SS315- SS320
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 200 Volts
Forward Current - 3.0 Amperes
SMC/DO-214AB
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction Low
power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
Mechanical Data
Case: JEDEC DO-214ABmolded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS
SS315
SS320
UNITS
VRRM
VRMS
VDC
150
105
150
200
140
200
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amps
IFSM
100.0
Amps
VF
0.84
Volts
IR
1.0
10
mA
CJ
RqJA
TJ,
TSTG
300
62.0
-65 to +150
-65 to +150
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
SS315-SS320
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
0.6
50
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
£PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CUR VES SS320
75
100
125
150
80
60
40
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
100
NUMBER OF CYCLES AT 60 Hz
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
1,000
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
TJ=25 C
CURRENT,AMPERES
10.0
1
0.1
100
10
TJ=75 C
1
0.1
TJ=25 C
0.01
0.01
0.4
0.6
0.8
1.0
1.2
1.4
TJ=100 C
60
80
200
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
1000
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
TJ=25 C
100
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
ht t p : //
200
t,PULSE DURATION,sec.
www.lgesem i .c o m
很抱歉,暂时无法提供与“SS320”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55005
- 50+0.44637
- 150+0.39453
- 500+0.35565
- 3000+0.29646
- 6000+0.28091
- 国内价格
- 1+0.48730
- 200+0.31460
- 1500+0.27390
- 3000+0.24200
- 国内价格
- 10+0.50421
- 100+0.40917
- 600+0.32601
- 1200+0.32112
- 3000+0.27176
