SS110FA
SS110FA
    LGE(鲁光)
    SMAF
    鲁光 SMAF Io: 1A IR: 0.5mA VF: 0.85V
SS110FA 数据手册
SS12FA--SS120FA SURFACE MOUNT SCHOTTKY SMAF Cathode Band Top View FEATURES  Schottky barrier rectifier 0.110(2.80) 0.094(2.40) 0.059(1.50) 0.051(1.30)  Guarding protection 0.145(3.70) 0.128(3.25)  Low forward voltage  Reverse energy tested 0.012(0.30) 0.004(0.10) 0.059(1.50) 0.039(1.00)  High current capability  Extremely low thermal resistance 0.047(1.20) 0.028(0.60) MECHANICAL DATA  Case: SMAFL molded plastic body  Polarity: Color band denotes cathode end  Mounting position: ANY 0.190(4.85) 0.172(4.35) Maximum Ratings (@TA = 25°C unless otherwise specified) Characteristic Symbol SS12 FA SS12 Device marking code SS13 FA SS14 FA SS13 SS14 SS15 FA Dimensions in inches and (millimeters) SS16 FA SS16 SS15 SS18 FA SS18 SS19 FA SS19 SS110 SS115 SS120 FA FA FA UNITS SS110 SS115 SS120 Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 150 200 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 105 150 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 150 200 V Maximum average forward rectified current at TL=90℃ Peak forward surge current 8.3ms single half-sine-wave IF(AV) 1.0 A IFSM 40 A Thermal Characteristics Characteristic Symbol SS12 FA SS13 FA SS14 FA SS15 FA SS16 FA SS18 FA SS19 FA SS110 SS115 SS120 FA FA FA UNITS Maximum thermal resistance RθJL 28 ℃/W Operating temperature range TJ -55 ---- +150 ℃ TSTG --55 ---- +150 ℃ Storage temperature range Electrical Characteristics (@TA = 25°C unless otherwise specified) Characteristic Maximum instantaneous forward voltage at IFM=1.0A Maximum DC reverse current TJ=25℃ at rated DC blocking voltage TJ=125℃ Symbol SS12 FA 0.50 VF SS14 FA SS15 FA SS16 FA SS18 FA SS19 FA 0.70 6.0 www.lgesemi .c o m SS110 SS115 SS120 FA FA FA 0.85 0.2 IR ht t p : // Revision:20170701-P1 SS13 FA 0.5 5.0 UNITS V mA mail:lge@lgesemi.com SS12FA--SS120FA SURFACE MOUNT SCHOTTKY PACKAGE SMAF SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG 3000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SS110FA 价格&库存
很抱歉,暂时无法提供与“SS110FA”相匹配的价格&库存,您可以联系我们找货
