SMCJ9.0A
SMCJ9.0A
    LEIDITECH(雷卯电子)
    SMC(DO-214AB)
    雷卯 DO-214AB 1500W 9V
SMCJ9.0A 数据手册
SMCJ Series 1500W Transient Voltage Suppressor DESCRIPTION TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMC FEATURES Low profile package. Low inductance. Excellent clamping capability. 1500W peak pulse power capability at 10×1000μs waveform Typical IR less than 1μA above 10V. Fast response time: typically less than 1.0ps from 0V to VBR min. High temperature to reflow soldering: 260℃/40s at terminals. Plastic package has underwriters laboratory flammability 94V-0. Meets MSL level 1, per J-STD020, LF maximum peak of 260℃. For surface mounted applications in order to optimize board space.  AEC-Q101 qualified. Symbol ABSOLUTE MAXIMUM RATINGS (TA=25℃, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=50℃ Peak pulse power dissipation on 10/1000μs waveform Maximum instantaneous forward voltage at 100A for unidirectional Rev : 01.06.2015 1/6 Symbol Value Unit Tstg -60 to +150 ℃ Tj -40 to +150 ℃ PM(AV) 6.5 W PPP 1500 W VF 5.0 V www.leiditech.com SMCJ Series 1500W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMCJ5.0A SMCJ5.0CA 5.0 300 6.40 7.00 10 9.2 163.0 SMCJ6.0A SMCJ6.0CA 6.0 250 6.67 7.37 10 10.3 145.6 SMCJ6.5A SMCJ6.5CA 6.5 150 7.22 7.98 10 11.2 134.0 SMCJ7.0A SMCJ7.0CA 7.0 100 7.78 8.60 10 12.0 125.0 SMCJ7.5A SMCJ7.5CA 7.5 50 8.33 9.21 1 12.9 116.3 SMCJ8.0A SMCJ8.0CA 8.0 30 8.89 9.83 1 13.6 110.3 SMCJ8.5A SMCJ8.5CA 8.5 20 9.44 10.40 1 14.4 104.2 SMCJ9.0A SMCJ9.0CA 9.0 10 10.00 11.10 1 15.4 97.4 SMCJ10A SMCJ10CA 10 5 11.10 12.30 1 17.0 88.2 SMCJ11A SMCJ11CA 11 2 12.20 13.50 1 18.2 82.4 SMCJ12A SMCJ12CA 12 1 13.30 14.70 1 19.9 75.4 SMCJ13A SMCJ13CA 13 1 14.40 15.90 1 21.5 69.8 SMCJ14A SMCJ14CA 14 1 15.60 17.20 1 23.2 64.7 SMCJ15A SMCJ15CA 15 1 16.70 18.50 1 24.4 61.5 SMCJ16A SMCJ16CA 16 1 17.80 19.70 1 26.0 57.7 SMCJ17A SMCJ17CA 17 1 18.90 20.90 1 27.6 54.4 SMCJ18A SMCJ18CA 18 1 20.00 22.10 1 29.2 51.4 SMCJ20A SMCJ20CA 20 1 22.20 24.50 1 32.4 46.3 SMCJ22A SMCJ22CA 22 1 24.40 26.90 1 35.5 42.3 SMCJ24A SMCJ24CA 24 1 26.70 29.50 1 38.9 38.6 SMCJ26A SMCJ26CA 26 1 28.90 31.90 1 42.1 35.6 SMCJ28A SMCJ28CA 28 1 31.10 34.40 1 45.4 33.1 SMCJ30A SMCJ30CA 30 1 33.30 36.80 1 48.4 31.0 SMCJ33A SMCJ33CA 33 1 36.70 40.60 1 53.3 28.2 SMCJ36A SMCJ36CA 36 1 40.00 44.20 1 58.1 25.8 SMCJ40A SMCJ40CA 40 1 44.40 49.10 1 64.5 23.3 SMCJ43A SMCJ43CA 43 1 47.80 52.80 1 69.4 21.6 SMCJ45A SMCJ45CA 45 1 50.00 55.30 1 72.7 20.6 SMCJ48A SMCJ48CA 48 1 53.30 58.90 1 77.4 19.4 SMCJ51A SMCJ51CA 51 1 56.70 62.70 1 82.4 18.2 Rev : 01.06.2015 2/6 www.leiditech.com SMCJ Series 1500W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃,continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMCJ54A SMCJ54CA 54 1 60.00 66.30 1 87.1 17.2 SMCJ58A SMCJ58CA 58 1 64.40 71.20 1 93.6 16.1 SMCJ60A SMCJ60CA 60 1 66.70 73.70 1 96.8 15.5 SMCJ64A SMCJ64CA 64 1 71.10 78.60 1 103.0 14.6 SMCJ70A SMCJ70CA 70 1 77.80 86.00 1 113.0 13.3 SMCJ75A SMCJ75CA 75 1 83.30 92.10 1 121.0 12.4 SMCJ78A SMCJ78CA 78 1 86.70 95.80 1 126.0 11.9 SMCJ85A SMCJ85CA 85 1 94.40 104.0 1 137.0 11.0 SMCJ90A SMCJ90CA 90 1 100.0 111.0 1 146.0 10.3 SMCJ100A SMCJ100CA 100 1 111.0 123.0 1 162.0 9.3 SMCJ110A SMCJ110CA 110 1 122.0 135.0 1 177.0 8.5 SMCJ120A SMCJ120CA 