BC846x series
65 V, 100 mA NPN general-purpose transistors
Rev. 12 — 1 July 2022
Product data sheet
1. General description
NPN general-purpose transistors in a small SOT23 (TO236AB) Surface-Mounted Device (SMD)
plastic package.
Table 1. Product overview
Type number
Package
BC846
PNP complement
Nexperia
JEDEC
SOT23
TO-236AB
BC856
BC846A
BC856A
BC846B
BC856B
2. Features and benefits
General-purpose transistors
SMD plastic package
Two different gain selections
3. Applications
General-purpose switching and amplification
4. Quick reference data
Table 2. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
65
V
IC
collector current
100
mA
110
450
110
180
220
200
290
450
open base
DCcurrent gain
hFE
BC846
BC846A
BC846B
VCE = 5 V; IC = 2 mA
BC846x series
Nexperia
5. Pinning information
Table 3. Pinning
Pin
Symbol
Description
1
B
base
2
E
emitter
3
C
collector
Simplified outline
Graphic symbol
3
C
B
E
1
2
sym021
6. Ordering information
Table 4. Ordering information
Type number
Package
BC846
Name
Description
Version
TO-236AB
Plastic surface-mounted package; 3 leads
SOT23
BC846A
BC846B
7. Marking
Table 5. Marking
Type number
Marking code[1]
BC846
1D%
BC846A
1A%
BC846B
1B%
[1]
% = placeholder for manufacturing site code
BC846X_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2022. All rights reserved
2 / 11
BC846x series
Nexperia
8. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
80
V
VCEO
collector-emitter voltage
open base
65
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current
100
mA
ICM
peak collector current
single pulse; tp ≤ 1 ms
200
mA
IBM
peak base current
200
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
250
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-65
150
°C
Tstg
storage temperature
-65
150
°C
Min
Typ
Max
Unit
500
K/W
[1]
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
9. Thermal characteristics
Table 7. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
in free air
[1]
[2]
thermal resistance from junction to ambient
[1]
[2]
Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided; 35 µm copper; tin-plated and standard footprint.
Valid for all available selection groups.
aaa-028968
103
duty cycle =
1
Zth(j-a)
(K/W)
0.5
102
0.75
0.33
0.2
0.1
0.05
10
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, single-sided; 35 µm copper, tin-plated and standard footprint
Fig. 1.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
BC846X_SER
Product data sheet
3 / 11
BC846x series
Nexperia
10. Characteristics
Table 8. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)CBO
collector-base
breakdown voltage
IC = 100 µA; IE = 0 A; Tamb = 25 °C
80
V
V(BR)CEO
collector-emitter
breakdown voltage
IC = 10 mA; IE = 0 A; Tamb = 25 °C
65
V
V(BR)EBO
emitter-base
breakdown voltage
IE = 100 µA; IC = 0 A; Tamb = 25 °C
6
V
ICBO
collector-base
cut-off current
VCB = 30 V; IE = 0 A; Tamb = 25 °C
15
nA
VCB = 30 V; IE = 0 A; Tj = 150 °C
5
μA
IEBO
emitter-base
cut-off current
VEB = 5 V; IC = 0 A; Tamb = 25 °C
100
nA
hFE
DC current gain
BC846A
180
BC846B
290
BC846
110
450
110
180
220
200
290
450
BC846A
VCE = 5 V; IC = 10 µA; Tamb = 25 °C
VCE = 5 V; IC = 2 mA; Tamb = 25 °C
BC846B
VCEsat
VBEsat
90
200
mV
IC =100 mA; IB = 5 mA; Tamb = 25 °C
[1]
200
400
mV
base-emitter saturation IC =10 mA; IB = 0.5 mA; Tamb = 25 °C
voltage
[2]
760
mV
900
mV
collector-emitter
saturation voltage
IC = 2 mA; VCE = 5 V; Tamb = 25 °C
[3]
580
660
700
mV
IC = 10 mA; VCE = 5 V; Tamb = 25 °C
[3]
770
mV
100
MHz
VCB = 10 V; IE = ie = 0 A; f = 1 MHz;
Tamb = 25 °C
2
3
pF
emitter capacitance
VEB = 0.5 V; IC = ic = 0 A; f = 1 MHz;
Tamb = 25 °C
11
pF
noise figure
IC = 200 A; VCE = 5 V; RS = 2 kΩ; f = 1 kHz; B =
200 Hz; Tamb = 25 °C
2
10
dB
VBE
base-emitter voltage
fT
transition frequency
VCE = 5 V; IC = 10 mA; f = 100 MHz;
Tamb = 25 °C
Cc
collector capacitance
Ce
NF
[1]
[2]
[3]
pulsed; tp ≤ 300 μs; δ ≤ 0.02
VBEsat decreases by approximately 1.7 mV/K with increasing temperature.
