SS12J
SS12J
    LGE(鲁光)
    SMAJ
    鲁光 SMAJ Io: 1A IR: 0.2mA VF: 0.55V
SS12J 数据手册
SS12J-SS110J Surface Mount Schottky Barrier Rectifiers REVERSE VOLTAGE: 20 - 100 V FORWARD CURRENT: 1.0 A SMAJ Features Schottky barrier rectifier 4.3± 0.1 Guardring protection Reverse energy tested 2.6± 0.15 1.70± 0.25 Low forward voltage High current capability Extremely low thermal resistance 5.6± 0.2 2.35± 0.1 Mechanical Data 1111 1.3± 0.2 Polarity: Color band denotes cathode end Mounting position: ANY 0.2± 0.05 0.203MAX Case: SMAJ molded plastic body Weight: 0.003 ounces, 0.084 grams Dimensions in millimeters MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25oC ambient temperature unless otherwise specified SS12J SS13J SS14J SS15J SS16J SS18J SS19J SS110J SS12 Device marking code SS13 SS14 SS15 SS16 UNITS SS18 SS19 S110 Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 V Maximum average forward rectified current at TL=90 IF(AV) 1.0 A Peak forward surge current 8.3ms single half-sine-wave IFSM 40 A Maximum instantaneous forward voltage at I FM=1.0A (NOTE1) VF Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range 0.85 0.2 IR R 0.70 0.55 0.5 6.0 JL 5.0 28 V mA o C/W TJ -55 ---- +125 o C TSTG -55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS12J-SS110J Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves 1.0 FIG.2-- PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,AMPERES CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE Resistive or inductive Load 0.5 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 0 50 60 70 80 90 100 110 120 130 140 150 160 170 40 20 0 LEAD TEMPERATURE SS12J-SS14J 10 SS18J-SS110J 0 .0 1 0 Pulse Width=300 1%DUTY CYCLE S SS15J-SS16J 0 .2 0 .4 0 .6 0 .8 1 .0 1 .2 1 .4 1 .6 INSTANTANEOUS FORWARD VOLTAGE,VOLTS 10 0 100 SS15J-SS110J 10 TJ=125℃ 1 SS12-SS14 SS18J-SS110J 0.1 T J=25℃ SS12J-SS16J 0.01 0.001 0 20 40 60 80 1 00 PERCENT OF RATED PEAK REVERSE VOLTAGE, PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 10 FIG.4 -- TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT,MICRO AMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 50 0 .1 1 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 1 O TL=100 C 8 .3 m s S in g le H a lf S in e -W a v e (J E D E C M e th o d ) www.lgesemi .c o m mail:lge@lgesemi.com
SS12J 价格&库存
很抱歉,暂时无法提供与“SS12J”相匹配的价格&库存,您可以联系我们找货
