SMBJ6.0A
SMBJ6.0A
    LEIDITECH(雷卯电子)
    SMB(DO-214AA)
    单向TVS 6V截止 峰值浪涌电流:58.3A
SMBJ6.0A 数据手册
SMBJ Series 600W 00W Transient Voltage Suppressor DESCRIPTION: TVS diodes iodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMB FEATURES:            Glass passivated or planar ar junction Excellent clamping capability Repetition rate (duty cycle): 0.01% Typical IR less than 1μA A above 10V. Low profile package and low ow inductance 600W 00W Peak Pulse power capability at 10×1000μs 10×1000 waveform. Fast response time: typically less than 1.0ps from 0V to VBR min. High temperature emperature soldering: 260℃/10s 260 at terminals. Plastic package has Underwriters Laboratory Flammability 94V-0. 94V For surface mounted applications in order to optimize board space AEC-Q101 qualified. Symbol ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs 10/1000 waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional Rev : 01.06.2014 1/6 Symbol Value Unit Tstg -55 to +125 ℃ Tj -55 to +125 ℃ PM(AV) 5.0 W PPP 600 W VF 5.0 V www.leiditech.com SMBJ Series 600W 00W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMBJ5.0A SMBJ5.0CA 5.0 100 6.40 7.00 10 9.2 65.2 SMBJ6.0A SMBJ6.0CA 6.0 100 6.67 7.37 10 10.3 58.3 SMBJ6.5A SMBJ6.5CA 6.5 50 7.22 7.98 10 11.2 53.6 SMBJ7.0A SMBJ7.0CA 7.0 50 7.78 8.60 10 12.0 50.0 SMBJ7.5A SMBJ7.5CA 7.5 50 8.33 9.21 1 12.9 46.5 SMBJ8.0A SMBJ8.0CA 8.0 20 8.89 9.83 1 13.6 44.1 SMBJ8.5A SMBJ8.5CA 8.5 10 9.44 10.40 1 14.4 41.7 SMBJ9.0A SMBJ9.0CA 9.0 5 10.00 11.10 1 15.4 39.0 SMBJ10A SMBJ10CA 10 2 11.10 12.30 1 17.0 35.3 SMBJ11A SMBJ11CA 11 1 12.20 13.50 1 18.2 33.0 SMBJ12A SMBJ12CA 12 1 13.30 14.70 1 19.9 30.2 SMBJ13A SMBJ13CA 13 1 14.40 15.90 1 21.5 27.9 SMBJ14A SMBJ14CA 14 1 15.60 17.20 1 23.2 25.9 SMBJ15A SMBJ15CA 15 1 16.70 18.50 1 24.4 24.6 SMBJ16A SMBJ16CA 16 1 17.80 19.70 1 26.0 23.1 SMBJ17A SMBJ17CA 17 1 18.90 20.90 1 27.6 21.8 SMBJ18A SMBJ18CA 18 1 20.00 22.10 1 29.2 20.6 SMBJ20A SMBJ20CA 20 1 22.20 24.50 1 32.4 18.6 SMBJ22A SMBJ22CA 22 1 24.40 26.90 1 35.5 16.9 SMBJ24A SMBJ24CA 24 1 26.70 29.50 1 38.9 15.4 SMBJ26A SMBJ26CA 26 1 28.90 31.90 1 42.1 14.3 SMBJ28A SMBJ28CA 28 1 31.10 34.40 1 45.4 13.2 SMBJ30A SMBJ30CA 30 1 33.30 36.80 1 48.4 12.4 SMBJ33A SMBJ33CA 33 1 36.70 40.60 1 53.3 11.3 SMBJ36A SMBJ36CA 36 1 40.00 44.20 1 58.1 10.4 SMBJ40A SMBJ40CA 40 1 44.40 49.10 1 64.5 9.3 SMBJ43A SMBJ43CA 43 1 47.80 52.80 1 69.4 8.7 SMBJ45A SMBJ45CA 45 1 50.00 55.30 1 72.7 8.3 SMBJ48A SMBJ48CA 48 1 53.30 58.90 1 77.4 7.8 SMBJ51A SMBJ51CA 51 1 56.70 62.70 1 82.4 7.3 Rev : 01.06.2014 2/6 www.leiditech.com SMBJ Series 600W 00W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMBJ54A SMBJ54CA 54 1 60.00 66.30 1 87.1 6.9 SMBJ58A SMBJ58CA 58 1 64.40 71.20 1 93.6 6.4 SMBJ60A SMBJ60CA 60 1 66.70 73.70 1 96.8 6.2 SMBJ64A SMBJ64CA 64 1 71.10 78.60 1 103.0 5.8 SMBJ70A SMBJ70CA 70 1 77.80 86.00 1 113.0 5.3 SMBJ75A SMBJ75CA 75 1 83.30 92.10 1 121.0 5.0 SMBJ78A SMBJ78CA 78 1 86.70 95.80 1 126.0 4.8 SMBJ85A SMBJ85CA 85 1 94.40 104.0 1 137.0 4.4 SMBJ90A SMBJ90CA 90 1 100.0 111.0 1 146.0 4.1 SMBJ100A SMBJ100CA 100 1 111.0 123.0 1 162.0 3.7 SMBJ110A SMBJ110CA 110 1 122.0 135.0 1 177.0 3.4 SMBJ120A SMBJ120CA 120 1 