ESDA07CP
ESDA07CP
    LEIDITECH(雷卯电子)
    DFN1006
    ESD 7V截止
ESDA07CP 数据手册
ESDA07CP 1-Line Bi -directional TVS Diode Features ● ● ● ● ● ● ● ● ● ● Small Body Outline Dimensions Low Body Height Dimensions DFN1006-2 Peak Power up to 80 Watts @ 8 x 20 μ s Pulse Low Leakage Response Time is Typically < 1 ns ESD Rating of Class 3 (> 16 kV) per Human Body Model IEC61000−4−2 Level 4 ESD Protection IEC61000−4−4 Level 4 EFT Protection We declare that the material of product compliance with RoHS req uirements. Pin Configuration Applications ● Cellular Handsets and Accessories ● Personal Digital Assistants ● Notebooks and Handhelds ● Portable Instrumentation ● Digital Cameras ● Peripherals ● Audio Players ● Keypads, Side Keys, LCD Displays Mechanical Characteristics ● Package: DFN1006-2 (1.0×0.6×0.5mm) ● Lead Finish: NiPdAu ● Case Material: “Green” Molding Compound. ● UL Flammability Classification Rating 94V-0 ● Moisture Sensitivity: Level 3 per J-STD-020 ● Terminal Connections: See Diagram Below ● Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 80 Unit W ±20 VESD Kv ±15 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/4 www.leiditech.com ESDA07CP Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) R2 7 ESDA07CP Rev : 01.06.2015 VBR (V) 7.2 IT (mA) VC @1A 1 16 2/4 (Max) 13 (@A) 3 IR μA (Max) C (Pf) (Typ.) 1 16 www.leiditech.com ESDA07CP Typical Performance Characteristics (TA=25°C unless otherwise Specified) Fig1. Pulse Waveform Fig3.Power Derating Rev : 01.06.2015 3/4 www.leiditech.com ESDA07CP DFN1006-2 Package Outline Drawing A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 4/4 www.leiditech.com
ESDA07CP 价格&库存
很抱歉,暂时无法提供与“ESDA07CP”相匹配的价格&库存,您可以联系我们找货
ESDA07CP
  • 1+0.15440
库存:20
ESDA07CP
    • 20+0.31670
    • 1000+0.31353
    • 4000+0.30726
    • 10000+0.29804
    库存:10000
