SS220FA
SS220FA
    LGE(鲁光)
    SMAF
    鲁光 SMAF Io: 2A IR: 0.5mA VF: 0.85V
SS220FA 数据手册
SS22FA--SS220FA SURFACE MOUNT SCHOTTKY SMAF Cathode Band Top View FEATURES 0.110(2.80) 0.094(2.40)  Schottky barrier rectifier 0.059(1.50) 0.051(1.30)  Guarding protection 0.145(3.70) 0.128(3.25)  Low forward voltage 0.012(0.30) 0.004(0.10) 0.059(1.50) 0.039(1.00)  Reverse energy tested 0.047(1.20) 0.028(0.60) MECHANICAL DATA  Case: SMA molded plastic body 0.190(4.85) 0.172(4.35)  Polarity: Color band denotes cathode end  Mounting position: ANY Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. SS22 FA Device marking code SS23 SS24 FA FA SS25 SS26 FA FA SS28 FA SS29 SS210 SS215 SS220 FA FA FA FA UNITS SS22F SS23F SS24F SS25F SS26F SS28F SS29F SS210F SS215F SS220F Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 100 200 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 105 150 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 100 200 V Maximum average forward rectified current at TL=90℃ Peak forward surge current8.3ms single half-sine-wave Maximum instantaneous forward voltage @IFM=2.0A Maximum DC reverse current TA=25 ℃ at rated DC blocking voltage TA=100℃ IF(AV) 2.0 A IFSM 50 A VF 0.50 0.75 0.5 IR 10 0.85 V mA Maximum thermal resistance R θJL 17 ℃/W Operating temperature range TJ -55 ---- +125 ℃ TSTG -55 ---- +125 ℃ Storage temperature range NOTE: 1.Pulse test: Pulse width 300us, duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS22FA--SS220FA SURFACE MOUNT SCHOTTKY PACKAGE SMAF SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SS220FA 价格&库存
很抱歉,暂时无法提供与“SS220FA”相匹配的价格&库存,您可以联系我们找货