133.0 147.0 1 193.0 3.1 SMBJ130A SMBJ130CA 130 1 144.0 159.0 1 209.0 2.9 SMBJ150A SMBJ150CA 150 1 167.0 185.0 1 243.0 2.5 SMBJ160A SMBJ160CA 160 1 178.0 197.0 1 259.0 2.3 SMBJ170A SMBJ170CA 170 1 189.0 209.0 1 275.0 2.2 SMBJ180A SMBJ180CA 180 1 201.0 222.0 1 292.0 2.1 SMBJ190A SMBJ190CA 190 1 211.0 234.0 1 307.0 2.0 SMBJ200A SMBJ200CA 200 1 224.0 247.0 1 324.0 1.9 SMBJ210A SMBJ210CA 210 1 233.0 258.0 1 337.0 1.8 SMBJ220A SMBJ220CA 220 1 246.0 272.0 1 356.0 1.7 SMBJ250A SMBJ250CA 250 1 279.0 309.0 1 405.0 1.5 SMBJ300A SMBJ300CA 300 1 335.0 371.0 1 486.0 1.3 SMBJ350A SMBJ350CA 350 1 391.0 432.0 1 567.0 1.1 SMBJ400A SMBJ400CA 400 1 447.0 494.0 1 648.0 0.9 SMBJ440A SMBJ440CA 440 1 492.0 543.0 1 713.0 0.8 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev : 01.06.2014 3/6 www.leiditech.com SMBJ Series 600W 00W Transient Voltage Suppressor ORDERING INFORMATION RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V V C V BR V R IT IR V C V BR V R VF V IR IT V R V BR V C IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform P PP derating in percentage(%) 100 IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 80 Peak value 60 Half value 40 50 20 td 0 0 Rev : 01.06.2014 1.0 t(ms) 2.0 3.0 4.0 4/6 0 0 25 50 T A (℃ ) 75 100 125 150 175 www.leiditech.com SMBJ Series 600W 00W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition -Temperature Min (Ts(min)) tp -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow Critical Zone TL to TP Ramp-up -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Temperature Pre Heat FIG.5: Reflow condition +150℃ Ramp-down Preheat TS(min) 25 Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions B C Ref. H F G D E L J K Millimeters Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 L Rev : 01.06.2014 5/6 0.270 2.60 K DO-214AA (SMB) Inches 2.40 0.100 0.090 www.leiditech.com SMBJ Series 600W 00W Transient Voltage Suppressor TAPE AND REEL SPECIFICATION-SMB P0 P1 Cathode F E d Dimensions B W Ref. A P Millimeters Inches A 3.76 ± 0.2 0.144 ± 0.012 B 5.69 ± 0.2 0.244 ± 0.012 d 1.5 ± 0.25 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.75 ± 0.2 0.059 ± 0.008 F 5.5 ± 0.1 0.222 ± 0.008 P 8.0 ± 0.2 0.315 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.3 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) TAPING 3,000 48,000 330 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 6/6 www.leiditech.com
SMBJ6.0A
物料型号:Leiditech SMBJ系列
器件简介:瞬态电压抑制二极管(TVS)可用于多种应用,如消费电子产品、汽车工业、军火、电信、航天工业和智能控制系统。
引脚分配:双向TVS二极管的符号为Cathode和Anode,单向TVS二极管的符号为Cathode和Anode。
参数特性: - 玻璃钝化或平面结构结 - 优秀的钳位能力 - 重复率(占空比):0.01% - 典型IR小于10V时的1μA - 低轮廓封装和低电感 - 600W峰值脉冲功率能力在10×1000μs波形下 - 快速响应时间:从0V到VBR最小值通常小于1.0ps - 高温焊接:260℃/10s在端子上 - 塑料封装具有UL94V-0可燃性等级 - 符合AEC-Q101标准
功能详解:瞬态电压抑制二极管用于保护电子设备免受电压瞬变的影响,如静电放电、电源浪涌等。
应用信息:适用于需要电压保护的各种电子设备和系统。
封装信息:提供DO-214AA(SMB)封装,具体尺寸和机械数据在文档中有详细描述。
电气特性表提供了不同型号的瞬态电压抑制二极管在25℃环境下的电气参数,包括VR(稳定电压)、IR@VR(在VR时的反向漏电流)、VBR@IT(在IT时的击穿电压)、Vc@lpp max(在lpp1时的最大钳位电压)和lpp1(脉冲电流)。
订购信息和焊接参数也在文档中给出,包括焊接条件和峰值温度等信息。
SMBJ6.0A 价格&库存
很抱歉,暂时无法提供与“SMBJ6.0A”相匹配的价格&库存,您可以联系我们找货
SMBJ6.0A
  • 10+0.46228
  • 100+0.37371
  • 300+0.32941
  • 3000+0.26488
  • 6000+0.23836
  • 9000+0.22505
库存:19067
