SS110B
SS110B
    LGE(鲁光)
    SMB(DO-214AA)
    鲁光 SMB Io: 1A IR: 0.5mA VF: 0.85V
SS110B 数据手册
SS12B-SS110B Surface Mount Schottky Barrier Rectifiers REVERSE VOLTAGE: 20 - 100 V FORWARD CURRENT: 1.0 A Features SMB/DO-214AA  Schottky barrier rectifier  Guardring protection  Low forward voltage  Reverse energy tested   High current capability Extremely low thermal resistance 0.180(4.57) 0.160(4.06) 0.086(2.20) 0.077(1.95) 0.155(3.94) 0.130(3.30) 0.209(5.30) 0.201(5.10) Mechanical Data 0.012(0.30) 0.006(0.15) 0.096(2.44) 0.084(2.13)  Case: SMB molded plastic body  Polarity: Color band denotes cathode end  Mounting position: ANY  Weight: 0.003 ounces, 0.093 gram 1111 0.059(1.50) 0.035(0.90) 0.008(0.20) 0.002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25oC ambient temperature unless otherwise specified SS12B SS13B SS14BSS15B SS16B SS18B SS19B SS110B UNITS Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 V Maximum average forward rectified current at TL=90 IF(AV) 1.0 A Peak forward surge current 8.3ms single half-sine-wave IFSM 40 A Maximum instantaneous forward voltage at I FM=1.0A (NOTE1) VF Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range 0.50 0.85 0.2 IR R 0.75 0.5 6.0 JL 5.0 28 V mA o C/W TJ -55 ---- +125 o C TSTG -55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS12B-SS110B Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves 1.0 FIG.2-- PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,AMPERES CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE Resistive or inductive Load 0.5 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 0 50 60 70 80 90 100 110 120 130 140 150 160 170 40 20 0 LEAD TEMPERATURE SS12B-SS14B 10 SS18B-SS110B 0 .0 1 0 Pulse Width=300 1%DUTY CYCLE S SS15B-SS16B 0 .2 0 .4 0 .6 0 .8 1 .0 1 .2 1 .4 1 .6 INSTANTANEOUS FORWARD VOLTAGE,VOLTS 10 0 100 SS15B-SS110B 10 TJ=125℃ 1 SS12B-SS14B SS18B-SS110B 0.1 T J=25℃ SS12B-SS16B 0.01 0.001 0 20 40 60 80 1 00 PERCENT OF RATED PEAK REVERSE VOLTAGE, PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMB 3000/REEL 48000 36X35.8X36.5 12.00 11.00 ht t p : // Revision:20170701-P1 10 FIG.4 -- TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT,MICRO AMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 50 0 .1 1 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 1 O TL=100 C 8 .3 m s S in g le H a lf S in e -W a v e (J E D E C M e th o d ) www.lgesemi .c o m mail:lge@lgesemi.com
SS110B 价格&库存
很抱歉,暂时无法提供与“SS110B”相匹配的价格&库存,您可以联系我们找货
