ESD01811CDN
ESD01811CDN
    LEIDITECH(雷卯电子)
    DFN1006
    雷卯 DFN1006 100W 1.8V
ESD01811CDN 数据手册
ESD01811CDN BIDIRECTIONAL TVS DIODE Features  Protects one data line  Ultra low leakage: nA level   Operating voltage: 1.8V Ultra low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 12A (8/20μs) RoHS Compliant  Dimensions DFN1006 Applications   Pin Configuration Cellular Handsets and Accessories Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation   Digital Cameras Peripherals  Audio Players  Keypads, Side Keys, LCD Displays Mechanical Characteristics  Package: DFN1006   Case Material: “Green” Molding Compound. Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 100 W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESD01811CDN Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD01811CDN Rev : 01.06.2018 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 181 1.8 2.5 1 3.5 2/4 (Max) 8.5 (@A) 12 IR μA (Max) C (Pf) (Typ.) 0.2 30 www.leiditech.com ESD01811CDN Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2018 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD01811CDN DNF1006 PACKAGE OUTLINE & DIMENSIONS A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 L1 0.05REF h 0.07 0.12 0.002REF 0.17 0.003 0.005 0.007 Suggested Land Pattern ╋ Y3 SYM Y1 Y2 Z DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 ╋ X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD01811CDN 价格&库存
很抱歉,暂时无法提供与“ESD01811CDN”相匹配的价格&库存,您可以联系我们找货
