74AUP1G74DC-Q100H
74AUP1G74DC-Q100H
    NEXPERIA(安世)
    VSSOP-8
    低功率D型触发器,具有设置和复位功能;正边缘触发器
74AUP1G74DC-Q100H 数据手册
74AUP1G74-Q100 Low-power D-type flip-flop with set and reset; positive-edge trigger Rev. 2 — 10 April 2017 1 Product data sheet General description The 74AUP1G74-Q100 provides a low-power, low-voltage single positive-edge triggered D-type flip-flop with individual data (D), clock (CP), set (SD) and reset (RD) inputs and complementary Q and Q outputs. The SD and RD are asynchronous active LOW inputs and operate independently of the clock input. Information on the data input is transferred to the Q output on the LOW-to-HIGH transition of the clock pulse. The D input must be stable one set-up time prior to the LOW-to-HIGH clock transition for predictable operation. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2 Features and benefits • Automotive product qualification in accordance with AEC-Q100 (Grade 1) – Specified from -40 °C to +85 °C and from -40 °C to +125 °C • Wide supply voltage range from 0.8 V to 3.6 V • High noise immunity • Complies with JEDEC standards: – JESD8-12 (0.8 V to 1.3 V) – JESD8-11 (0.9 V to 1.65 V) – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-B (2.7 V to 3.6 V) • ESD protection: – MIL-STD-883, method 3015 Class 3A. Exceeds 5000 V – HBM JESD22-A114F Class 3A. Exceeds 5 000 V – MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) • Low static power consumption; ICC = 0.9 μA (maximum) • Latch-up performance exceeds 100 mA per JESD 78 Class II • Inputs accept voltages up to 3.6 V • Low noise overshoot and undershoot < 10 % of VCC • IOFF circuitry provides partial power-down mode operation 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1G74DC-Q100 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm 4 Marking Table 2. Marking codes Type number Marking code 74AUP1G74DC-Q100 p74 [1] 5 SOT765-1 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Functional diagram SD D CP SD Q D CP Q S FF Q C1 Q 1D RD RD R 001aah725 001aah726 Figure 1. Logic symbol Figure 2. IEC logic symbol Q C C C C D RD Q C C SD CP 001aae087 C C Figure 3. Logic diagram 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 6 Pinning information 6.1 Pinning 74AUP1G74-Q100 CP 1 8 VCC D 2 7 SD Q 3 6 RD GND 4 5 Q aaa-018153 Figure 4. Pin configuration SOT765-1 6.2 Pin description Table 3. Pin description Symbol Pin Description CP 1 clock input D 2 data input Q 3 complement output GND 4 ground (0 V) Q 5 true output RD 6 asynchronous reset input (active LOW) SD 7 asynchronous set input (active LOW) VCC 8 supply voltage 7 Functional description Table 4. Function table for asynchronous operation [1] Input Output SD RD CP D Q Q L H X X H L H L X X L H L L X X H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Table 5. Function table for synchronous operation [1] Input Output SD RD CP D Qn+1 Qn+1 H H ↑ L L H H H ↑ H H L [1] H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH CP transition; Qn+1 = state after the next LOW-to-HIGH CP transition. 