P8S22CA
P8S22CA
    LEIDITECH(雷卯电子)
    R-6
    雷卯 R-6 8000W 22V
P8S22CA 数据手册
P8S Series 8000W Transient Voltage Suppressor DESCRIPTION: The P8S series of high current uni/bi-directional transient suppressors are designed for A.C. line protection and high power DC bus clamping applications. These devices offer uni/bi-directional port protection from 20 volts to 43 volts. They provide a clamping voltage lower than the avalanche voltage. Therefore, any voltage rise due to increased current conduction is contained to a minimum, providing the best possible protection level. They can also be connected in series and/or parallel to create very high capacity protection solutions. Symbol FEATURES:          Low zener impedance. Excellent clamping capability. JEDEC R-6/P-600 Molded Plastic. Repetition rate (duty cycle): 0.01%. Color band denoted cathode except bidirectional. High temperature soldering: 260℃/10s at terminals. Glass passivated chip junction in R-6/P600 package. 8000W Peak Pulse power capability at 10×1000μs waveform. Fast response time: typically less than 1.0ps from 0V to VBR min.  AEC-Q101 qualified. ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit PPP 8000 W IPP See next table A PM(AV) 8 W TSTG, TJ -55 to +150 ℃ IFSM 500 A Peak pulse power dissipation on 10/1000μs waveform Peak pulse current of on 10/1000μs waveform Steady state power dissipation at TL=75℃ Operating junction and Storage temperature range Peak forward surge current, 8.3ms single half sine-wave Rev : 01.06.2014 1/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A P8S20A P8S20CA 20 5 22.2 24.5 5 32.4 246.9 P8S22A P8S22CA 22 5 24.4 26.9 5 35.5 225.3 P8S24A P8S24CA 24 5 26.7 29.5 5 38.9 205.6 P8S26A P8S26CA 26 5 28.9 31.9 5 42.1 190.1 P8S28A P8S28CA 28 5 31.1 34.4 5 45.4 176.2 P8S30A P8S30CA 30 5 33.3 36.8 5 48.4 165.3 P8S33A P8S33CA 33 5 36.7 40.6 5 53.3 150.1 P8S36A P8S36CA 36 5 40.0 44.2 5 58.1 137.7 P8S40A P8S40CA 40 5 44.4 49.1 5 64.5 124.1 P8S43A P8S43CA 43 5 47.8 52.8 5 69.4 115.3 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR:Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR:Reverse Leakage Current RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) F IG .1:V - I cu rv e ch aracteristics (U n i-d ire ctio n al) F IG .2:V - I cu rv e ch aracteristics (B i-d irectio n al) IP P V V C V BR V R V C V BR V R VF V IR IT VR VBR VC I PP I PP Rev : 01.06.2014 IT IR 2/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform P PP derating in percentage(%) 100 IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 50 T A (℃ ) 75 100 125 150 175 SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) tp Critical Zone TL to TP Ramp-up tL TS(max) -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Temperature Pre Heat Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time MARKING & ORDERING INFORMATION P8S XX C A (1) (2) (3) (4) (1)Series:8000 watts series (2)Reverse Stand-off Voltage (3)Bi-directional (4)5% VBR Voltage tolerance Cathode Band Logo P8SxxCA Rev : 01.06.2014 Product Type 3/4 www.leiditech.com P8S Series 8000W Transient Voltage Suppressor PACKAGE MECHANICAL DATA Dimensions A B A Ref. Min. C D Millimeters Inches Max. Min. Max. - 25.40 - A 1.000 B 0.339 0.370 8.60 9.40 C 0.048 0.052 1.20 1.40 D 0.340 0.360 8.60 9.10 Part Number Case Type Quantity Packing Option P8SXXCA/A R6/P600 300 Box Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
P8S22CA
物料型号:P8S系列,包括P8S20A/CA至P8S43A/CA等型号。
器件简介:P8S系列瞬态电压抑制器设计用于交流线路保护和高功率直流总线钳位应用,提供20伏至43伏的单向/双向端口保护。
引脚分配:文档中未明确提供引脚分配信息,但提到了JEDEC R-6/P-600封装。
参数特性:包括低齐纳阻抗、优秀的钳位能力、高温焊接能力、快速响应时间等。
功能详解:这些器件能够提供比雪崩电压更低的钳位电压,从而将电压上升限制在最小,提供最佳保护。
应用信息:适用于高电流单向/双向瞬态电压抑制,可以串联和并联使用,以创建高容量保护解决方案。
封装信息:JEDEC R-6/P-600封装,文档还提供了焊接参数和标记与订购信息。
P8S22CA 价格&库存
很抱歉,暂时无法提供与“P8S22CA”相匹配的价格&库存,您可以联系我们找货
