74AUP1G373-Q100
Low-power D-type transparent latch; 3-state
Rev. 2 — 27 March 2020
Product data sheet
1. General description
The 74AUP1G373-Q100 provides the single D-type transparent latch with 3-state output. While
the latch-enable (LE) input is high, the Q output follows the data (D) input. When pin LE is LOW,
the latch stores the information that was present at the D-input one set-up time preceding the
HIGH-to-LOW transition of pin LE. When pin OE is LOW, the contents of the latch is available at
the (Q) output. When pin OE is HIGH, the output goes to the high-impedance OFF-state. Operation
of input pin OE does not affect the state of the latch. Schmitt trigger action at all inputs makes the
circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire VCC range
from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
• JESD8-12 (0.8 V to 1.3 V)
• JESD8-11 (0.9 V to 1.65 V)
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8-B (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 Class 3A. Exceeds 5000 V
• HBM JESD22-A114F Class 3A. Exceeds 5000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Low static power consumption; ICC = 0.9 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
74AUP1G373-Q100
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
74AUP1G373GW-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
4. Marking
Table 2. Marking
Type number
Marking code [1]
74AUP1G373GW-Q100
aW
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
D
3
D
1
LE
OE
6
Fig. 1.
Q
4
1
4
Q
LE
LE
EN
6
001aae247
OE
001aae248
Fig. 2.
Q
LE
C1
3
Logic symbol
D
IEC logic symbol
Fig. 3.
001aae249
Logic diagram
6. Pinning information
6.1. Pinning
74AUP1G373-Q100
LE
1
6
OE
GND
2
5
VCC
D
3
4
Q
aaa-009632
Fig. 4.
Pin configuration SOT363 (SC-88)
74AUP1G373_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 17
74AUP1G373-Q100
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
LE
1
latch enable input (active HIGH)
GND
2
ground (0 V)
D
3
data input
Q
4
latch output
VCC
5
supply voltage
OE
6
output enable input (active LOW)
7. Functional description
Table 4. Function table
H = HIGH voltage level; h = HIGH voltage level one setup time prior to the HIGH-to-LOW LE transition;
L = LOW voltage level; l = LOW voltage level one setup time prior to the HIGH-to-LOW LE transition;
X = Don’t care; Z = high-impedance OFF-state.
Operating modes
Internal latch Output
Input
OE
LE
D
Enable and read register (transparent mode) L
H
L
L
L
L
H
H
H
H
L
L
l
L
L
L
L
h
H
H
H
X
X
X
Z
Latch and read register
Latch register and disable outputs
Q
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
IGND
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
-50
-0.5
+4.6
V
±20
mA
supply current
50
mA
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
VI < 0 V
Min
[1]
Tamb = -40 °C to +125 °C
[1]
[2]
mA
V
mA
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT363 (SC-88) package: Ptot derates linearly with 3.7 mW/K above 83 °C.
74AUP1G373_Q100
Product data sheet
3 / 17
74AUP1G373-Q100
Nexperia
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.8
3.6
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Active mode
Power-down mode; VCC = 0 V
V
-40
+125
°C
200
ns/V
VCC = 0.8 V to 3.6 V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 × VCC
V
VCC = 0.9 V to 1.95 V
0.65 × VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75 × VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 × VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
74AUP1G373_Q100
Product data sheet
VI = VIH or VIL
IO = -20 μA; VCC = 0.8 V to 3.6 V
VI = VIH or VIL
4 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VO = 0 V to 3.6 V;
VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage
current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
ΔICC
additional supply
current
VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V
40
μA
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
output enabled; VO = GND; VCC = 0 V
1.7
pF
output disabled; VCC = 0 V to 3.6 V;
VO = GND or VCC
1.5
pF
VCC = 0.8 V
0.70 × VCC
V
0.65 × VCC
V
1.6
V
[1]
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
74AUP1G373_Q100
Product data sheet
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
0.7 × VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 × VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
VI = VIH or VIL
VI = VIH or VIL
5 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
II
±0.5
μA
IOZ
OFF-state output
current
VCC = 0 V to 3.6 V
±0.5
μA
IOFF
power-off leakage
current
±0.5
μA
ΔIOFF
leakage current
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
additional supply
current
50
μA
VCC = 0.8 V
0.75 × VCC
V
0.70 × VCC
V
1.6
V
[1]
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
74AUP1G373_Q100
Product data sheet
2.0
V
VCC = 0.8 V
0.25 × VCC
V
0.30 × VCC
V
0.7
V
0.9
V
VCC - 0.11
V
0.6 × VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 × VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
VI = VIH or VIL
VI = VIH or VIL
6 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
II
±0.75
μA
IOZ
OFF-state output
current
VCC = 0 V to 3.6 V
±0.75
μA
IOFF
power-off leakage
current
±0.75
μA
ΔIOFF
leakage current
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
additional supply
current
75
μA
[1]
[1]
One input at VCC - 0.6 V, other input at VCC or GND.