8 Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit -0.5 +4.6 V input voltage [1] -0.5 +4.6 V VO output voltage Active mode and Power-down mode [1] -0.5 +4.6 V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCC - ±20 mA ICC supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 250 mW VI Ptot [1] [2] total power dissipation Tamb = -40 °C to +125 °C [2] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K. 9 Recommended operating conditions Table 7. Operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74AUP1G74_Q100 Product data sheet Min Max 0.8 3.6 V 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V -40 +125 °C - 200 ns/V VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 Unit © Nexperia B.V. 2017. All rights reserved. 4 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 10 Static characteristics Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.70 × VCC - - V VCC = 0.9 V to 1.95 V 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30 × VCC V VCC = 0.9 V to 1.95 V - - 0.35 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.75 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.11 - - V IO = -1.9 mA; VCC = 1.65 V 1.32 - - V IO = -2.3 mA; VCC = 2.3 V 2.05 - - V IO = -3.1 mA; VCC = 2.3 V 1.9 - - V IO = -2.7 mA; VCC = 3.0 V 2.72 - - V IO = -4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V Tamb = 25 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 0.8 V to 3.6 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.1 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.2 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.2 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 μA 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Min Typ Max ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V; per pin - - 40 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.6 - pF CO output capacitance VO = GND; VCC = 0 V - 1.3 - pF VCC = 0.8 V 0.70 × VCC - - V VCC = 0.9 V to 1.95 V 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30 × VCC V VCC = 0.9 V to 1.95 V - - 0.35 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.7 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.03 - - V IO = -1.9 mA; VCC = 1.65 V 1.30 - - V IO = -2.3 mA; VCC = 2.3 V 1.97 - - V IO = -3.1 mA; VCC = 2.3 V 1.85 - - V IO = -2.7 mA; VCC = 3.0 V 2.67 - - V IO = -4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V [1] Unit Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.5 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.5 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.6 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 μA 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions ΔICC VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V; per pin additional supply current Min Typ Max - - 50 μA VCC = 0.8 V 0.75 × VCC - - V VCC = 0.9 V to 1.95 V 0.70 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25 × VCC V VCC = 0.9 V to 1.95 V - - 0.30 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.11 - - V IO = -1.1 mA; VCC = 1.1 V 0.6 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 0.93 - - V IO = -1.9 mA; VCC = 1.65 V 1.17 - - V IO = -2.3 mA; VCC = 2.3 V 1.77 - - V IO = -3.1 