LC1154CI
LC1154CI
    LEIDITECH(雷卯电子)
    SOD-323
    雷卯 SOD-323 350W 5V
LC1154CI 数据手册
LC1154CI 1-Line Low Capacitance Bi-directional TVS Diode Features ● ● ● ● ● ● ● ● 450W peak pulse power (8/20μs) Ultra low capacitance: 0.6pF typical Ultra low leakage: nA level Low operating voltage: 5V Low clamping voltage Protects one power line or data line Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 80A (5/50ns) – IEC61000-4-5 (Lightning) 18A (8/20 μs) RoHS Compliant Dimensions SOD-323 Pin Configuration Applications ● ● ● ● ● ● ● USB Ports SIM Ports Smart Phones Wireless Systems Set-top box and digital TV Digital video interface (DVI) Ethernet 10/100/1000 Base T Mechanical Characteristics ● ● ● ● ● ● ● Package: SOD-323 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 350 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev 2.0 : 01.07.2021 1/4 www.leiditech.com LC1154CI Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number LC1154CI Device Marking VRWM (V) VBR (V) IT (mA) VC @1A AC 5 6 1 10 Rev 2.0 : 01.07.2021 2/4 (Max) 20 (@A) IR μA (Max) C (Pf) (Typ.) 18 0.2 0.6 www.leiditech.com LC1154CI Typical Performance Characteristics (TA=25°C unless otherwise Specified) 30 Vc-Clamping Voltage(V) CJ-Junction Capacitance (pF) 2 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 25 20 15 10 5 0.2 0 0 0 1 2 3 4 0 5 VR—Reverse Voltage(V) 2 4 6 8 10 12 14 16 18 20 Ipp-Peak Pulse Current(A) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage Voltage (V) Peak Power_Ppp(kW) 10 1 -20 0.1 0.1 1.0 10.0 Pulse Duration_tp(uS) 100 100 Ipp-Peak Pulse Current-%of Ipp % of Rated Power 120 80 60 40 20 0 50 75 100 125 150 60 80 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) 8 X 20us Pulse Waveform Power Derating Curve Rev 2.0 : 01.07.2021 40 IEC61000−4−2 Pulse Waveform 120 25 20 Time (nS) Peak Pulse Power vs. Pulse Time 0 0 100.0 3/4 www.leiditech.com LC1154CI SOD-323 Package Outline & Dimensions DIMENSIONS SYM MILLIMETERS INCHES MIN MAX MIN MAX A 1.50 1.80 0.060 0.071 B 1.20 1.40 0.045 0.054 C 2.30 2.80 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 F 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev 2.0 : 01.07.2021 4/4 www.leiditech.com
LC1154CI 价格&库存
很抱歉,暂时无法提供与“LC1154CI”相匹配的价格&库存,您可以联系我们找货
