SDA0711P1
1-Line Bi -directional TVS Diode
Features
Ultra small package: 1.0x0.6x0.5mm
Protects one data or power line
Ultra low leakage: nA level
Operating voltage: 7V
Low clamping voltage
2-pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 7A (8/20µs)
RoHS Compliant
Dimensions DFN1006-2
Pin Configuration
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, LCD Displays
Mechanical Characteristics
Package: DFN1006-2 (1.0×0.6×0.5mm)
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
Unit
105
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2015
1/4
www.leiditech.com
SDA0711P1
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
B2
7
SDA0711P1
Rev : 01.06.2015
VBR
(V)
7.5
IT
(mA)
VC
@1A
1
9
2/4
(Max)
15
(@A)
7
IR
μA
(Max)
C
(Pf)
(Typ.)
1
10
www.leiditech.com
SDA0711P1
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
9
8
Peak Power_Ppp(W)
Junction Capacitance_Cj(pF)
10
7
6
5
4
3
2
1
0.1
1
2
3
4
Reverse Voltage_VR(V)
0.01
5
0.1
1
10
100
Pulse Duration_tp(uS)
Peak Pulse Power vs. Pulse Time
15
120
12
100
% of Rated Power
Clamping Voltage_Vc (V)
Junction Capacitance vs. Reverse Voltage
9
6
3
80
60
40
2
3
4
5
6
7
Peak Pulse Current_Ipp (A)
8
Clamping Voltage vs. Peak Pulse Current (tp = 8/20us)
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
100
% of Peak Pulse Current
90
Peak Pulse Current (Ipp)
80
70
Ipp/2
60
50
40
30
Rev : 01.06.2015
60
Time_t(uS)
8 X 20uS Pulse Waveform
80
ESD Clamping Voltage
8 kV Contact per IEC61000−4−2
3/4
www.leiditech.com
SDA0711P1
DFN1006-2 Package Outline Drawing
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
4/4
www.leiditech.com
很抱歉,暂时无法提供与“SDA0711P1”相匹配的价格&库存,您可以联系我们找货
