SS58
SS58
    LGE(鲁光)
    SMC(DO-214AB)
    电压:80V 电流:5A
SS58 数据手册
SS52-SS520 Surface Mount Schottky Barrier Rectifiers SMC/DO-214AB Features   Plastic package has Underwriters Laborator Flammability Classification 94V-0  For surface mounted applications  Low profile package  Built-in strain relief  Metal silicon junction, majority carrier conduction  High surge capability  High current capability,low forward voltage drop  Low power loss,high effciency   For use in low voltage high frequency inverters,free wheeling and polarity protection applications Guardring for overvoltage protection  High temperature soldering guaranteed:250oC/10 1 seconds at terminals  Dimensions in inches and (millimeters) Mechanical Data   Case:JEDEC SMC,molded plastic over 1111passivated chip Polarity: Color band denotes cathode end  Weight: 0.007 ounces, 0.21 gram MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25oC ambient temperature unless otherwise specified SS52 SS53 SS54 SS55 SS56 SS58 SS59 SS510 SS520 UNITS 50 60 80 28 35 42 56 40 50 60 80 100 200 V 63 70 100 140 200 V 90 VRRM 20 30 Maximum RMS voltage VRWS 14 21 Maximum DC blocking voltage VDC 20 30 Maximum average forw ord rectified current at c TL(SEE FIG.1) (NOTE 2) I(AV) 5.0 A Peak forw ard surge current 8.3ms single halfc sine-w ave superimposed on rated load(JEDEC c Method) IFSM 175 A Maximum instantaneous forw ard voltage at v 5.0A(NOTE.1) at rated DC blockjing voltage(NOTE1) @TA=100oC Typical thermal resitance (NOTE2) Operating junction temperature range Storage temperature range 0.70 0.55 VF Maximum DC reverse current @TA=25oC 40 90 Maximum recurrent peak reverse voltage 20 10 RθJA 55 RθJL 17 V 0.85 0.5 IR V mA o C/W TJ -55--- +150 o TSTG -55--- +150 o C C NOTE: 1.Pulse test:300μS pulse width,1%duty cy cle 2. P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm 2)copper pad areas ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS52-SS520 Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves FIG.2-- PEAK FORWARD SURGE CURRENT 175 5.0 Resistive or inductive Load PEAK FORWARD SURGE CURRENT,AMPERES AVERAGE FORWARD RECTIFIED CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE 2.5 0 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 50 60 70 80 90 100 110 120 130 140 150 160 170 140 8.3ms Single Half Sine Wave TJ=125 105 70 35 0 1 AMBIENT TEMPERATURE ℃ NUMBER OF CYCLES AT 60HZ FIG.4 -- TYPICAL REVERSE CHARACTERISTICS FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 10 20 10 SS52-SS54 SS58-SS520 SS55-SS56 1 TJ =25 Pulse width=300 s 1% duty Cycle .1 .1 .3 .5 .7 .9 1.1 1.3 1.5 1.7 1.9 2.1 INSTANTANEOUS REVERSE CURRENT,MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 100 10 5.0 .5 .1 .05 TJ = 25 .01 0 INSTANTANEOUS FORWARD VOLTAGE,VOLTS 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,% PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMC 3000/REEL 42000 36X36X36.5 18.50 15.50 ht t p : // Revision:20170701-P1 TJ = 125 1.0 www.lgesemi .c o m mail:lge@lgesemi.com
很抱歉,暂时无法提供与“SS58”相匹配的价格&库存,您可以联系我们找货
SS58
  • 5+0.57902
  • 50+0.45772
  • 150+0.39707
  • 500+0.35158
  • 3000+0.31522
  • 6000+0.29695
库存:1899
