SS22A-SS220A
Surface Mount Schottky Barrier Rectifiers
REVERSE VOLTAGE: 20 - 200 V
FORWARD CURRENT: 2.0 A
Features
SMA/DO-214AC
Schottky barrier rectifier
Guardring protection
Low forward voltage
Reverse energy tested
High current capability
Extremely low thermal resistance
0. 181( 4. 60)
0. 161( 4. 10)
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
0. 209( 5. 30)
0. 193( 4. 90)
Mechanical Data
0. 012(0.30)
0. 006(0.15)
Case: SMA molded plastic body
1111
Polarity: Color band denotes cathode end
Mounting position: ANY
Weight: 0.002 ounces, 0.064 gram
0.096(2.45)
0.078(2.00)
0. 059( 1. 50)
0. 035( 0. 90)
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
o
Ratings at 25 C ambient
temperature unless otherwise specified
SS22A SS23A SS24A SS25A SS26A SS28A SS210A SS215A SS220A UNITS
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
150
200
V
Maximum average forward rectified current at
TL=90
IF(AV)
2.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
50
A
Maximum instantaneous forward voltage
at I FM=2.0A (NOTE1)
VF
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
IR
R
JL
0.50
0.75
0.03
0.4
10
5.0
28
V
0.85
mA
o
C/W
TJ
-55 ---- +125
o
C
TSTG
-55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS22A-SS220A
Ratings AND Charactieristic Curves
2.0
FIG.2-- PEAK FORWARD SURGE CURRENT
PEAK FORWARD SURGE
CURRENT,AMPERES
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
Resistive or
inductive Load
1.0
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
50
60
70 80
90 100 110 120 130 140 150 160 170
50
30
LEAD TEMPERATURE
10
10 0
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
1
SS
25
A~
SS
SS
26
A
28
A~
SS
22
0A
10
INSTANTANEOUS REVERSE
CURRENT,MICRO AMPERES
100
SS
22A
~S
S2
4A
INSTANTANEOUS FORWARD
CURRENT,AMPERES
1
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
0.1
0.01
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
.2
.3
.4
.5
.6
.7
.8
10
1.0
SS28A-SS210A
0.1
0.01
0.001
0.001
TJ=125℃
SS22A-SS26A
SS28A-SS210A
T J=25℃
SS22A-SS26A
60
80
1 00
.9
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
PERCENT OF RATED PEAK REVERSE VOLTAGE,
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
T L =100℃
8.3ms Single Half Sine-Wave
(JED E C M ethod)
40
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS26A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32152
- 100+0.25920
- 300+0.22799
- 1000+0.20466
- 5000+0.17820
- 10000+0.16881
