ESD0711C
ESD0711C
    LEIDITECH(雷卯电子)
    DFN1006
    雷卯 DFN1006 300W 7V
ESD0711C 数据手册
ESD0711C Bi -Directional TVS Diode Array Features ● ● ● ● ● Dimensions DFN1006-2 Ultra low leakage: nA level Operating voltage: 7V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 20A (8/20μs) RoHS Compliant Applications ● Cellular Handsets and Accessories ● Personal Digital Assistants ● ● Computer Interfaces Protection Control Signal Lines Protection ● Digital Cameras ● Peripherals ● ● Pin Configuration Audio Players Keypads, Side Keys, LCD Displays Mechanical Characteristics ● ● ● Package: DFN1006-2 (1.0×0.6×0.5mm) Lead Finish: NiPdAu Case Material: “Green” Molding Compound. ● UL Flammability Classification Rating 94V-0 ● Moisture Sensitivity: Level 3 per J-STD-020 ● ● Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 300 VESD ± 30 Unit W Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESD0711C Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD0711C Rev : 01.06.2018 Device Marking T7 VRWM (V) VBR (V) IT (mA) VC @1A 7 7.5 1 10 2/4 (Max) 15 (@A) 20 IR μA (Max) C (Pf) (Typ.) 0.5 60 www.leiditech.com ESD0711C Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Power Derating Curve Clamping Voltage vs. Peak Pulse Current Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2018 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD0711C DFN1006 -2 PACKAGE OUTLINE & DIMENSIONS e D h A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM h - b E - L c A Bottom View A1 e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Y1 Z Y2 ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD0711C 价格&库存
很抱歉,暂时无法提供与“ESD0711C”相匹配的价格&库存,您可以联系我们找货
