BC857AMB,315
BC857AMB,315
    NEXPERIA(安世)
    SOT883B
    通用三极管 45V 100mA PNP SOT883B 125~250
BC857AMB,315 数据手册
BC857xMB series 45 V, 100 mA PNP general-purpose transistors Rev. 1 — 21 February 2012 Product data sheet 1. Product profile 1.1 General description PNP general-purpose transistors in a leadless ultra small SOT883B Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package NPN complement Nexperia JEITA JEDEC BC857AMB SOT883B - - BC847AMB BC857BMB SOT883B - - BC847BMB BC857CMB SOT883B - - BC847CMB 1.2 Features and benefits  Leadless ultra small SMD plastic package  Low package height of 0.37 mm  Power dissipation comparable to SOT23  AEC-Q101 qualified 1.3 Applications  General-purpose switching and amplification  Mobile applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 45 V IC collector current - - 100 mA hFE DC current gain BC857AMB 125 - 250 BC857BMB 220 - 475 BC857CMB 420 - 800 VCE = 5 V; IC = 2 mA BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 2. Pinning information Table 3. Pinning Pin Description Simplified outline 1 base 2 emitter 1 3 collector 2 Graphic symbol 3 3 1 Transparent top view 2 sym013 3. Ordering information Table 4. Ordering information Type number Package Name BC857xMB series - Description Version leadless ultra small plastic package; 3 solder lands; body 1.0  0.6  0.37 mm SOT883B 4. Marking Table 5. Marking codes Type number Marking code[1] BC857AMB 0100 0100 BC857BMB 0100 0101 BC857CMB 0100 0110 [1] For SOT883B binary marking code description, see Figure 1. 4.1 Binary marking code description PIN 1 INDICATION READING DIRECTION READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac673 Fig 1. BC857XMB_SER Product data sheet SOT883B binary marking code description All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 2 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BC857XMB_SER Product data sheet Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 45 V VEBO emitter-base voltage open collector - 5 V IC collector current - 100 mA ICM peak collector current single pulse; tp  1 ms - 200 mA IBM peak base current single pulse; tp  1 ms - 100 mA Ptot total power dissipation Tamb  25 C - 250 mW Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1][2] [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 3 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air [1][2] Min Typ Max Unit - - 500 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. 006aab603 103 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.5 0.33 102 0.2 0.1 0.05 0.02 10 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC857XMB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 4 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 7. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off current VCB = 30 V; IE = 0 A - - 15 nA VCB = 30 V; IE = 0 A; Tj = 150 C - - 5 A IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 5 V; IC = 2 mA BC857AMB 125 - 250 BC857BMB 220 - 475 BC857CMB 420 - 800 ICBO VCEsat VBE Product data sheet IC = 10 mA; IB = 0.5 mA - - 200 mV - - 400 mV base-emitter voltage IC = 2 mA; VCE = 5 V 600 - 750 mV IC = 10 mA; VCE = 5 V - - 820 mV IC = 100 mA; IB = 5 mA [1] fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - - 2.5 pF NF noise figure IC = 200 A; VCE = 5 V; RS = 2 k; f = 1 kHz; B = 200 Hz - - 10 dB [1] BC857XMB_SER collector-emitter saturation voltage Pulse test: tp  300 s;   0.02. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 5 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors mle188 500 mle189 −1200 VBE (mV) hFE −1000 400 (1) (1) −800 300 (2) (2) 200 −600 (3) 0 −10−2 (3) −400 100 −10−1 −1 −10 −102 −103 IC (mA) −200 −10−2 VCE = 5 V −10−1 −103 −102 IC (mA) −10 VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 3. −1 BC857AMB: DC current gain as a function of collector current; typical values mle190 −104 VCEsat (mV) Fig 4. BC857AMB: Base-emitter voltage as a function of collector current; typical values mle191 −1200 VBEsat (mV) −1000 (1) −103 (2) −800 −102 (3) −600 (1) (2) (3) −10 −10−1 −1 −10 −400 −102 IC (mA) −103 −200 −10−1 −1 IC/IB = 20 IC/IB = 20 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 5. BC857AMB: Collector-emitter saturation voltage as a function of collector current; typical values BC857XMB_SER Product data sheet Fig 6. −10 −102 IC (mA) −103 BC857AMB: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 6 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors mle192 1000 mle193 −1200 VBE (mV) hFE 800 −1000 600 −800 (1) (1) (2) −600 400 (2) 200 0 −10−2 (3) −400 (3) −10−1 −1 −10 −102 −103 IC (mA) −200 −10−2 VCE = 5 V −10−1 −103 −102 IC (mA) −10 VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 7. −1 BC857BMB: DC current gain as a function of collector current; typical values mle194 −104 VCEsat (mV) Fig 8. BC857BMB: Base-emitter voltage as a function of collector current; typical values mle195 −1200 VBEsat (mV) −1000 (1) −103 (2) −800 (3) −600 −102 (1) (2) −400 (3) −10 −10−1 −1 −10 −102 IC (mA) −103 −200 −10−1 −1 IC/IB = 20 IC/IB = 20 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 9. BC857BMB: Collector-emitter saturation voltage as a function of collector current; typical values BC857XMB_SER Product data sheet −10 −102 IC (mA) −103 Fig 10. BC857BMB: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 7 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors mle196 1000 hFE (1) mle197 −1200 VBE (mV) −1000 800 (1) −800 600 (2) (2) −600 400 (3) (3) −400 200 0 −10−2 −10−1 −1 −10 −102 −103 IC (mA) −200 −10−1 VCE = 5 V −1 −10 −102 IC (mA) −103 VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 11. BC857CMB: DC current gain as a function of collector current; typical values mle198 −104 VCEsat (mV) Fig 12. BC857CMB: Base-emitter voltage as a function of collector current; typical values mle199 −1200 VBEsat (mV) −1000 (1) −103 (2) −800 (3) −600 (1) −102 (2) −400 (3) −10 −10−1 −1 −10 −102 IC (mA) −103 −200 −10−1 −1 IC/IB = 20 IC/IB = 20 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 13. BC857CMB: Collector-emitter saturation voltage as a function of collector current; typical values BC857XMB_SER Product data sheet −10 −102 IC (mA) −103 Fig 14. BC857CMB: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 8 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 0.65 0.55 0.40 0.34 0.35 0.20 0.12 1 0.04 max 2 0.30 0.22 1.05 0.65 0.95 0.30 0.22 3 0.55 0.47 Dimensions in mm 11-11-02 Fig 15. Package outline SOT883B 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 10000 BC857xMB series SOT883B [1] BC857XMB_SER Product data sheet 2 mm pitch, 8 mm tape and reel -315 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 9 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 11. Soldering Footprint information for reflow soldering SOT883B 1.3 0.7 R0.05 (8x) 0.9 0.6 0.7 0.25 (2x) 0.3 (2x) 0.3 0.4 (2x) 0.4 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot883b_fr Reflow soldering is the only recommended soldering method. Fig 16. Reflow soldering footprint SOT883B BC857XMB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 10 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BC857XMB_SER v.1 20120221 Product data sheet - - BC857XMB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 11 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BC857XMB_SER Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 12 of 14 BC857xMB series Nexperia 45 V, 100 mA PNP general-purpose transistors Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BC857XMB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia BC857xMB series 45 V, 100 mA PNP general-purpose transistors 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 4.1 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Binary marking code description. . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 February 2012
BC857AMB,315 价格&库存
很抱歉,暂时无法提供与“BC857AMB,315”相匹配的价格&库存,您可以联系我们找货
