
    SMB SMT 30.8V
P6SMB36A 数据手册
P6SMBSeries 600W Transient Voltage Suppressor Description The P6SMB series is designed specifically to protectsensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. DO-214AA(SMB) Features z For surface mounted applications z Reliable low cost construction utilizing molded plastic technique z Plastic package has UL flammability classification 94V-O z Typical IR less than 1uA above 13V z Glass passivated chip junction in DO-15 Package z 600W peak pulse capability at 10*1000us waveform,repetition rate (duty cycles):0.01% z Fast response time: typically less than 1.0ps from 0 Volts to BV min z AEC -Q101 qualified. Maximum Ratings and Electrical Characteristics (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit PPPM 600 W Power Dissipation on infinite heat sink at TA=75℃ PD 5.0 W Peak Forward Surge Current, 8.3ms Single Half Sine Wave Unidirectional only(Note 2) IFSM 100 A Maximum Instantaneous Forward Voltage at 50A for Unidirectional only (Note 3) VF 3.5V/5.0 V TJ, TSTG -55 to 175 ℃ Typical Thermal Resistance Junction to Lead RuJL 20 ℃/W Typical Thermal Resistance Junction to Ambient RuJA 75 ℃/W Peak Pulse Power Dissipation at TA=25℃ by 10x1000μs waveform (Fig.1)(Note 1) Operating Junction and Storage Temperature Range Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig. 2. 2. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only. 3. VF < 3.5V for devices of VBR ≤ 200V and VF< 5.0V for devicesof VBR ≥ 201V. Applications Tvsdevices are ideal for the protection of I/O interfaces,Vcc bus and other vulnerable circuits uded in telecom, computer,industrial and consumer electronic applications. Rev : 01.06.2014 1/6 www.leiditech.com P6SMBSeries 600W Transient Voltage Suppressor Rating And Characteristic Curves (TA=25℃ unless otherwise noted) Figure 1 – Peak Pulse Power Rating Figure 2 – Pulse Derating Curve Figure 3 – Pulse Waveform Figure 4 – Typical Junction Capacitance Uni- Directional Figure 5 – Steady State Power Derating Curve Rev : 01.06.2014 Figure 6 – Maximum Non-Repetitive Forward Surge Current 2/6 www.leiditech.com P6SMBSeries 600W Transient Voltage Suppressor Electrical Characteristics P6KE PART NUMBER UNI-POLAR BI-POLAR P6SMB6. 8A P6SMB7. 5A P6SMB8. 2A P6SMB9. 1A P6SMB10 A P6SMB11 A P6SMB12 A P6SMB13 A P6SMB15 A P6SMB16 A P6SMB18 A P6SMB20 A P6SMB22 A P6SMB24 A P6SMB27 A P6SMB30 A P6SMB33 A P6SMB36 A P6SMB39 A P6SMB43 A P6SMB47 A P6SMB51 A P6SMB56 A P6SMB62 A P6SMB68 A P6SMB75 A P6SMB82 A P6SMB6.8 CA P6SMB7.5 CA P6SMB8.2 CA P6SMB9.1 CA P6SMB10 CA P6SMB11 CA P6SMB12 CA P6SMB13 CA P6SMB15 CA P6SMB16 CA P6SMB18 CA P6SMB20 CA P6SMB22 CA P6SMB24 CA P6SMB27 CA P6SMB30 CA P6SMB33 CA P6SMB36 CA P6SMB39 CA P6SMB43 CA P6SMB47 CA P6SMB51 CA P6SMB56 CA P6SMB62 CA P6SMB68 CA P6SMB75 CA P6SMB82 CA Rev : 01.06.2014 REVERSE STANDOFF VOLTAGE VRWM(V) BREAKDOWN VOLTAGE VBR(V) MIN. @IT BREAKDOWN VOLTAGE VBR(V) MAX. @IT TEST CURRENT IT (mA) MAXIMUM CLAMPING VOLTAGE @Ipp Vc(V) PEAK PULSE CURRENT Ipp (A) REVERSE LEAKAGE @VRWM IR(µA) 5.8 6.45 7.14 10 10.5 58.1 1000 6.4 7.13 7.88 10 11.3 54 500 7.02 7.79 8.61 10 12.1 50.4 200 7.78 8.65 9.55 1 13.4 45.5 50 8.55 9.5 10.5 1 14.5 42.1 10 9.4 10.5 11.6 1 15.6 39.1 5 10.2 11.4 12.6 1 16.7 36.5 5 11.1 12.4 13.7 1 18.2 33.5 5 12.8 14.3 15.8 1 21.2 28.8 5 13.6 15.2 16.8 1 22.5 27.1 5 15.3 17.1 18.9 1 25.5 24.2 5 17.1 19 21 1 27.7 22 5 18.8 20.9 23.1 1 30.6 19.9 5 20.5 22.8 25.2 1 33.2 18.4 5 23.1 25.7 28.4 1 37.5 16.3 5 25.6 28.5 31.5 1 41.4 14.7 5 28.2 31.4 34.7 1 45.7 13.3 5 30.8 34.2 37.8 1 49.9 12.2 5 33.3 37.1 41 1 53.9 11.3 5 36.8 40.9 45.2 1 59.3 10.3 5 40.2 44.7 49.4 