SMDJ5.0A
SMDJ5.0A
    LEIDITECH(雷卯电子)
    SMC(DO-214AB)
    雷卯 DO-214AB 3000W 5V
SMDJ5.0A 数据手册
SMDJ Series 3000W Transient Voltage Suppressor DESCRIPTION: TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMC FEATURES:  Glass passivated or planar junction.           Excellent clamping capability. Repetition rate (duty cycle): 0.01%. Typical IR less than 1μA above 10V. Low profile package and low inductance. 3000W peak pulse power capability at 10×1000μs waveform. Fast response time: typically less than 1.0ps from 0V to VBR min. High temperature soldering: 260℃/10s at terminals. Plastic package has Underwriters Laboratory Flammability 94V-0. For surface mounted applications in order to optimize board space. AEC-Q101 qualified. Symbol ABSOLUTE MAXIMUM RATINGS (TA=25℃, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum instantaneous forward voltage at 80A for unidirectional Rev : 01.06.2015 1/6 Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +125 ℃ PM(AV) 8.0 W PPP 3000 W VF 5.0 V www.leiditech.com SMDJ Series 3000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (T Part Number =25℃) VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMDJ5.0A SMDJ5.0CA 5.0 800 6.40 7.00 10 9.2 326.1 SMDJ6.0A SMDJ6.0CA 6.0 800 6.67 7.37 10 10.3 291.3 SMDJ6.5A SMDJ6.5CA 6.5 500 7.22 7.98 10 11.2 267.9 SMDJ7.0A SMDJ7.0CA 7.0 200 7.78 8.60 10 12.0 250.0 SMDJ7.5A SMDJ7.5CA 7.5 100 8.33 9.21 1 12.9 232.6 SMDJ8.0A SMDJ8.0CA 8.0 50 8.89 9.83 1 13.6 220.6 SMDJ8.5A SMDJ8.5CA 8.5 20 9.44 10.40 1 14.4 208.3 SMDJ9.0A SMDJ9.0CA 9.0 10 10.00 11.10 1 15.4 194.8 SMDJ10A SMDJ10CA 10 5 11.10 12.30 1 17.0 176.5 SMDJ11A SMDJ11CA 11 1 12.20 13.50 1 18.2 164.8 SMDJ12A SMDJ12CA 12 1 13.30 14.70 1 19.9 150.8 SMDJ13A SMDJ13CA 13 1 14.40 15.90 1 21.5 139.5 SMDJ14A SMDJ14CA 14 1 15.60 17.20 1 23.2 129.3 SMDJ15A SMDJ15CA 15 1 16.70 18.50 1 24.4 123.0 SMDJ16A SMDJ16CA 16 1 17.80 19.70 1 26.0 115.4 SMDJ17A SMDJ17CA 17 1 18.90 20.90 1 27.6 108.7 SMDJ18A SMDJ18CA 18 1 20.00 22.10 1 29.2 102.7 SMDJ20A SMDJ20CA 20 1 22.20 24.50 1 32.4 92.6 SMDJ22A SMDJ22CA 22 1 24.40 26.90 1 35.5 84.5 SMDJ24A SMDJ24CA 24 1 26.70 29.50 1 38.9 77.1 SMDJ26A SMDJ26CA 26 1 28.90 31.90 1 42.1 71.3 SMDJ28A SMDJ28CA 28 1 31.10 34.40 1 45.4 66.1 SMDJ30A SMDJ30CA 30 1 33.30 36.80 1 48.4 62.0 SMDJ33A SMDJ33CA 33 1 36.70 40.60 1 53.3 56.3 SMDJ36A SMDJ36CA 36 1 40.00 44.20 1 58.1 51.6 SMDJ40A SMDJ40CA 40 1 44.40 49.10 1 64.5 46.5 SMDJ43A SMDJ43CA 43 1 47.80 52.80 1 69.4 43.2 SMDJ45A SMDJ45CA 45 1 50.00 55.30 1 72.7 41.3 SMDJ48A SMDJ48CA 48 1 53.30 58.90 1 77.4 38.8 SMDJ51A SMDJ51CA 51 1 56.70 62.70 1 82.4 36.4 Rev : 01.06.2015 2/6 www.leiditech.com SMDJ Series 3000W Transient Voltage Suppressor ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A SMDJ54A SMDJ54CA 54 1 60.00 66.30 1 87.1 34.4 SMDJ58A SMDJ58CA 58 1 64.40 71.20 1 93.6 32.1 SMDJ60A SMDJ60CA 60 1 66.70 73.70 1 96.8 31.0 SMDJ64A SMDJ64CA 64 1 71.10 78.60 1 103.0 29.1 SMDJ70A SMDJ70CA 70 1 77.80 86.00 1 113.0 26.5 SMDJ75A SMDJ75CA 75 1 83.30 92.10 1 121.0 24.8 SMDJ78A SMDJ78CA 78 1 86.70 95.80 1 126.0 23.8 SMDJ85A SMDJ85CA 85 1 94.40 104.0 1 137.0 21.9 SMDJ90A SMDJ90CA 