ESDA1082CP
BIDIRECTIONAL TVS DIODE
Features
Protects one data line
Ultra low leakage: nA level
Operating voltage: 3.3V
Ultra low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (Lightning) 8A (8/20μs)
RoHS Compliant
Dimensions DFN1006
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, LCD Displays
Pin Configuration
Mechanical Characteristics
Package: DFN1006
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
80
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev 2.0 : 01.06.2021
1/4
www.leiditech.com
ESDA1082CP
Electrical Characteristics(TA=25°C unless otherwise specified)
Part Number
ESDA1082CP
Device
Marking
B
VRWM
(V)
VBR
(V)
IT
(mA)
3.3
3.5
1
VC
@1A
(Typ.)
6.5
2/4
Vc
(Max)
10
(@A)
8
IR
μA
(Max)
C
(Pf)
(Typ.)
0.5
12
www.leiditech.com
ESDA1082CP
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
CJ-Junction Capacitance (pF)
16
14
12
10
8
6
4
2
2
3
4
5
VR—Reverse Voltage(V)
Clamping Voltage vs. Peak Pulse Current
Voltage (V)
Junction Capacitance vs. Reverse Voltage
-20
60
80
100
Time (nS)
IEC61000−4−2 Pulse Waveform
120
120
100
100
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
Peak Pulse Power vs. Pulse Time
80
60
40
50
75
100
125
150
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
80
3/4
www.leiditech.com
ESDA1082CP
DFN1006 (0402)Package Outline Drawing
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.08
0.037
0.039
0.041
SYM
e
D
h
h
b
E
L
A
Bottom View
A1
c
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.68
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Suggested Land Pattern
Y3
SYM
Y1
Y2
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESDA1082CP”相匹配的价格&库存,您可以联系我们找货
