ULC15DT3
ULC15DT3
    LEIDITECH(雷卯电子)
    SOT-23
    雷卯 SOT-23 15W 210V
ULC15DT3 数据手册
ULC15DT3 Ultra Low Capacitance TVS Diode Array Features ● 210 Watts Peak Pulse Power per Line (tp=8/20μs) ● Protects Two High Speed I/O Lines Low Clamping Voltage RoHS Compliant IEC Compatibility ● ● ● Dimensions SOT-23 IEC61000-4-2 (ESD) ±25kV (air), ±20kV (contact) IEC61000-4-4 (EFT) 40A (5/50ηs) IEC61000-4-5 (LIGHTING) 6A (8/20μs) Applications ● Cellular Handsets & Accessories ● Keypads, Side Keys, Audio Ports Portable Instrumentation' Notebooks, Desktops, and Servers Digital Lines Tablet PC ● ● ● ● Pin Configuration Mechanical Characteristics ● ● ● ● ● ● ● Package:SOT-23 Molding Compound Flammability Rating : UL 94V-O Weight 8 Millgrams (Approximate) Reel Size : 7 inch Lead Finish : Lead Free Quantity Per Reel:10,000pcs Device Marking:N15 Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 210 W ±25 VESD KV ±20 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -40 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.07.2021 1/6 www.leiditech.com ULC15DT3 Electrical Characteristics(TA=25°C unless otherwise specified) Symbol Parameter VRWM Reverse Working Peak Voltage VBR Reverse Breakdown Voltage Conditions IT = 1mA Min Typ Max Unit 15 V V 16.7 VRWM = 15V 1 µA Clamping Voltage IPP = 1 A (8/20µs) 22 V VC Clamping Voltage IPP = 6 A (8/20µs) 35 V CJ Capacitance VR = 0V, f = 1MHz IR Reverse Leakage Current VC Rev : 01.07.2021 2/6 0.6 pF www.leiditech.com ULC15DT3 Characteristic Curves Figure 1. 8 x 20μs Waveform Figure 2. Power Derating Curve Figure 3. Clamping Voltage vs. Peak Pulse Current (tp=8/20μs) Rev : 01.07.2021 3/6 www.leiditech.com ULC15DT3 Characteristic Curves Figure 4. Typic Capacitance vs. Reverse Voltage Figure 5. Typic Capacitance vs. Reverse Voltage Rev : 01.07.2021 4/6 www.leiditech.com ULC15DT3 Characteristic Curves Figure 6. Typic Capacitance vs. Reverse Voltage Typic Application Schematic Rev : 01.07.2021 5/6 www.leiditech.com ULC15DT3 SOT-23 Package Outline Drawing Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.07.2021 6/6 www.leiditech.com
ULC15DT3 价格&库存
很抱歉,暂时无法提供与“ULC15DT3”相匹配的价格&库存,您可以联系我们找货