mA; VCC = 2.3 V 1.67 - - V IO = -2.7 mA; VCC = 3.0 V 2.40 - - V IO = -4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V [1] Unit Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.75 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.75 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.75 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 μA ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V; per pin - - 75 μA [1] [1] One input at VCC - 0.6 V, other input at VCC or GND. 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 11 Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C Max Min Max Min Max CL = 5 pF tpd propagation CP to Q, Q; see Figure 5. delay VCC = 0.8 V [2] - 25.4 - - - - - ns VCC = 1.1 V to 1.3 V 2.9 6.7 14.0 2.6 14.2 2.6 14.2 ns VCC = 1.4 V to 1.6 V 2.4 4.5 7.6 2.3 8.3 2.3 8.6 ns VCC = 1.65 V to 1.95 V 1.9 3.5 5.7 1.7 6.5 1.7 6.8 ns VCC = 2.3 V to 2.7 V 1.7 2.6 3.8 1.4 4.4 1.4 4.7 ns 1.5 2.2 3.1 1.2 3.4 1.2 3.7 ns - 19.6 - - - - - ns VCC = 1.1 V to 1.3 V 2.7 5.6 11.0 2.5 11.4 2.5 11.5 ns VCC = 1.4 V to 1.6 V 2.4 4.0 6.3 2.2 6.9 2.2 7.3 ns VCC = 1.65 V to 1.95 V 2.0 3.3 4.9 1.7 5.6 1.7 5.9 ns VCC = 2.3 V to 2.7 V 1.9 2.7 3.7 1.7 4.0 1.7 4.2 ns 1.8 2.5 3.2 1.5 3.6 1.5 3.8 ns - 19.2 - - - - - ns VCC = 1.1 V to 1.3 V 2.6 5.5 11.0 2.5 11.3 2.5 11.5 ns VCC = 1.4 V to 1.6 V 2.3 3.9 6.3 2.2 6.8 2.2 7.3 ns VCC = 1.65 V to 1.95 V 1.9 3.2 5.0 1.8 5.6 1.8 5.9 ns VCC = 2.3 V to 2.7 V 1.9 2.6 3.6 1.7 4.1 1.7 4.3 ns VCC = 3.0 V to 3.6 V 1.8 2.4 3.3 1.5 3.6 1.5 3.8 ns VCC = 0.8 V - 53 - - - - - MHz VCC = 1.1 V to 1.3 V - 203 - 170 - 170 - MHz VCC = 1.4 V to 1.6 V - 347 - 310 - 300 - MHz VCC = 1.65 V to 1.95 V - 435 - 400 - 390 - MHz VCC = 2.3 V to 2.7 V - 550 - 490 - 480 - MHz VCC = 3.0 V to 3.6 V - 619 - 550 - 510 - MHz - 28.9 - - - - - ns VCC = 3.0 V to 3.6 V SD to Q, Q; see Figure 6. [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V RD to Q, Q; see Figure 6. [2] VCC = 0.8 V fmax maximum frequency CP; see Figure 5. CL = 10 pF tpd propagation CP to Q, Q; see Figure 5. delay VCC = 0.8 V 74AUP1G74_Q100 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Tamb = 25 °C Min Typ VCC = 1.1 V to 1.3 V 3.1 VCC = 1.4 V to 1.6 V Max Min Max Min Max 7.5 15.8 2.9 16.1 2.9 16.1 ns 2.7 5.1 8.7 2.4 9.4 2.4 9.8 ns VCC = 1.65 V to 1.95 V 2.5 4.1 6.5 2.2 7.2 2.2 7.6 ns VCC = 2.3 V to 2.7 V 2.0 3.2 4.6 1.8 5.3 1.8 5.6 ns 1.8 2.8 3.8 1.6 4.1 1.6 4.4 ns - 23.2 - - - - - ns VCC = 1.1 V to 1.3 V 2.9 6.5 12.9 2.8 13.3 2.8 13.5 ns VCC = 1.4 V to 1.6 V 2.7 4.6 7.5 2.3 7.9 2.3 8.3 ns VCC = 1.65 V to 1.95 V 2.6 3.9 5.6 2.3 6.3 2.3 6.6 ns VCC = 2.3 V to 2.7 V 2.3 3.2 4.4 2.0 4.8 2.0 5.2 ns 2.2 3.0 3.9 1.9 4.2 1.9 4.4 ns - 22.7 - - - - - ns VCC = 1.1 V to 1.3 V 2.8 6.4 12.8 2.7 13.2 2.7 13.4 ns VCC = 1.4 V to 1.6 V 2.6 4.5 7.5 2.3 8.1 2.3 8.4 ns VCC = 1.65 V to 1.95 V 2.5 3.3 5.8 2.3 6.3 2.3 6.7 ns VCC = 2.3 V to 2.7 V 2.2 3.2 4.4 2.0 4.9 2.0 5.2 ns VCC = 3.0 V to 3.6 V 2.0 2.9 4.0 1.9 4.3 1.9 4.5 ns VCC = 0.8 V - 52 - - - - - MHz VCC = 1.1 V to 1.3 V - 192 - 150 - 150 - MHz VCC = 1.4 V to 1.6 V - 324 - 280 - 230 - MHz VCC = 1.65 V to 1.95 V - 