ESD6V8W5
ESD6V8W5
    LEIDITECH(雷卯电子)
    SOT-353-5(SC-70-5)
    雷卯 SOT-353 20W 5V
ESD6V8W5 数据手册
ESDA6V8W5 BI-DIRECTIONAL TVS DIODE ARRAY FOR ESD AND LATCH-UP PROTECTION Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 1.6A (8/20μs) RoHS Compliant Dimensions SOT-353 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-353 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 20 Unit W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESDA6V8W5 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESDA6V8W5 Rev : 01.06.2018 Device Marking 6H VRWM (V) 5 VBR (V) 6.4 IT (mA) VC @1.6A 1 13 2/4 (Max) 13 (@A) 1.6 IR μA (Max) 1 C (Pf) (Typ.) 16.8 www.leiditech.com ESDA6V8W5 110 % OF RATED POWER OR IPP Ppk, PEAK SURGE POWER (W) 100 10 10 100 90 80 70 60 50 40 30 20 10 0 1 1 100 1000 50 75 100 Figure 2. Power Derating Curve 150 14 0.14 0.12 0.10 0.08 0.06 0.04 0.02 12 TA = 25°C 10 8 6 4 2 0 0 −60 −40 0 20 40 60 80 100 2 3 4 Figure 3. Reverse Leakage versus Temperature Figure 4. Capacitance 70 60 HALF VALUE IRSM/2 @ 20 s 50 5 6 1 PULSE WIDTH (tP) IS DEFINED AS THAT POINT WHERE THE PEAK CURRENT DECAY = 8 s 40 tP 20 1 BIAS VOLTAGE (V) 80 30 0 T, TEMPERATURE (°C) PEAK VALUE IRSM @ 8 s tr 90 −20 IF, FORWARD CURRENT (A) 100 0.1 0.01 10 0 125 Figure 1. Pulse Width TYPICAL CAPACITANCE (pF) 1 MHz FREQUENCY IR, REVERSE LEAKAGE (A) 25 TA, AMBIENT TEMPERATURE (°C) 0.16 % OF PEAK PULSE CURRENT 0 t, TIME (s) TA = 25°C 0.001 0 Rev : 01.06.2018 20 40 60 0.6 80 0.8 1.0 1.2 1.4 t, TIME (s) VF, FORWARD VOLTAGE (V) Figure 5. 8 × 20 s Pulse Waveform Figure 6. Forward Voltage 3/4 1.6 1.8 www.leiditech.com ESDA6V8W5 SOT-353 Package Outline & Dimensions NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. 419A−01 OBSOLETE. NEW STANDARD 419A−02. 4. DIMENSIONS A AND B DO NOT INCLUDE MOLD FLASH, PROTRUSIONS, OR GATE BURRS. A G 5 4 DIM A B C D G H J K N S −B− S 1 2 3 D 5 PL 0.2 (0.008) B M M N INCHES MIN MAX 0.071 0.087 0.045 0.053 0.031 0.043 0.004 0.012 0.026 BSC −−− 0.004 0.004 0.010 0.004 0.012 0.008 REF 0.079 0.087 MILLIMETERS MIN MAX 1.80 2.20 1.15 1.35 0.80 1.10 0.10 0.30 0.65 BSC −−− 0.10 0.10 0.25 0.10 0.30 0.20 REF 2.00 2.20 J C K H SOLDERING FOOTPRINT* 0.50 0.0197 0.65 0.025 0.65 0.025 0.40 0.0157 1.9 0.0748 SCALE 20:1 mm  inches Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD6V8W5 价格&库存
很抱歉,暂时无法提供与“ESD6V8W5”相匹配的价格&库存,您可以联系我们找货