90 1 100.0 111.0 1 146.0 20.5 SMDJ100A SMDJ100CA 100 1 111.0 123.0 1 162.0 18.5 SMDJ110A SMDJ110CA 110 1 122.0 135.0 1 177.0 16.9 SMDJ120A SMDJ120CA 120 1 133.0 147.0 1 193.0 15.5 SMDJ130A SMDJ130CA 130 1 144.0 159.0 1 209.0 14.4 SMDJ150A SMDJ150CA 150 1 167.0 185.0 1 243.0 12.3 SMDJ160A SMDJ160CA 160 1 178.0 197.0 1 259.0 11.6 SMDJ170A SMDJ170CA 170 1 189.0 209.0 1 275.0 10.9 SMDJ180A SMDJ180CA 180 1 201.0 222.0 1 292.0 10.3 SMDJ190A SMDJ190CA 190 1 211.0 234.0 1 307.0 9.7 SMDJ200A SMDJ200CA 200 1 224.0 247.0 1 324.0 9.3 SMDJ210A SMDJ210CA 210 1 233.0 258.0 1 337.0 8.8 SMDJ220A SMDJ220CA 220 1 246.0 272.0 1 356.0 8.4 ① Surge waveform: 10/1000μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current Rev : 01.06.2015 3/6 www.leiditech.com SMDJ Series 3000W Transient Voltage Suppressor ORDERING INFORMATION SMDJ xx C A 3000W SMC Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional RATINGS AND V-I CHARACTERISTICS CURVES (TA=25℃, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR VC VBR VR VF V IR IT VR VBR VC IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 IT IR 80 Peak value 60 Half value 40 50 20 td 0 0 Rev : 01.06.2015 1.0 t(ms) 2.0 3.0 0 0 4.0 4/6 25 50 TA(℃) 75 100 125 150 175 www.leiditech.com SMDJ Series 3000W Transient Voltage Suppressor SOLDERING PARAMETERS Pb-Free assembly (see FIG.5) Reflow Condition -Temperature Min (Ts(min)) tp -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL tL TS(max) Average ramp up rate (Liquid us Temp (TL)to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow Critical Zone TL to TP Ramp-up Temperature Pre Heat FIG.5: Reflow condition +150℃ Ramp-down Preheat TS(min) 25 -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ ts time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA B Dimensions H F A C Ref. D K J L J G E Millimeters Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 L Rev : 01.06.2015 5/6 0.094 4.20 K DO-214AB (SMC) Inches 3.30 0.165 0.130 www.leiditech.com SMDJ Series 3000W Transient Voltage Suppressor TAPE AND REEL SPECIFICATION-SMC P0 P1 Cathode F E d Dimensions B W Ref. A P Millimeters Inches A 6.05 ± 0.3 0.238 ± 0.012 B 8.31 ± 0.3 0.327 ± 0.012 d 1.55 ± 0.1 0.061 ± 0.004 D 330.0 13.0 D2 13.3 ± 0.3 0.524 ± 0.012 E 1.75 ± 0.2 0.069 ± 0.008 F 7.50 ± 0.2 0.295 ± 0.008 P 8.00 ± 0.2 0.3145 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 2.00 ± 0.2 0.079 ± 0.008 W 16.0 ± 0.2 0.630 ± 0.008 W1 19.7 ± 2.0 0.776 ± 0.079 PART No. PACKAGE QUANTITY TAPE & REEL SMDJxxCA/A SMC(DO-214AB) 3,000 13 inch Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 6/6 www.leiditech.com
SMDJ5.0A
物料型号:SMDJ系列,包括SMDJ5.0A至SMDJ220A等不同型号。
器件简介:该系列TVS二极管适用于消费电子产品、汽车工业、军火、电信、航天工业和智能控制系统等多种应用领域。
引脚分配:文档中提供了双向和单向TVS的符号,但未明确指出具体的引脚分配
参数特性: - 玻璃钝化或平面结构。 - 优秀的钳位能力。 - 重复率(占空比):0.01%。 - 典型反向漏电流小于1μA(10V以上)。 - 低轮廓封装和低电感。 - 10×1000μs波形下的3000W峰值脉冲功率能力。 - 快速响应时间:从0V到VBR最小值的典型时间小于1.0ps。 - 高温焊接:260℃/10s在端子上。 - 塑料封装符合UL可燃性94V-0标准。 - 符合AEC-Q101认证。
功能详解:TVS二极管用于保护电子设备免受电压瞬变的影响,如ESD(静电放电)、EFT(电快速瞬变)等。
应用信息:适用于需要电压保护的各种电子设备和系统中。
封装信息:提供DO-214AB(SMC)封装,详细尺寸和机械数据在文档中有描述。
SMDJ5.0A 价格&库存
很抱歉,暂时无法提供与“SMDJ5.0A”相匹配的价格&库存,您可以联系我们找货