421 - 310 - 250 - MHz VCC = 2.3 V to 2.7 V - 486 - 370 - 360 - MHz VCC = 3.0 V to 3.6 V - 550 - 410 - 360 - MHz - 32.4 - - - - - ns VCC = 1.1 V to 1.3 V 3.5 8.3 17.6 3.3 17.8 3.3 18.0 ns VCC = 1.4 V to 1.6 V 3.2 5.6 9.5 2.8 10.5 2.8 11.1 ns VCC = 1.65 V to 1.95 V 2.7 4.6 7.2 2.5 8.1 2.5 8.6 ns VCC = 2.3 V to 2.7 V 2.4 3.6 5.2 2.2 5.8 2.2 6.2 ns 2.2 3.2 4.4 2.0 4.9 2.0 5.2 ns VCC = 3.0 V to 3.6 V SD to Q, Q; see Figure 6. [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V RD to Q, Q; see Figure 6. [2] VCC = 0.8 V fmax maximum frequency [1] Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C CP; see Figure 5. CL = 15 pF tpd propagation CP to Q, Q; see Figure 5. delay VCC = 0.8 V [2] VCC = 3.0 V to 3.6 V SD to Q, Q; see Figure 6. 74AUP1G74_Q100 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Tamb = 25 °C Min VCC = 0.8 V Max Min Max Min Max 26.7 - - - - - ns VCC = 1.1 V to 1.3 V 3.3 7.3 14.7 3.1 15.2 3.1 15.4 ns VCC = 1.4 V to 1.6 V 3.2 5.2 8.3 2.9 9.0 2.9 9.5 ns VCC = 1.65 V to 1.95 V 2.8 4.3 6.4 2.5 7.1 2.5 7.5 ns VCC = 2.3 V to 2.7 V 2.8 3.7 5.1 2.2 5.5 2.2 5.8 ns 2.5 3.5 4.6 2.4 5.0 2.4 5.2 ns - 26.1 - - - - - ns VCC = 1.1 V to 1.3 V 3.2 7.2 14.5 3.1 15.0 3.1 15.2 ns VCC = 1.4 V to 1.6 V 3.1 5.1 8.4 2.7 9.2 2.7 9.7 ns VCC = 1.65 V to 1.95 V 2.7 4.3 6.5 2.6 7.3 2.6 7.7 ns VCC = 2.3 V to 2.7 V 2.6 3.6 5.0 2.4 5.5 2.4 5.8 ns VCC = 3.0 V to 3.6 V 2.4 3.4 4.6 2.3 5.0 2.3 5.2 ns VCC = 0.8 V - 50 - - - - - MHz VCC = 1.1 V to 1.3 V - 181 - 120 - 120 - MHz VCC = 1.4 V to 1.6 V - 301 - 190 - 160 - MHz VCC = 1.65 V to 1.95 V - 407 - 240 - 190 - MHz VCC = 2.3 V to 2.7 V - 422 - 300 - 270 - MHz VCC = 3.0 V to 3.6 V - 481 - 320 - 300 - MHz - 42.7 - - - - - ns VCC = 1.1 V to 1.3 V 4.2 10.6 22.5 4.0 23.0 4.0 23.3 ns VCC = 1.4 V to 1.6 V 3.7 7.2 12.0 3.7 13.3 3.7 14.0 ns VCC = 1.65 V to 1.95 V 3.5 5.8 9.2 3.4 10.4 3.4 11.0 ns VCC = 2.3 V to 2.7 V 3.3 4.7 6.6 3.0 7.3 3.0 7.8 ns 3.0 4.3 5.8 2.8 6.8 2.8 7.3 ns - 37.0 - - - - - ns VCC = 1.1 V to 1.3 V 4.0 9.5 19.8 3.8 20.8 3.8 21.1 ns VCC = 1.4 V to 1.6 V 3.8 6.7 10.9 3.7 12.0 3.7 12.7 ns VCC = 1.65 V to 1.95 V 3.7 5.6 8.4 3.5 9.3 3.5 9.9 ns VCC = 2.3 V to 2.7 V 3.7 4.8 6.6 3.2 7.2 3.2 7.6 ns VCC = 3.0 V to 3.6 V 3.4 4.6 6.0 3.1 6.8 3.1 7.1 ns RD to Q, Q; see Figure 6. [2] VCC = 0.8 V maximum frequency [1] - VCC = 3.0 V to 3.6 V fmax Typ Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C CP; see Figure 5. CL = 30 pF tpd propagation CP to Q, Q; see Figure 5. delay VCC = 0.8 V [2] VCC = 3.0 V to 3.6 V SD to Q, Q; see Figure 6. VCC = 0.8 V 74AUP1G74_Q100 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Tamb = 25 °C Min RD to Q, Q; see Figure 6. VCC = 0.8 V fmax maximum frequency Typ [1] Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C Max Min Max Min Max [2] - 36.4 - - - - - ns VCC = 1.1 V to 1.3 V 3.9 9.4 19.5 3.8 20.2 3.8 20.5 ns VCC = 1.4 V to 1.6 V 3.6 6.6 10.9 3.7 12.0 3.7 12.6 ns VCC = 1.65 V to 1.95 V 3.5 5.5 8.5 3.5 9.5 3.5 10.1 ns VCC = 2.3 V to 2.7 V 3.5 4.7 6.5 3.2 7.1 3.2 7.6 ns VCC = 3.0 V to 3.6 V 3.3 4.4 6.1 3.1 7.1 3.1 7.5 ns VCC = 0.8 V - 28 - - - - - MHz VCC = 1.1 V to 1.3 V - 