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
21.4
ns
VCC = 1.1 V to 1.3 V
2.8
6.6
13.5
2.6
13.8
2.6
15.2
ns
VCC = 1.4 V to 1.6 V
2.4
4.6
7.8
2.1
8.3
2.1
9.1
ns
VCC = 1.65 V to 1.95 V
1.9
3.7
6.2
1.6
6.7
1.6
7.3
ns
1.8
2.9
4.1
1.5
4.5
1.5
4.9
ns
1.5
2.5
3.5
1.2
4.0
1.2
4.5
ns
20.3
ns
2.7
6.2
13.6
2.5
14.0
2.5
15.4
ns
2.3
4.4
7.6
2.0
8.5
2.0
9.3
ns
1.8
3.5
5.8
1.5
6.7
1.5
7.3
ns
1.5
2.6
4.0
1.3
4.4
1.3
4.8
ns
1.3
2.2
3.3
1.1
3.8
1.1
4.2
ns
CL = 5 pF
tpd
propagation D to Q; see Fig. 5
delay
VCC = 0.8 V
[2]
LE to Q; see Fig. 6
[2]
VCC = 0.8 V
ten
enable time
OE to Q; see Fig. 8
VCC = 0.8 V
74AUP1G373_Q100
Product data sheet
[3]
17.9
ns
3.2
5.1
9.2
3.0
9.2
3.0
10.1
ns
2.6
3.8
5.8
2.4
6.1
2.4
6.7
ns
2.2
3.3
4.8
2.0
5.0
2.0
5.5
ns
2.0
2.7
3.8
1.8
4.0
1.8
4.4
ns
1.9
2.5
3.4
1.8
3.6
1.8
4.0
ns
7 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
tdis
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
9.4
ns
2.9
4.2
7.5
2.8
7.9
2.8
8.7
ns
2.2
3.2
4.9
2.1
5.3
2.1
5.8
ns
2.2
3.0
4.4
2.1
4.9
2.1
5.4
ns
1.6
2.2
3.1
1.5
3.4
1.5
3.7
ns
1.9
2.6
3.3
1.8
3.6
1.8
4.0
ns
24.4
ns
3.0
7.5
15.3
2.7
15.9
2.7
17.4
ns
2.6
5.3
9.0
2.2
9.4
2.2
10.3
ns
2.5
4.3
6.9
2.1
7.3
2.1
8.0
ns
2.0
3.5
4.8
1.8
5.3
1.8
5.9
ns
1.8
3.1
4.2
1.7
4.6
1.7
5.1
ns
23.3
ns
2.9
7.1
15.4
2.7
16.1
2.7
17.7
ns
2.5
5.0
8.8
2.1
9.5
2.1
10.4
ns
2.3
4.1
6.6
2.0
7.3
2.0
8.1
ns
1.9
3.1
4.7
1.6
5.2
1.6
5.8
ns
1.7
2.8
4.0
1.4
4.4
1.4
4.9
ns
21.2
ns
3.7
6.0
10.6
3.4
10.6
3.4
11.7
ns
3.1
4.5
6.7
2.8
7.0
2.8
7.7
ns
2.7
3.9
5.5
2.5
5.8
2.5
6.4
ns
2.4
3.3
4.5
2.2
4.7
2.2
5.2
ns
2.3
3.1
4.1
2.2
4.3
2.2
4.7
ns
disable time OE to Q; see Fig. 8
[4]
VCC = 0.8 V
CL = 10 pF
tpd
delay
VCC = 0.8 V
[2]
LE to Q; see Fig. 6
[2]
VCC = 0.8 V
ten
enable time
OE to Q; see Fig. 8
[3]
VCC = 0.8 V
tdis
VCC = 0.8 V
74AUP1G373_Q100
Product data sheet
[4]
11.3
ns
3.9
5.3
8.7
3.8
9.2
3.8
10.1
ns
3.0
4.1
5.8
2.9
6.2
2.9
6.8
ns
3.2
4.2
5.7
3.1
6.0
3.1
6.6
ns
2.3
3.0
4.0
2.2
4.3
2.2
4.7
ns
3.0
3.8
4.7
2.9
5.0
2.9
5.5
ns
8 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
27.3
ns
3.5
8.3
16.9
3.2
17.5
3.2
19.2
ns
3.1
5.9
9.6
2.7
10.5
2.7
11.6
ns
2.6
4.8
7.6
2.2
8.5
2.2
9.3
ns
2.5
3.9
5.5
2.2
5.9
2.2
6.5
ns
2.2
3.6
4.9
1.8
5.5
1.8
6.0
ns
26.1
ns
3.3
7.9
17.3
3.0
18.0
3.0
19.8
ns
3.0
5.6
9.7
2.5
10.7
2.5
11.8
ns
2.5
4.6
7.4
2.2
8.3
2.2
9.1
ns
2.3
3.6
5.3
2.0
5.9
2.0
6.4
ns
2.1
3.2
4.6
1.8
5.1
1.8
5.6
ns
24.6
ns
4.1
6.8
12.1
3.8
12.1
3.8
13.3
ns
3.5
5.1
7.5
3.2
7.9
3.2
8.7
ns
3.1
4.4
6.1
2.8
6.5
2.8
7.2
ns
2.8
3.7
5.0
2.5
5.3
2.5
5.8
ns
2.6
3.5
4.7
2.5
