ULC0542CDN
1-Line Bi-directional TVS Diode
Features
Ultra low capacitance: 0.5pF typical
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
2-pin leadless package
Dimensions DFN1006
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
– IEC61000-4-5 (Lightning) 5A (8/20μs)
RoHS Compliant
Lead Finish: NiPdAu
Pin Configuration
Applications
Smart phones
Display Ports
MDDI Ports
USB Ports
Digital Video Interface (DVI)
PCI Express and Serial SATA Ports
Mechanical Characteristics
Package: DFN1006
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:10,000pcs
Reel Size:7 inch
Device Marking: S1
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
35
VESD
± 25
Unit
W
Kv
± 20
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-40 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev 2.0 : 01.07.2021
1/4
www.leiditech.com
ULC0542CDN
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Test Condition
Min
Typ
VRWM
12.0
Max Unit
5.0
V
14.0
V
4.0
V
0.2
µA
Breakdown Voltage
VBR
IT = 1mA
8.0
Holding Voltage
Vh
IT = 100mA
2.6
Reverse Leakage Current
IR
VRWM = 5.0V
Clamping Voltage
VC
IPP = 1A (8 x 20µs pulse)
5.0
Clamping Voltage
VC
IPP = 5A (8 x 20µs pulse)
6.0
8.0
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
0.5
1.0
pF
V
Portion Electronics Parameter
Symbol
Parameter
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
Vc
Clamping Voltage @Ic
2/4
www.leiditech.com
ULC0542CDN
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
8
6
4
2
2
3
4
VR—Reverse Voltage(V)
2
3
4
5
6
Ipp-Peak Pulse Current(A)
Junction Capacitance vs. Reverse Voltage
Clamping Voltage vs. Peak Pulse Current
100
80
60
Voltage (V)
Ipp-Peak Pulse Current-%of Ipp
120
40
-20
-20
60
T-Time(us)
60
80
100
Time (nS)
8 X 20us Pulse Waveform
IEC61000−4−2 Pulse Waveform
% of Rated Power
120
100
80
60
40
50
75
100
125
150
Ambient Temperature_Ta(℃)
Power Derating Curve
3/4
www.leiditech.com
ULC0542CDN
DFN1006 PACKAGE OUTLINE & DIMENSIONS
h
h
b
E
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.40
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
e
D
L
A1
c
A
Bottom View
SYM
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Suggested Land Pattern
Y3
SYM
Y1
Y2
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ULC0542CDN”相匹配的价格&库存,您可以联系我们找货