VBE decreases by about 2 mV/K with increasing temperature.
BC846X_SER
Product data sheet
4 / 11
BC846x series
Nexperia
mgt723
400
hFE
(1)
300
mgt724
1200
VBE
(mV)
1000
(1)
800
(2)
(2)
200
600
100
(3)
400
(3)
200
1
10
102
I C (mA)
103
VCE = 5 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 2.
1
10
102
I C (mA)
103
VCE = 5 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Group A: DC current gain as a function of
collector current; typical values
mgt725
103
Fig. 3.
Group A: Base-emitter voltage as a function of
mgt726
1200
VBEsat
(mV)
1000
VCEsat
(mV)
(1)
800
102
(2)
600
(1)
(3)
(2)
400
(3)
200
10
10- 1
Fig. 4.
1
10
102
I C (mA)
103
1
10
102
I C (mA)
103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
IC/IB = 10
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Group A: Collector-emitter saturation voltage as Fig. 5.
a function of collector current; typical values
Group A: Base-emitter saturation voltage as a
BC846X_SER
Product data sheet
5 / 11
BC846x series
Nexperia
mgt727
600
hFE
500
400
mgt728
1200
VBE
(mV)
1000
(1)
800
(1)
(2)
300
600
(2)
200
(3)
100
1
10
200
102
I C (mA)
103
VCE = 5 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 6.
(3)
400
10- 1
1
102
103
I C (mA)
10
VCE = 5 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Group B: DC current gain as a function of
mgt729
104
Fig. 7.
Group B: Base-emitter voltage as a function of
mgt730
1200
VBEsat
(mV)
1000
VCEsat
(mV)
(1)
103
800
(2)
600
(3)
102
400
(1)
200
(3) (2)
10
10- 1
Fig. 8.
1
10
102
I C (mA)
103
1
10
102
I C (mA)
103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
IC/IB = 10
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Group B: Collector-emitter saturation voltage as Fig. 9.
Group B: Base-emitter saturation voltage as a
BC846X_SER
Product data sheet
6 / 11
BC846x series
Nexperia
11. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
0.15
0.09
18-03-12
Fig. 10. Package outline SOT23 (TO-236AB)
BC846X_SER
Product data sheet
7 / 11
BC846x series
Nexperia
12. Soldering
3.3
2.9
1.9
solder lands
3
solder resist
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig. 11. Reflow soldering footprint for SOT23 (TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot23_fw
Fig. 12. Wave soldering footprint for SOT23 (TO-236AB)
BC846X_SER
Product data sheet
8 / 11
BC846x series
Nexperia
13. Revision history
Table 9. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
BC846X_SER v.12
20220701
Product data sheet
BC846X_SER v.11
Modifications:
BC846X_SER v.11
20220520
Product data sheet
BC846X_SER v.10
BC846X_SER v.10
20220127
Product data sheet
BC846_SER v.9
BC846_SER v.9
20120925
Product data sheet
BC846_SER v.8
BC846_SER v.8
20120424
Product data sheet
BC846_BC546_SER v.7
BC846_BC546_SER v.7
20091117
Product data sheet
BC846_BC546_SER v.6
BC846_BC546_SER v.6
20060207
Product data sheet
BC846X_SER
Product data sheet
Product(s) changed to non-automotive qualification. Please refer to nexperia.com for
automotive (-Q) product alternative(s).
9 / 11
BC846x series
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
BC846X_SER
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
10 / 11
BC846x series
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 4
11. Package outline.......................................................... 7
12. Soldering..................................................................... 8
13. Revision history..........................................................9
14. Legal information......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 July 2022
BC846X_SER
Product data sheet
11 / 11