4.9
2.5
5.4
ns
13.1
ns
4.9
6.5
9.8
4.8
10.4
4.8
11.4
ns
3.9
5.0
6.8
3.8
7.3
3.8
8.0
ns
4.2
5.3
6.9
4.1
7.3
4.1
8.0
ns
3.0
3.8
4.8
2.9
5.1
2.9
5.6
ns
4.1
5.0
6.1
4.0
6.4
4.0
7.0
ns
CL = 15 pF
tpd
delay
VCC = 0.8 V
[2]
LE to Q; see Fig. 6
[2]
VCC = 0.8 V
ten
enable time
OE to Q; see Fig. 8
[3]
VCC = 0.8 V
tdis
VCC = 0.8 V
74AUP1G373_Q100
Product data sheet
[4]
9 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
35.9
ns
4.0
10.6
22.1
3.7
23.3
3.7
25.6
ns
3.6
7.5
12.3
3.5
13.6
3.5
15.0
ns
3.5
6.2
9.5
3.2
10.5
3.2
11.5
ns
3.3
5.1
6.9
2.9
7.6
2.9
8.3
ns
3.0
4.7
6.4
2.9
7.2
2.9
7.9
ns
34.8
ns
3.9
10.2
22.2
3.7
23.5
3.7
25.9
ns
3.5
7.2
12.4
3.4
13.7
3.4
15.1
ns
3.3
5.9
9.5
3.0
10.5
3.0
11.6
ns
3.1
4.8
6.8
2.7
7.5
2.7
8.2
ns
2.9
4.4
6.1
2.6
7.0
2.6
7.7
ns
34.5
ns
5.5
9.1
16.2
4.9
16.2
4.9
17.8
ns
4.6
6.7
9.9
4.2
10.5
4.2
11.6
ns
4.2
5.7
7.9
3.7
8.6
3.7
9.5
ns
3.6
4.9
6.4
3.4
6.9
3.4
7.6
ns
3.4
4.7
6.1
3.3
6.5
3.3
7.2
ns
19.2
ns
8.0
9.9
13.7
7.9
14.5
7.9
16.0
ns
6.3
7.7
9.7
6.2
10.5
6.2
11.6
ns
7.3
8.7
10.6
7.2
11.3
7.2
12.4
ns
5.2
6.2
7.5
5.1
7.8
5.1
8.6
ns
7.5
8.8
10.2
7.4
10.5
7.4
11.6
ns
VCC = 0.8 V
4.0
ns
0.7
2.1
2.1
ns
0.5
1.3
1.3
ns
0.4
1.0
1.0
ns
0.3
0.8
0.8
ns
0.2
0.8
0.8
ns
CL = 30 pF
tpd
delay
VCC = 0.8 V
[2]
LE to Q; see Fig. 6
[2]
VCC = 0.8 V
ten
enable time
OE to Q; see Fig. 8
[3]
VCC = 0.8 V
tdis
VCC = 0.8 V
[4]
CL = 5 pF, 10 pF, 15 pF and 30 pF
tW
pulse width
74AUP1G373_Q100
Product data sheet
LE HIGH; see Fig. 6
10 / 17
74AUP1G373-Q100
Nexperia
Symbol Parameter
tsu(H)
tsu(L)
th
CPD
set-up time
HIGH
set-up time
LOW
hold time
Conditions
25 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
VCC = 0.8 V
4.6
ns
0.9
2.2
2.2
ns
0.6
1.4
1.4
ns
0.4
1.0
1.0
ns
0.6
ns
-0.1
0.4
0.4
ns
VCC = 0.8 V
4.0
ns
1.2
2.7
2.7
ns
0.7
1.5
1.5
ns
0.6
1.2
1.2
ns
0.4
0.9
0.9
ns
0.3
0.7
0.7
ns
VCC = 0.8 V
-4.6
ns
-0.9
-0.1
-0.1
ns
-0.6
-0.1
-0.1
ns
-0.4
ns
-0.2
0.2
0.2
ns
-0.1
0.3
0.3
ns
D to LE; see Fig. 7
D to LE; see Fig. 7
D to LE HIGH or LOW;
see Fig. 7
fi = 1 MHz; VI = GND to VCC;
power
output enabled
dissipation
capacitance
V = 0.8 V
[5] [6]
2.0
pF
2.0
pF
2.0
pF
2.1
pF
2.4
pF
2.8
pF
CC
[1]
[2]
[3]
[4]
[5]
[6]
-40 °C to
+85 °C
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
All specified values are the average typical values over all stated loads.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
2
Σ(CL × VCC × fo) = sum of the outputs;
N = number of inputs switching.
74AUP1G373_Q100
Product data sheet
11 / 17
74AUP1G373-Q100
Nexperia
11.1. Waveforms
VI
VM
D input
GND
t PHL
