BC856BMBYL
BC856BMBYL
    NEXPERIA(安世)
    DFN1006B-3
    通用三极管 60V 100mA PNP DFN1006B-3 220~475
BC856BMBYL 数据手册
BC856BMB 60 V, 100 mA PNP general-purpose transistor 19 August 2015 Product data sheet 1. General description PNP general-purpose transistor in a leadless ultra small DFN1006B-3 (SOT883B) Surface-Mounted Device (SMD) plastic package. NPN complement: BC846BMB. 2. Features and benefits • • • • Leadless ultra small SMD plastic package Low package height of 0.37 mm Power dissipation comparable to SOT23 AEC-Q101 qualified 3. Applications • • General-purpose switching and amplification Mobile applications 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -60 V IC collector current - - -100 mA hFE DC current gain 220 - 475 VCE = -5 V; IC = -2 mA; Tamb = 25 °C 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 1 3 2 1 Transparent top view DFN1006B-3 (SOT883B) 2 sym013 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 6. Ordering information Table 3. Ordering information Type number BC856BMB Package Name Description Version DFN1006B-3 DFN1006B-3: leadless ultra small plastic package; 3 solder lands; body 1.0 x 0.6 x 0.37 mm SOT883B 7. Marking Table 4. Marking codes Type number Marking code BC856BMB 0101 1010 PIN 1 INDICATION READING DIRECTION READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac673 Fig. 1. DFN1006B-3 (SOT883B) binary marking code description BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 2 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -80 V VCEO collector-emitter voltage open base - -60 V VEBO emitter-base voltage open collector - -6 V IC collector current - -100 mA ICM peak collector current - -200 mA IBM peak base current - -200 mA Ptot total power dissipation - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] single pulse; tp ≤ 1 ms Tamb ≤ 25 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. aaa-019152 300 Ptot (mW) 200 100 0 -75 -25 25 75 125 Tj (°C) 175 FR4 PCB, standard footprint Fig. 2. Power derating curve DFN1006B-3 (SOT883B) BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 3 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] 103 Max Unit - - 500 K/W Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 006aab603 0.5 102 Typ duty cycle = 1 Zth(j-a) (K/W) [1] Min 0.75 0.33 0.2 0.1 0.05 10 0.02 0.01 0 1 10- 5 10- 4 10- 3 10- 2 10- 1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 4 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = -30 V; IE = 0 A; Tamb = 25 °C - - -15 nA VCB = -30 V; IE = 0 A; Tj = 150 °C - - -5 µA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -100 nA hFE DC current gain VCE = -5 V; IC = -2 mA; Tamb = 25 °C 220 - 475 VCEsat collector-emitter saturation voltage IC = -10 mA; IB = -0.5 mA; Tamb = 25 °C - - -200 mV IC = -100 mA; IB = -5 mA; pulsed; - - -400 mV base-emitter saturation IC = -10 mA; IB = -0.5 mA; Tamb = 25 °C voltage IC = -100 mA; IB = -5 mA; Tamb = 25 °C - -700 - mV - -850 - mV base-emitter voltage VCE = -5 V; IC = -2 mA; Tamb = 25 °C -600 - -750 mV VCE = -5 V; IC = -10 mA; Tamb = 25 °C - - -820 mV VCB = -10 V; IE = 0 A; ie = 0 A; - - 2.5 pF - 4.5 - pF 100 - - MHz - - 10 dB tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VBEsat VBE CC collector capacitance f = 1 MHz; Tamb = 25 °C CE emitter capacitance VEB = -0.5 V; IC = 0 A; ic = 0 A; f = 1 MHz; Tamb = 25 °C fT transition frequency VCE = -5 V; IC = -10 mA; f = 100 MHz; Tamb = 25 °C NF noise figure VCE = -5 V; IC = -200 µA; RS = 2 kΩ; f = 1 kHz; B = 200 Hz; Tamb = 25 °C BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 5 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor aaa-019159 600 hFE aaa-019160 -1.2 VBE (V) (1) 400 (1) -0.8 (2) (2) 200 0 -10-1 Fig. 4. (3) -0.4 (3) -1 -10 -102 IC (mA) 0 -10-1 -103 -1 -10 VCE = -5 V VCE = -5 V (1) Tamb = 150 °C (1) Tamb = -55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −55 °C (3) Tamb = 150 °C DC current gain as a function of collector current; typical values Fig. 5. aaa-019161 -1.2 -102 IC (mA) -103 Base-emitter voltage as a function of collector current; typical values aaa-019162 -1 VBEsat (V) -1.0 VCEsat (V) (1) -0.8 (2) -10-1 (1) -0.6 (2) (3) (3) -0.4 -0.2 -10-1 Fig. 6. -1 -10 -102 IC (mA) -103 -10-2 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 20 IC/IB = 20 (1) Tamb = -55 °C (1) Tamb = 150 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 150°C (3) Tamb = -55 °C Base-emitter saturation voltage as a function of Fig. 7. collector current; typical values Collector-emitter saturation voltage as a function of collector current; typical values BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 6 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 11. Test information 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 0.65 0.55 0.35 1 2 0.20 0.12 0.40 0.34 0.04 max 0.30 0.22 1.05 0.65 0.95 0.30 0.22 3 0.55 0.47 Dimensions in mm Fig. 8. 11-11-02 Package outline DFN1006B-3 (SOT883B) BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 7 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 13. Soldering Footprint information for reflow soldering SOT883B 1.3 0.7 R0.05 (8x) 0.9 0.6 0.7 0.25 (2x) Fig. 9. 0.3 (2x) 0.3 0.4 (2x) 0.4 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot883b_fr Reflow soldering footprint for DFN1006B-3 (SOT883B) BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 8 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BC856BMB v.1 20150819 Product data sheet - - BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 9 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. BC856BMB Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 10 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 11 / 12 BC856BMB Nexperia 60 V, 100 mA PNP general-purpose transistor 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 1 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 11.1 Test information ..................................................... 7 Quality information ............................................... 7 12 Package outline ..................................................... 7 13 Soldering ................................................................ 8 14 Revision history ..................................................... 9 15 15.1 15.2 15.3 15.4 Legal information .................................................10 Data sheet status ............................................... 10 Definitions ...........................................................10 Disclaimers .........................................................10 Trademarks ........................................................ 11 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 August 2015 BC856BMB Product data sheet All information provided in this document is subject to legal disclaimers. 19 August 2015 © Nexperia B.V. 2017. All rights reserved 12 / 12
BC856BMBYL 价格&库存
很抱歉,暂时无法提供与“BC856BMBYL”相匹配的价格&库存,您可以联系我们找货
BC856BMBYL
    • 10000+0.63720
    • 20000+0.62100
    • 30000+0.59940
    • 60000+0.58860
    BC856BMBYL
