74AUP2G79GF,115
74AUP2G79GF,115
    NEXPERIA(安世)
    XSON8_1.35X1MM
    低功耗D型触发器;正边缘触发器
74AUP2G79GF,115 数据手册
74AUP2G79 Low-power dual D-type flip-flop; positive-edge trigger Rev. 8 — 24 January 2013 Product data sheet 1. General description The 74AUP2G79 provides the dual positive-edge triggered D-type flip-flop. Information on the data input (nD) is transferred to the nQ output on the LOW-to-HIGH transition of the clock pulse (nCP). The nD input must be stable one set-up time prior to the LOW-to-HIGH clock transition for predictable operation. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing a damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C Downloaded from Arrow.com. 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP2G79DC 40 C to +125 C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm 74AUP2G79GT 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1  1.95  0.5 mm 74AUP2G79GF 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1  0.5 mm 74AUP2G79GD 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT996-2 8 terminals; body 3  2  0.5 mm 74AUP2G79GM 40 C to +125 C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6  1.6  0.5 mm SOT902-2 74AUP2G79GN 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2  1.0  0.35 mm SOT1116 74AUP2G79GS 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1.0  0.35 mm SOT1203 SOT1089 4. Marking Table 2. Marking codes Type number Marking code[1] 74AUP2G79DC p79 74AUP2G79GT p79 74AUP2G79GF pP 74AUP2G79GD p79 74AUP2G79GM p79 74AUP2G79GN pP 74AUP2G79GS pP [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1D 1Q D 1CP CP 2D 2Q 2CP D CP 001aah812 001aah811 Fig 1. Logic symbol 74AUP2G79 Product data sheet Downloaded from Arrow.com. Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 2 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger CP C C D C C TG TG C C Fig 3. Q C C TG TG C C mna442 Logic diagram (one flip-flop) 6. Pinning information 6.1 Pinning 74AUP2G79 1CP 1 8 VCC 1D 2 7 1Q 2Q 3 6 2D GND 4 5 2CP 74AUP2G79 1CP 1 8 VCC 1D 2 7 1Q 2Q 3 6 2D GND 4 5 2CP 001aaf269 Transparent top view 001aaf268 Fig 4. Pin configuration SOT765-1 74AUP2G79 Product data sheet Downloaded from Arrow.com. Fig 5. Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 3 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 74AUP2G79 74AUP2G79 1 8 VCC 1D 2 7 1Q 2Q 3 6 2D GND 4 5 2CP 1 2D 2CP 8 1Q 7 1CP 2 6 1D 3 5 2Q GND 4 1CP VCC terminal 1 index area 001aaj898 Transparent top view Transparent top view Fig 6. 001aaf270 Pin configuration SOT996-2 Fig 7. Pin configuration SOT902-2 6.2 Pin description Table 3. Pin description Symbol Pin Description SOT765-1, SOT833-1, SOT1089, SOT996-2, SOT1116 and SOT1203 SOT902-2 1CP, 2CP 1, 5 7, 3 clock pulse input 1D, 2D 2, 6 6, 2 data input GND 4 4 ground (0 V) 1Q, 2Q 7, 3 1, 5 data output VCC 8 8 supply voltage 7. Functional description Table 4. Function table[1] Input Output nCP nD nQ  L L  H H L X q [1] H = HIGH voltage level; L = LOW voltage level;  = LOW-to-HIGH CP transition; X = don’t care; q = lower case letter indicates the state of referenced input, one set-up time prior to the LOW-to-HIGH CP transition. 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 4 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 +4.6 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot [1] [2] Tamb = 40 C to +125 C [2] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For VSSOP8 packages: above 110 C the value of Ptot derates linearly with 8.0 mW/K. For XSON8 and XQFN8 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74AUP2G79 Product data sheet Downloaded from Arrow.com. Min Max Unit 0.8 3.6 V 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C 0 200 ns/V VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 5 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V VCC = 0.9 V to 1.95 V Typ Max Unit 0.70  VCC - - V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - V Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL - IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V VI = VIH or VIL IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current per pin; VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.6 - pF CO output capacitance VO = GND; VCC = 0 V - 1.3 - pF 74AUP2G79 Product data sheet Downloaded from Arrow.com. [1] All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 6 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +85 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current per pin; VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A 74AUP2G79 Product data sheet Downloaded from Arrow.com. [1] All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 7 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage LOW-level output voltage VOL VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current per pin; VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A [1] [1] One input at VCC  0.6 V, other input at VCC or GND. 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 8 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 19.7 - - - - - ns VCC = 1.1 V to 1.3 V 2.6 5.5 11.0 2.4 12.9 2.4 14.2 ns VCC = 1.4 V to 1.6 V 2.0 3.8 7.0 1.8 8.1 1.8 9.0 ns VCC = 1.65 V to 1.95 V 1.7 3.1 5.4 1.5 6.4 1.5 7.1 ns VCC = 2.3 V to 2.7 V 1.4 2.3 4.0 1.1 4.7 1.1 5.2 ns VCC = 3.0 V to 3.6 V 1.2 2.0 3.4 0.9 4.0 0.9 4.4 ns VCC = 0.8 V - 53 - - - - - MHz VCC = 1.1 V to 1.3 V - 203 - 170 - 170 - MHz VCC = 1.4 V to 1.6 V - 347 - 310 - 300 - MHz CL = 5 pF tpd fmax propagation nCP to nQ; see Figure 8 delay VCC = 0.8 V maximum frequency [2] nCP; see Figure 9 VCC = 1.65 V to 1.95 V - 435 - 400 - 390 - MHz VCC = 2.3 V to 2.7 V - 550 - 490 - 480 - MHz VCC = 3.0 V to 3.6 V - 619 - 550 - 510 - MHz - 23.1 - - - - - ns VCC = 1.1 V to 1.3 V 3.1 6.3 12.3 2.8 14.4 2.8 15.9 ns VCC = 1.4 V to 1.6 V 2.5 4.4 8.1 2.2 9.5 2.2 10.5 ns CL = 10 pF tpd fmax propagation nCP to nQ; see Figure 8 delay VCC = 0.8 V maximum frequency 74AUP2G79 Product data sheet Downloaded from Arrow.com. [2] VCC = 1.65 V to 1.95 V 2.1 3.6 6.3 1.9 7.5 1.9 8.3 ns VCC = 2.3 V to 2.7 V 1.8 2.8 4.7 1.5 5.6 1.5 6.2 ns VCC = 3.0 V to 3.6 V 1.7 2.5 4.1 1.3 4.5 1.3 5.0 ns nCP; see Figure 9 VCC = 0.8 V - 52 - - - - - MHz VCC = 1.1 V to 1.3 V - 192 - 150 - 150 - MHz VCC = 1.4 V to 1.6 V - 324 - 280 - 230 - MHz VCC = 1.65 V to 1.95 V - 421 - 310 - 250 - MHz VCC = 2.3 V to 2.7 V - 486 - 370 - 360 - MHz VCC = 3.0 V to 3.6 V - 550 - 410 - 360 - MHz All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 9 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 26.6 - - - - - ns VCC = 1.1 V to 1.3 V 3.5 7.1 13.6 3.2 15.6 3.2 17.2 ns VCC = 1.4 V to 1.6 V 2.8 5.0 9.2 2.5 10.7 2.5 11.8 ns CL = 15 pF tpd fmax propagation nCP to nQ; see Figure 8 delay VCC = 0.8 V maximum frequency [2] VCC = 1.65 V to 1.95 V 2.4 4.1 7.1 2.2 8.5 2.2 9.4 ns VCC = 2.3 V to 2.7 V 2.2 3.2 5.4 1.9 6.3 1.9 7.0 ns VCC = 3.0 V to 3.6 V 2.0 2.9 4.5 1.6 5.0 1.6 5.5 ns nCP; see Figure 9 VCC = 0.8 V - 50 - - - - - MHz VCC = 1.1 V to 1.3 V - 181 - 120 - 120 - MHz VCC = 1.4 V to 1.6 V - 301 - 190 - 160 - MHz VCC = 1.65 V to 1.95 V - 407 - 240 - 190 - MHz VCC = 2.3 V to 2.7 V - 422 - 300 - 270 - MHz VCC = 3.0 V to 3.6 V - 481 - 320 - 300 - MHz CL = 30 pF tpd fmax propagation nCP to nQ; see Figure 8 delay VCC = 0.8 V maximum frequency 74AUP2G79 Product data sheet Downloaded from Arrow.com. [2] - 36.8 - - - - - ns VCC = 1.1 V to 1.3 V 4.7 9.3 17.3 4.2 23.3 4.2 25.6 ns VCC = 1.4 V to 1.6 V 3.8 6.4 11.8 3.3 14.3 3.3 15.7 ns VCC = 1.65 V to 1.95 V 3.3 5.3 9.4 3.0 11.3 3.0 12.4 ns VCC = 2.3 V to 2.7 V 3.0 4.3 7.0 2.7 8.5 2.7 9.4 ns VCC = 3.0 V to 3.6 V 2.8 3.9 5.8 2.6 7.2 2.6 7.9 ns VCC = 0.8 V - 28 - - - - - VCC = 1.1 V to 1.3 V - 128 - 70 - 70 - MHz VCC = 1.4 V to 1.6 V - 206 - 120 - 110 - MHz VCC = 1.65 V to 1.95 V - 262 - 150 - 120 - MHz VCC = 2.3 V to 2.7 V - 269 - 190 - 170 - MHz VCC = 3.0 V to 3.6 V - 309 - 200 - 190 - MHz nCP; see Figure 9 All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © MHz Nexperia B.V. 2017. All rights reserved 