LC03CILVC
LC03CILVC
    LEIDITECH(雷卯电子)
    SOD-323
    雷卯 SOD-323 400W 3.3V
LC03CILVC 数据手册
LC03CILVC LOW CLAMPING / LOW CAPACITANCE BIDIRECTIONAL TVS DIODE Features ● 400 Watts Peak Pulse Power per Line (tp=8/20μs) ● Protects One Bidirectional I/O Line ● Low Clamping Voltage ● RoHS Compliant ● IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact) ● IEC61000-4-4 (EFT) 40A (5/50ηs) ● IEC61000-4-5 (LIGHTNING) 25A (8/20μs) Dimensions SOD-323 Applications ● Monitors and Flat Panel Displays ● WAN/LAN Equipment ● Test & Measurement Equipment ● Instrumentation ● Analog Inputs Protection ● Base Stations ● 10/100/1000M Ports Pin Configuration Mechanical Characteristics ● SOD-323 Package ● Molding Compound Flammability Rating : UL 94V-O ● Weight 5 Millgrams (Approximate) ● Reel Size : 7 inch ● Lead Finish : Lead Free ● Device Marking:71W Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 400 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.07.2021 1/6 www.leiditech.com LC03CILVC Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Symbol Test Condition Min Typ VRWM Max Unit 3.3 V Trigger Voltage Vt1 Holding Voltage Vh IT = 1mA 3.5 4.2 V Holding Voltage Vh IT = 10mA 3.5 4.2 V Reverse Leakage Current IR VRWM = 3.3V 0.1 µA Clamping Voltage VC IPP = 1A (8 x 20 μs pulse) 6 V Clamping Voltage VC IPP = 25A (8 x 20 μ s pulse) 16 V Junction Capacitance CJ VR = 0V, f = 1MHz Rev : 01.07.2021 3.8 2/6 V 1 pF www.leiditech.com LC03CILVC TYPIC CHARACTERISTICS Figure 1. 8 x 20μs Waveform Figure 2. Power Derating Curve Figure 3. Difinition of Electrical Characteristics Rev : 01.07.2021 3/6 www.leiditech.com LC03CILVC TYPIC CHARACTERISTICS Figure 4. Clamping Voltage vs. Peak Pulse Current (tp=8/20μs) Figure 5. Typic Breakdown Voltage vs. Temperature Rev : 01.07.2021 4/6 www.leiditech.com LC03CILVC TYPIC CHARACTERISTICS Figure 6. Typic Reverse Leakage vs. Temperature Figure 7. Typic Capacitance vs. Reverse Voltage Rev : 01.07.2021 5/6 www.leiditech.com LC03CILVC SOD-323 Package Outline & Dimensions Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.07.2021 6/6 www.leiditech.com
LC03CILVC 价格&库存
很抱歉,暂时无法提供与“LC03CILVC”相匹配的价格&库存,您可以联系我们找货
