SS210A
SS210A
    LGE(鲁光)
    SMA(DO-214AC)
    鲁光 SMA Io: 2A IR: 0.03mA VF: 0.85V
SS210A 数据手册
SS22A-SS220A Surface Mount Schottky Barrier Rectifiers REVERSE VOLTAGE: 20 - 200 V FORWARD CURRENT: 2.0 A Features SMA/DO-214AC  Schottky barrier rectifier  Guardring protection  Low forward voltage  Reverse energy tested   High current capability Extremely low thermal resistance 0. 181( 4. 60) 0. 161( 4. 10) 0. 108( 2. 75) 0. 096( 2. 45) 0. 063(1.60) 0. 051(1.30) 0. 209( 5. 30) 0. 193( 4. 90) Mechanical Data 0. 012(0.30) 0. 006(0.15)  Case: SMA molded plastic body 1111  Polarity: Color band denotes cathode end  Mounting position: ANY  Weight: 0.002 ounces, 0.064 gram 0.096(2.45) 0.078(2.00) 0. 059( 1. 50) 0. 035( 0. 90) 0.008(0.20) 0. 002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS o Ratings at 25 C ambient temperature unless otherwise specified SS22A SS23A SS24A SS25A SS26A SS28A SS210A SS215A SS220A UNITS Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 100 150 200 V Maximum RMS voltage VRWS 14 21 28 35 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 100 150 200 V Maximum average forward rectified current at TL=90 IF(AV) 2.0 A Peak forward surge current 8.3ms single half-sine-wave IFSM 50 A Maximum instantaneous forward voltage at I FM=2.0A (NOTE1) VF Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range IR R JL 0.50 0.75 0.03 0.4 10 5.0 28 V 0.85 mA o C/W TJ -55 ---- +125 o C TSTG -55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS22A-SS220A Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves 2.0 FIG.2-- PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,AMPERES CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE Resistive or inductive Load 1.0 0 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 50 60 70 80 90 100 110 120 130 140 150 160 170 50 30 20 10 0 LEAD TEMPERATURE 10 10 0 FIG.4 -- TYPICAL REVERSE CHARACTERISTICS 1 SS 25 A~ SS SS 26 A 28 A~ SS 22 0A 10 INSTANTANEOUS REVERSE CURRENT,MICRO AMPERES 100 SS 22A ~S S2 4A INSTANTANEOUS FORWARD CURRENT,AMPERES 1 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 0.1 0.01 Tj=25oC Pulse Width=300 s 1% Duty Cycle .2 .3 .4 .5 .6 .7 .8 10 1.0 SS28A-SS210A 0.1 0.01 0.001 0.001 0 TJ=125℃ SS22A-SS26A SS28A-SS210A T J=25℃ SS22A-SS26A 20 40 60 80 1 00 .9 INSTANTANEOUS FORWARD VOLTAGE,VOLTS PERCENT OF RATED PEAK REVERSE VOLTAGE, PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 T L =100℃ 8.3ms Single Half Sine-Wave (JED E C M ethod) 40 www.lgesemi .c o m mail:lge@lgesemi.com
SS210A 价格&库存
很抱歉,暂时无法提供与“SS210A”相匹配的价格&库存,您可以联系我们找货