120 1 133.0 147.0 1 193.0 7.8 SMCJ130A SMCJ130CA 130 1 144.0 159.0 1 209.0 7.2 SMCJ150A SMCJ150CA 150 1 167.0 185.0 1 243.0 6.2 SMCJ160A SMCJ160CA 160 1 178.0 197.0 1 259.0 5.8 SMCJ170A SMCJ170CA 170 1 189.0 209.0 1 275.0 5.5 SMCJ180A SMCJ180CA 180 1 201.0 222.0 1 292.0 5.2 SMCJ190A SMCJ190CA 190 1 211.0 234.0 1 307.0 4.9 SMCJ200A SMCJ200CA 200 1 224.0 247.0 1 324.0 4.7 SMCJ210A SMCJ210CA 210 1 233.0 258.0 1 337.0 4.5 SMCJ220A SMCJ220CA 220 1 246.0 272.0 1 356.0 4.2 SMCJ250A SMCJ250CA 250 1 279.0 309.0 1 405.0 3.7 SMCJ300A SMCJ300CA 300 1 335.0 371.0 1 486.0 3.1 SMCJ350A SMCJ350CA 350 1 391.0 432.0 1 567.0 2.7 SMCJ400A SMCJ400CA 400 1 447.0 494.0 1 648.0 2.3 SMCJ440A SMCJ440CA 440 1 492.0 543.0 1 713.0 2.1 ① Surge waveform: 10/1000μs VR: Stand-off voltage -- maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current Rev : 01.06.2015 3/6 www.leiditech.com SMCJ Series 1500W Transient Voltage Suppressor ORDERING INFORMATION SMCJ xx C A 5% VBR Voltage tolerance 1500W SMC Series C: Bi-directional VR Voltage RATINGS AND V-I CHARACTERISTICS CURVES (TA=25℃, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR VC VBR VR VF V IR IT VR VBR VC IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 IT IR 80 Peak value 60 Half value 40 50 20 td 0 0 Rev : 01.06.2015 1.0 t(ms) 2.0 3.0 0 0 4.0 4/6 25 50 TA (℃ ) 75 100 125 150 175 www.leiditech.com SMCJ Series 1500W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see figure at right) Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. tp TP Average ramp up rate (Liquidus Temp (TL)to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow Reflow condition Critical Zone TL to TP Ramp-up TL -Temperature(TL)(Liquidus) +217℃ -Temperature(tL) 60-150 secs. tL TS(max) Temperature Reflow Condition Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 20-40secs. Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA B Dimensions H F A C Ref. D K J L J G E Millimeters Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 L Rev : 01.06.2015 5/6 0.094 4.20 K DO-214AB (SMC) Inches 3.30 0.165 0.130 www.leiditech.com SMCJ Series 1500W Transient Voltage Suppressor TAPE AND REEL SPECIFICATION-SMC P0 P1 Cathode F E d Dimensions B W Ref. A P Millimeters Inches A 6.05 ± 0.3 0.238 ± 0.012 B 8.31 ± 0.3 0.327 ± 0.012 d 1.55 ± 0.1 0.061 ± 0.004 D 330.0 13.0 D2 13.3 ± 0.3 0.524 ± 0.012 E 1.75 ± 0.2 0.069 ± 0.008 F 7.50 ± 0.2 0.295 ± 0.008 P 8.00 ± 0.2 0.3145 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 PART No. PACKAGE QUANTITY TAPE & REEL SMCJxxCA/A SMC(DO-214AB) 3,000 13inch Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 6/6 www.leiditech.com
SMCJ9.0A
物料型号:SMCJ系列,包括不同额定电压的型号,如SMCJ5.0A、SMCJ6.0A等,直到SMCJ440A。
器件简介:瞬态电压抑制二极管(TVS)可广泛应用于消费电子产品、汽车工业、军火、电信、航天工业和智能控制系统。
引脚分配:文档中未明确提供引脚分配图,但通常这类器件为表面贴装(SMD)形式,具有两个引脚。
参数特性: - 低轮廓封装 - 低电感 - 优秀的钳位能力 - 10×1000μs波形下1500W的峰值脉冲功率能力 - 典型反向漏电流小于1μA(在10V以上) - 快速响应时间:从0V到VBR最小值通常小于1.0ps - 高温度下的回流焊接能力:260℃/40s在端子上 - 塑料封装符合UL94V-0可燃性等级 - 符合J-STD020的MSL等级1,LF最大峰值为260℃ - 适用于表面贴装应用,以优化板空间 - 通过AEC-Q101认证
功能详解:瞬态电压抑制二极管用于保护电子设备免受电压瞬变的影响,如静电放电(ESD)、电快速瞬变(EFT)等。
应用信息:适用于多种应用领域,包括消费电子、汽车、电信等,以保护敏感电子设备。
封装信息:DO-214AB(SMC)封装,提供了详细的尺寸数据和机械规格。
SMCJ9.0A 价格&库存
很抱歉,暂时无法提供与“SMCJ9.0A”相匹配的价格&库存,您可以联系我们找货
SMCJ9.0A
    • 3000+0.66000
    库存:50000
