SD14W
SD14W
    LEIDITECH(雷卯电子)
    SOD-323
    雷卯 SOD-323 450W 14V
SD14W 数据手册
SD14W Standard Capacitance TVS Diode Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage:14V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV Dimensions SOD-323 – IEC61000-4-5 (Lightning) 18.7A (8/20 μs) RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOD-323 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 450 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/3 www.leiditech.com SD14W Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) 14A 14 SD14W VBR (V) IT (mA) VC @1A 1 18.2 15.2 (Max) (@A) 24.4 18.7 IR μA (Max) C (Pf) (Typ.) 1 125 Characteristic Curves FIGURE 1 PEAK PULSE POWER VS PULSE TIME IPP - Peak Pulse Current - % of IPP 120 1,000 100 PPP - Peak Pulse Current - Watts 10,000 FIGURE 2 PULSE WAVE FORM tf 100 TEST WAVEFORM PARAMETERS tf = 8µs td = 20µs Peak Value IPP 80 e-t 60 40 td = IPP/2 20 0 10 0.01 0 1 10 100 1,000 10,000 5 10 15 t - Time - µs 20 25 30 td - Pulse Duration - µs FIGURE 3 POWER DERATING CURVE 100 Peak Pulse Power 8/20µs % Of Rated Power 80 60 40 20 0 0 Rev : 01.06.2015 25 50 75 100 125 TL - Lead Temperature - °C 150 2/3 www.leiditech.com SD14W SOD-323 Package Outline & Dimensions Millimeters Inches Symbol Min. Nom. Max. Min. Nom. Max. A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 Soldering Footprint 0.15 REF 0.006 REF b 0.25 0.32 0.40 0.010 0.012 0.016 C 0.089 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.062 0.066 0.070 E 1.15 1.25 1.35 0.045 0.049 0.053 L 0.08 HE 2.30 0.098 0.105 0.003 2.50 2.70 0.090 Symbol Millimeters Inches F 1.60 0.063 G 2.85 0.112 J 0.83 0.033 K 0.63 0.025 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 3/3 www.leiditech.com
SD14W 价格&库存
很抱歉,暂时无法提供与“SD14W”相匹配的价格&库存,您可以联系我们找货