145 - 70 - 70 - MHz VCC = 1.4 V to 1.6 V - 185 - 120 - 110 - MHz VCC = 1.65 V to 1.95 V - 270 - 150 - 120 - MHz VCC = 2.3 V to 2.7 V - 290 - 190 - 170 - MHz VCC = 3.0 V to 3.6 V - 315 - 200 - 190 - MHz VCC = 0.8 V - 3.4 - - - - - ns VCC = 1.1 V to 1.3 V - 0.6 - 1.2 - 1.2 - ns VCC = 1.4 V to 1.6 V - 0.3 - 0.6 - 0.6 - ns VCC = 1.65 V to 1.95 V - 0.4 - 0.5 - 0.5 - ns VCC = 2.3 V to 2.7 V - 0.2 - 0.4 - 0.4 - ns VCC = 3.0 V to 3.6 V - 0.3 - 0.4 - 0.4 - ns VCC = 0.8 V - 3.0 - - - - - ns VCC = 1.1 V to 1.3 V - 0.5 - 1.2 - 1.2 - ns VCC = 1.4 V to 1.6 V - 0.3 - 0.7 - 0.7 - ns VCC = 1.65 V to 1.95 V - 0.4 - 0.7 - 0.7 - ns VCC = 2.3 V to 2.7 V - 0.5 - 0.7 - 0.7 - ns VCC = 3.0 V to 3.6 V - 0.6 - 0.8 - 0.8 - ns VCC = 0.8 V - -1.9 - - - - - ns VCC = 1.1 V to 1.3 V - -0.3 - 0.5 - 0.5 - ns VCC = 1.4 V to 1.6 V - -0.2 - 0.2 - 0.2 - ns CP; see Figure 5. CL = 5 pF, 10 pF, 15 pF and 30 pF tsu set-up time D to CP HIGH; see Figure 5. D to CP LOW; see Figure 5. th hold time 74AUP1G74_Q100 Product data sheet D to CP; see Figure 5. All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Tamb = 25 °C Min trec recovery time Typ [1] Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C Max Min Max Min Max VCC = 1.65 V to 1.95 V - -0.2 - 0.1 - 0.1 - ns VCC = 2.3 V to 2.7 V - -0.2 - 0.1 - 0.1 - ns VCC = 3.0 V to 3.6 V - -0.2 - 0.1 - 0.1 - ns VCC = 1.1 V to 1.3 V - -0.5 - -0.9 - -0.9 - ns VCC = 1.4 V to 1.6 V - -0.2 - -0.6 - -0.6 - ns VCC = 1.65 V to 1.95 V - -0.2 - -0.4 - -0.4 - ns VCC = 2.3 V to 2.7 V - -0.1 - -0.1 - -0.1 - ns VCC = 3.0 V to 3.6 V - -0.1 - -0.1 - -0.1 - ns VCC = 1.1 V to 1.3 V - -0.5 - -0.3 - -0.3 - ns VCC = 1.4 V to 1.6 V - -0.4 - -0.1 - -0.1 - ns VCC = 1.65 V to 1.95 V - -0.3 - 0 - 0 - ns VCC = 2.3 V to 2.7 V - -0.2 - 0.1 - 0.1 - ns VCC = 3.0 V to 3.6 V - -0.1 - 0.1 - 0.1 - ns VCC = 1.1 V to 1.3 V - 2.1 - 2.7 - 2.7 - ns VCC = 1.4 V to 1.6 V - 1.1 - 1.5 - 1.5 - ns VCC = 1.65 V to 1.95 V - 0.9 - 1.6 - 1.6 - ns VCC = 2.3 V to 2.7 V - 0.6 - 1.7 - 1.7 - ns VCC = 3.0 V to 3.6 V - 0.6 - 1.9 - 1.9 - ns VCC = 1.1 V to 1.3 V - 4.2 - 11.3 - 11.5 - ns VCC = 1.4 V to 1.6 V - 2.3 - 6.2 - 6.4 - ns VCC = 1.65 V to 1.95 V - 1.8 - 4.8 - 5.0 - ns VCC = 2.3 V to 2.7 V - 1.2 - 3.3 - 3.5 - ns - 1.1 - 2.6 - 2.8 - ns - 2.8 - - - - - pF VCC = 1.1 V to 1.3 V - 2.9 - - - - - pF VCC = 1.4 V to 1.6 V - 3.0 - - - - - pF VCC = 1.65 V to 1.95 V - 3.0 - - - - - pF VCC = 2.3 V to 2.7 V - 3.5 - - - - - pF RD; see Figure 6 SD; see Figure 6. tW pulse width CP HIGH or LOW; see Figure 5. SD or RD LOW; see Figure 6. VCC = 3.0 V to 3.6 V CPD [3] fi = 1 MHz; power dissipation VI = GND to VCC capacitance VCC = 0.8 V 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Symbol Parameter Conditions Tamb = 25 °C Min VCC = 3.0 V to 3.6 V [1] [2] [3] - Typ [1] Tamb = -40 °C Tamb = -40 °C Unit to +85 °C to +125 °C Max Min Max Min Max - - - - - 3.9 pF All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 11.1 Waveforms and test circuit tW VI CP input VM GND 1/fmax VI VM D input GND th th t su t su t PHL t PLH VOH VM Q output VOL VOH Q output VM VOL t PLH t PHL 001aae365 Measurement points are given in Table 10. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Figure 5. The clock input (CP) to output (Q, Q) propagation delays, the data input (D) to clock input (CP) set-up and hold times and the clock input (CP) pulse width and maximum frequency 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger VI CP input VM GND t rec VI SD input VM t rec GND tW tW VI VM RD input GND t PLH t PHL t PHL t PLH VOH VM Q output VOL VOH VM Q output VOL 001aae366 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Figure 6. The set input (SD) and reset input (RD) to output (Q, Q) propagation delays, the set input (SD) and reset input (RD) pulse widths and the reset input (RD) to clock input (CP) recovery time Table 10. Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5 × VCC 0.5 × VCC VCC ≤ 3.0 ns 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger VCC G VI DUT VEXT 5 kΩ VO RT CL RL 001aac521 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 7. Test circuit for measuring switching times Table 11. Test data Supply voltage Load VEXT VCC CL [1] RL 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2 × VCC For measuring enable and disable times RL = 5 kΩ. For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ. 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 12 Package outline VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Figure 8. Package outline SOT765-1 (VSSOP8) 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 13 Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 14 Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1G74_Q100 v.2 20170410 Product data sheet 74AUP1G74_Q100 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AUP1G74_Q100 v.1 20150527 74AUP1G74_Q100 Product data sheet Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 - © Nexperia B.V. 2017. All rights reserved. 17 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation 74AUP1G74_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 74AUP1G74_Q100 Product data sheet 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 19 / 20 74AUP1G74-Q100 Nexperia Low-power D-type flip-flop with set and reset; positive-edge trigger Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 13 Package outline .................................................16 Abbreviations .................................................... 17 Revision history ................................................ 17 Legal information .............................................. 18 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 April 2017 Document identifier: 74AUP1G74_Q100
74AUP1G74DC-Q100H 价格&库存
很抱歉,暂时无法提供与“74AUP1G74DC-Q100H”相匹配的价格&库存,您可以联系我们找货
74AUP1G74DC-Q100H
    74AUP1G74DC-Q100H
    • 1+5.102851+0.63381
    • 10+3.5720010+0.44367
    • 50+2.9600850+0.36767
    • 100+2.76960100+0.34401
    74AUP1G74DC-Q100H
      • 3000+24.92600
      • 15000+24.67680
      库存:6000
      74AUP1G74DC-Q100H
      • 1+2.11200
      • 100+1.69400
      • 750+1.50700
      • 1500+1.43000
      • 3000+1.35300
      74AUP1G74DC-Q100H
      • 3000+2.226543000+0.27656
      • 6000+2.166456000+0.26909