1 64.8 9.4 5 43.6 48.5 53.6 1 70.1 8.7 5 47.8 53.2 58.8 1 77 7.9 5 53 58.9 65.1 1 85 7.2 5 58.1 64.6 71.4 1 92 6.6 5 64.1 71.3 78.8 1 103 5.9 5 70.1 77.9 86.1 1 113 5.4 5 3/6 www.leiditech.com P6SMBSeries 600W Transient Voltage Suppressor Electrical Characteristics P6KE PART NUMBER REVERSE STANDOFF VOLTAGE VRWM(V) BREAKDOWN VOLTAGE VBR(V) MIN. @IT BREAKDOWN VOLTAGE VBR(V) MAX. @IT TEST CURRENT IT (mA) MAXIMUM CLAMPING VOLTAGE @Ipp Vc(V) PEAK PULSE CURRENT Ipp (A) REVERSE LEAKAGE @VRWM IR(µA) UNI-POLAR BI-POLAR P6SMB91A P6SMB91CA 77.8 86.5 95.5 1 125 4.9 5 P6SMB100A P6SMB100CA 85.5 95 105 1 137 4.5 5 P6SMB110A P6SMB110CA 94 105 116 1 152 4 5 P6SMB120A P6SMB120CA 102 114 126 1 165 3.7 5 P6SMB130A P6SMB130CA 111 124 137 1 179 3.4 5 P6SMB150A P6SMB150CA 128 143 158 1 207 2.9 5 P6SMB160A P6SMB160CA 136 152 168 1 219 2.8 5 P6SMB170A P6SMB170CA 145 162 179 1 234 2.6 5 P6SMB180A P6SMB180CA 154 171 189 1 246 2.5 5 P6SMB200A P6SMB200CA 171 190 210 1 274 2.2 5 P6SMB220A P6SMB220CA 185 209 231 1 328 1.9 5 P6SMB250A P6SMB250CA 214 237 263 1 344 1.8 5 P6SMB300A P6SMB300CA 256 285 315 1 414 1.5 5 P6SMB350A P6SMB350CA 300 332 368 1 482 1.3 5 P6SMB400A P6SMB400CA 342 380 420 1 548 1.1 5 P6SMB440A P6SMB440CA 376 418 462 1 602 1 5 P6SMB480A P6SMB480CA 408 456 504 1 658 0.9 5 P6SMB510A P6SMB510CA 434 485 535 1 698 0.9 5 P6SMB530A P6SMB530CA 477 503.5 556.5 1 725 0.8 5 P6SMB540A P6SMB540CA 459 513 567 1 740 0.8 5 P6SMB550A P6SMB550CA 495 522.5 577.5 1 760 0.8 5 For bidirectional type having VRWM of 10 volts and less, the IR limit is double. For parts without A (VBR is ± 10% and VC is 5% higher than with A parts). Rev : 01.06.2014 4/6 www.leiditech.com P6SMBSeries 600W Transient Voltage Suppressor Soldering Parameters -Temperature Min(Ts(min)) -Temperature Max(Ts(min)) -Time(min to max)(ts) Average ramp up rate liquidus Temp (TL) to peak TS(max)to TL-ramp-up Rate -Temperature L)(Liquidus) (T Reflow -Time(min to max)(ts) Peak Temperature(TP) Pre Heat Time within 5℃ of actual peak Temperature(tp) Ramp-down Rate Time 25℃ to peak Temperature (TP) Do not exceed 150℃ 200℃ 60-180 secs 3℃/second max 3℃/second max 217℃ 60-150 seconds 260+0/-5℃ 20-40 seconds Flow/Wave Soldering(Solder Dipping) 6℃/second max 260℃ 10 seconds 1 time Peak Temperature: 8minutes Max. Dipping Time: 280℃ Soldering: Dimensions ` B Inches MIN MAX Millimeters MIN MAX A 0.134 0.155 3.40 3.94 B 0.205 0.22 5.21 5.59 C 0.075 0.083 1.90 2.11 D 0.166 0.185 4.22 4.70 E 0.036 0.056 0.91 1.42 F 0.073 0.087 1.85 2.2 G 0.002 0.008 0.05 0.20 Dimension H 0.077 0.094 1.95 2.40 J 0.043 0.053 1.09 1.35 K 0.008 0.014 0.20 0.35 L 0.039 0.049 0.99 1.24 Rev : 01.06.2014 D C A H F L E J K G .079 (2.0) 0.110 (2.8) .079 (2.0) 5/6 www.leiditech.com P6SMBSeries 600W Transient Voltage Suppressor Part Numbering System Part Marking System Cathode Band 5%Voltage Tolerance Bidirectional Voltage Product Type Series Summary of Packing Options Package Type Description Packing Quantity Industry Standard Embossed Carrier Reel Pack 3000PCS EIA-481-D DO-214AA(SMB) Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 6/6 www.leiditech.com
P6SMB36A
物料型号:P6SMB系列,包括多种型号,如P6SMB6.8A、P6SMB7.5A等,具有不同的反向工作电压和击穿电压。
器件简介:P6SMB系列采用表面贴装技术,具有可靠的低成本结构,塑料封装具有UL可燃性分类94V-0等级。器件具有小于1uA的典型反向电流,600W的峰值脉冲能力,快速响应时间小于1ps。
引脚分配:未在文档中明确说明,但通常DO-214AA(SMB)封装为表面贴装型封装。
参数特性:包括峰值脉冲功率耗散、功率耗散、峰值正向浪涌电流、最大瞬态正向电压等。例如,P6SMB6.8A型号的峰值脉冲电流为58.1A,反向漏电流为1000uA。
功能详解:瞬态电压抑制器(TVS)适用于保护I/O接口、Vcc总线和其他易受电信、计算机、工业和消费电子应用中使用的电路。
应用信息:适用于电信、计算机、工业和消费电子应用中的I/O接口、Vcc总线和其他易受电路的保护。
封装信息:DO-214AA(SMB)封装,采用压花载体卷装,每卷3000件,符合EIA-481-D标准。
P6SMB36A 价格&库存
很抱歉,暂时无法提供与“P6SMB36A”相匹配的价格&库存,您可以联系我们找货