t PLH
VOH
Q output
VM
VOL
001aae253
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5.
The data input (D) to output (Q) propagation delays
VI
LE input
VM
GND
tW
tPLH
tPHL
VOH
Q output
VM
VOL
001aae254
Fig. 6.
The latch enable input (LE) to output (Q) propagation delays, the latch enable input (LE) pulse width
VI
D input
VM
GND
VI
tsu
th
tsu
th
VM
LE input
GND
001aae255
Fig. 7.
Data set-up and hold times for the D input to the LE input
74AUP1G373_Q100
Product data sheet
12 / 17
74AUP1G373-Q100
Nexperia
VI
OE input
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
tPZH
VOH
output
HIGH-to-OFF
OFF-to-HIGH
VY
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
mna644
Fig. 8.
Turn-on and turn-off times
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VI
tr = tf
VM
VX
VY
0.8 V to 1.6 V
0.5 × VCC
VCC
≤ 3.0 ns
0.5 × VCC
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5 × VCC
VCC
≤ 3.0 ns
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5 × VCC
VCC
≤ 3.0 ns
0.5 × VCC
VOL + 0.3 V
VOH - 0.3 V
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 9.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Load
VCC
CL
0.8 V to 3.6 V
5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ
[1]
VEXT
RL [1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 × VCC
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1G373_Q100
Product data sheet
13 / 17
74AUP1G373-Q100
Nexperia
12. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig. 10. Package outline SOT363 (SC-88)
74AUP1G373_Q100
Product data sheet
14 / 17
74AUP1G373-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AUP1G373_Q100 v.2
20200327
Product data sheet
Modifications:
74AUP1G373_Q100 v.1
74AUP1G373_Q100
Product data sheet
74AUP1G373_Q100 v.1
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Table 5: Derating values for Ptot total power dissipation updated.
20140310
Product data sheet
15 / 17
74AUP1G373-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74AUP1G373_Q100
Product data sheet
16 / 17
74AUP1G373-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................7
11.1. Waveforms............................................................... 12
12. Package outline........................................................ 14
13. Abbreviations............................................................ 15
14. Revision history........................................................15
15. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 March 2020
74AUP1G373_Q100
Product data sheet
17 / 17
