SDA1101CDN
SDA1101CDN
    LEIDITECH(雷卯电子)
    DFN1006
    雷卯 DFN1006 300W 24V
SDA1101CDN 数据手册
SDA1101CDN 1-Line Bi-directional TVS Diode Features ● Ultra small package: 1.0x0.6x0.5mm ● Protects one data or power line ● Ultra low leakage: nA level ● Working voltage: 24V ● Low clamping voltage ● 2-Pin leadless package ● Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±25kV – IEC61000-4-4 (EFT) 40A (5/50ns) ● RoHS Compliant Dimensions DFN1006 – IEC61000-4-5 (Lightning) 6A (8/20 μs) Pin Configuration Applications ● Cellular Handsets and Accessories ● Personal Digital Assistants ● Notebooks and Handhelds ● Portable Instrumentation ● Digital Cameras ● Peripherals ● Audio Players 1 2 Mechanical Characteristics ● Package: DFN1006 (1.0×0.6×0.5mm) ● Lead Finish: NiPdAu ● Case Material: “Green” Molding Compound. ● UL Flammability Classification Rating 94V-0 ● Moisture Sensitivity: Level 3 per J-STD-020 ● Terminal Connections: See Diagram Below ● Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 300 W ±30 VESD Kv ±25 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2021 1/4 www.leiditech.com SDA1101CDN Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A A4 24 27 1 34 SDA1101CDN Rev : 01.06.2021 2/4 (Max) 46 (@A) IR μA (Max) C (Pf) (Typ.) 6 0.2 20 www.leiditech.com SDA1101CDN Typical Performance Characteristics (TA=25°C unless otherwise Specified) 10 20 Peak Power_Ppp(W) Junction CapacitanceCj(pF) 25 15 10 5 1 0.1 0.01 0 0 5 10 15 20 Reverse Voltage_VR(V) 0.1 25 1000 Peak Pulse Power vs. Pulse Time 70 120 60 100 % of Rated Power Clamping Voltage_Vc (V) Junction Capacitance vs. Reverse Voltage 1 10 100 Pulse Duration_tp(uS) 50 40 30 20 80 60 40 20 10 0 0 0 1 2 3 4 5 Peak Pulse Current_Ipp (A) 6 0 Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 kV Contact per IEC61000−4−2 8 X 20uS Pulse Waveform Rev : 01.06.2021 3/4 www.leiditech.com SDA1101CDN DFN1006 Package Outline Drawing A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2021 4/4 www.leiditech.com
SDA1101CDN 价格&库存
很抱歉,暂时无法提供与“SDA1101CDN”相匹配的价格&库存,您可以联系我们找货