10 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 0.8 V - 3.4 - - - - - ns VCC = 1.1 V to 1.3 V - 0.8 - 1.5 - 1.5 - ns VCC = 1.4 V to 1.6 V - 0.5 - 1.0 - 1.0 - ns VCC = 1.65 V to 1.95 V - 0.5 - 0.9 - 0.9 - ns VCC = 2.3 V to 2.7 V - 0.4 - 0.7 - 0.7 - ns VCC = 3.0 V to 3.6 V - 0.4 - 0.6 - 0.6 - ns VCC = 0.8 V - 3.0 - - - - - ns VCC = 1.1 V to 1.3 V - 0.9 - 1.6 - 1.6 - ns VCC = 1.4 V to 1.6 V - 0.6 - 1.0 - 1.0 - ns VCC = 1.65 V to 1.95 V - 0.5 - 0.9 - 0.9 - ns VCC = 2.3 V to 2.7 V - 0.5 - 0.9 - 0.9 - ns VCC = 3.0 V to 3.6 V - 0.7 - 1.0 - 1.0 - ns VCC = 0.8 V - 1.9 - - - - - ns VCC = 1.1 V to 1.3 V - 0.6 - 0 - 0 - ns VCC = 1.4 V to 1.6 V - 0.4 - 0 - 0 - ns CL = 5 pF, 10 pF, 15 pF and 30 pF tsu set-up time HIGH; nD to nCP; see Figure 9 LOW; nD to nCP; see Figure 9 th tW hold time pulse width 74AUP2G79 Product data sheet Downloaded from Arrow.com. nD to nCP; see Figure 9 VCC = 1.65 V to 1.95 V - 0.4 - 0 - 0 - ns VCC = 2.3 V to 2.7 V - 0.4 - 0 - 0 - ns VCC = 3.0 V to 3.6 V - 0.3 - 0 - 0 - ns VCC = 0.8 V - 5.6 - - - - - ns VCC = 1.1 V to 1.3 V - 2.4 - 3.5 - 3.5 - ns VCC = 1.4 V to 1.6 V - 1.3 - 2.0 - 2.0 - ns HIGH or LOW; nCP; see Figure 9 VCC = 1.65 V to 1.95 V - 0.9 - 1.9 - 1.9 - ns VCC = 2.3 V to 2.7 V - 0.7 - 2.0 - 2.0 - ns VCC = 3.0 V to 3.6 V - 0.6 - 2.2 - 2.2 - ns All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 11 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter CPD 25 C Conditions 40 C to +125 C Unit Min Max Min Max Min Max - 1.6 - - - - - pF VCC = 1.1 V to 1.3 V - 1.7 - - - - - pF VCC = 1.4 V to 1.6 V - 1.8 - - - - - pF [3] power f = 1 MHz; dissipation VI = GND to VCC capacitance VCC = 0.8 V VCC = 1.65 V to 1.95 V - 1.9 - - - - - pF VCC = 2.3 V to 2.7 V - 2.3 - - - - - pF VCC = 3.0 V to 3.6 V - 2.7 - - - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] 40 C to +85 C Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 12. Waveforms VI nD input GND VI nCP input VM VM GND tPHL tPLH VM VM VOH nQ output VOL 001aaf271 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. The clock input (nCP) to output (nQ) propagation delays 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 12 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger VI VM nD input GND th th tsu tsu 1/fmax VI VM nCP input GND tW tPHL tPLH VOH VM nQ output VOL 001aaf272 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 9. Table 9. The clock input (nCP) to output (nQ) propagation delays, nCP clock pulse width, nD to nCP set-up times, nCP to nD hold times and the nCP maximum frequency Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5  VCC 0.5  VCC VCC  3.0 ns 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 13 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger VCC VEXT 5 kΩ G VI VO DUT CL RT RL 001aac521 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VEXT VCC CL RL[1] 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2  VCC For measuring enable and disable times RL = 5 k. For measuring propagation delays, set-up and hold times and pulse width RL = 1 M. 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 14 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 13. Package outline VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D E SOT765-1 A X c y HE v M A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 4 e L detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(2) e HE L Lp Q v w y Z(1) θ mm 1 0.15 0.00 0.85 0.60 0.12 0.27 0.17 0.23 0.08 2.1 1.9 2.4 2.2 0.5 3.2 3.0 0.4 0.40 0.15 0.21 0.19 0.2 0.13 0.1 0.4 0.1 8° 0° Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT765-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-06-07 MO-187 Fig 11. Package outline SOT765-1 (VSSOP8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 15 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig 12. Package outline SOT833-1 (XSON8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 16 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 E terminal 1 index area D A A1 detail X (4×)(2) e L (8×)(2) b 4 5 e1 1 terminal 1 index area 8 L1 X 0 0.5 scale Dimensions Unit mm max nom min 1 mm A(1) 0.5 A1 b D E e e1 L L1 0.35 0.40 0.04 0.20 1.40 1.05 0.15 1.35 1.00 0.55 0.35 0.30 0.35 0.27 0.32 0.12 1.30 0.95 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version SOT1089 sot1089_po References IEC JEDEC JEITA European projection Issue date 10-04-09 10-04-12 MO-252 Fig 13. Package outline SOT1089 (XSON8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 17 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 3 x 2 x 0.5 mm B D SOT996-2 A E A A1 detail X terminal 1 index area e1 1 4 8 5 C C A B C v w b e L1 y y1 C L2 L X 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit(1) mm max nom min A A1 b 0.05 0.35 D E 2.1 3.1 0.5 0.00 0.15 1.9 e e1 0.5 1.5 2.9 L L1 L2 0.5 0.15 0.6 0.3 0.05 0.4 v 0.1 w y 0.05 0.05 y1 0.1 sot996-2_po Outline version References IEC JEDEC JEITA European projection Issue date 07-12-21 12-11-20 SOT996-2 Fig 14. Package outline SOT996-2 (XSON8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 18 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XQFN8: plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 X A B D terminal 1 index area E A A1 detail X e v w b 4 3 C C A B C y y1 C 5 e1 2 6 1 7 terminal 1 index area 8 L metal area not for soldering L1 0 1 Dimensions Unit(1) mm max nom min 2 mm scale A 0.5 A1 b D E e e1 0.05 0.25 1.65 1.65 0.20 1.60 1.60 0.55 0.00 0.15 1.55 1.55 0.5 L L1 v 0.35 0.15 0.30 0.10 0.25 0.05 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT902-2 --- MO-255 --- sot902-2_po European projection Issue date 10-11-02 11-03-31 Fig 15. Package outline SOT902-2 (XQFN8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 19 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm 1 2 SOT1116 b 4 3 (4×)(2) L L1 e 8 7 e1 6 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 max 0.35 0.04 0.20 1.25 1.05 nom 0.15 1.20 1.00 0.55 min 0.12 1.15 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1116_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1116 Fig 16. Package outline SOT1116 (XSON8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 20 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 2 1 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Fig 17. Package outline SOT1203 (XSON8) 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 21 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 14. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP2G79 v.8 20130124 Product data sheet - 74AUP2G79 v.7 Modifications: • For type number 74AUP2G79GD XSON8U has changed to XSON8. 74AUP2G79 v.7 20120614 Product data sheet - 74AUP2G79 v.6 74AUP2G79 v.6 20111208 Product data sheet - 74AUP2G79 v.5 74AUP2G79 v.5 20100930 Product data sheet - 74AUP2G79 v.4 74AUP2G79 v.4 20090630 Product data sheet - 74AUP2G79 v.3 74AUP2G79 v.3 20090401 Product data sheet - 74AUP2G79 v.2 74AUP2G79 v.2 20080319 Product data sheet - 74AUP2G79 v.1 74AUP2G79 v.1 20061006 Product data sheet - - 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 22 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AUP2G79 Product data sheet Downloaded from Arrow.com. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 23 of 25 74AUP2G79 Nexperia Low-power dual D-type flip-flop; positive-edge trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AUP2G79 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 8 — 24 January 2013 © Nexperia B.V. 2017. All rights reserved 24 of 25 Nexperia 74AUP2G79 Low-power dual D-type flip-flop; positive-edge trigger 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 22 Legal information. . . . . . . . . . . . . . . . . . . . . . . 23 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 23 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Contact information. . . . . . . . . . . . . . . . . . . . . 24 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 January 2013 Downloaded from Arrow.com.
74AUP2G79GF,115 价格&库存
很抱歉,暂时无法提供与“74AUP2G79GF,115”相匹配的价格&库存,您可以联系我们找货
