Technical Data 10349
Effective August 2018
Supersedes October 2017
HCMA1104
Automotive grade
High current power inductors
Applications
Product features
Body electronics
Central body control module
Vehicle access control system
Headlamps, tai lamps and interior lighting
Heating ventilation and air conditioning controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system
Car black box system
Infotainment and cluster electronics
AEC-Q200 qualified
Audio subsystem: head unit and trunk amp
High current carrying capacity
Digital instrument cluster
Magnetically shielded, low EMI
In-vehicle infotainment (IVI) and navigation
Frequency range up to 5 MHz
Inductance range from 0.2 μH to 22 μH
Airbag control unit
Current range from 5 A to 45 A
Electronic stability control system (ESC)
11.5 mm x 10.3 mm footprint surface mount
package in a 4.0 mm height
Electric parking brake Voltage Regulator
Module (VRM)
Iron powder core material
Chassis and safety electronics
Environmental data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCMA1104
Automotive grade high current power inductors
Product Specifications
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4,5
(A)
DCR (mΩ)
typical @
+20 °C
DCR (mΩ)
maximum @
+20 °C
K-factor6
HCMA1104-R20-R
0.20
0.13
32
45
0.63
0.72
411
HCMA1104-R36-R
0.36
0.23
30
42
1.04
1.20
269
HCMA1104-R45-R
0.45
0.29
29
36
1.07
1.23
219
HCMA1104-R56-R
0.56
0.36
25
32
1.56
1.80
230
HCMA1104-R90-R
0.90
0.58
22
28
2.17
2.50
236
HCMA1104-1R0-R
1.0
0.56
18
28
3.0
3.3
378
HCMA1104-1R5-R
1.5
0.84
16
32
3.8
4.2
310
HCMA1104-2R2-R
2.2
1.23
12
18
6.0
7.0
253
HCMA1104-3R3-R
3.3
1.85
10
16
10.8
11.8
220
HCMA1104-4R7-R
4.7
2.63
8.5
15
17
HCMA1104-100-R
10
5.60
7.5
8.5
27
30
116
HCMA1104-220-R
22
12.3
5.0
5.5
60
66
92
Part Number
7
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, @ +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, @ Isat, @ +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C- HCM1104-R20-R to HCM1104-R90-R
5. Isat: Peak current for approximately 30% rolloff @ +25 °C HCM1104-1R0-R to HCM1104-220-R
6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L:
(Inductance in μH), ΔI (Peak to peak ripple current in Amps).
7. Part Number Definition: HCM1104-xxx-R
HCM1104 = Product code and size
xxx= inductance value in μH, R= decimal point ,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Recommended pad layout
Schematic
AXXX
wlyy R
Part marking: A=automotive grade, xxx=inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros.
wlyy=date code, R=revision level
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Color: Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCMA1104
Packaging information (mm)
AXXX
wlyy R
Supplied in tape and reel packaging, 850parts per 13” diameter reel
50.0
50.0
40.0
40.0
Temperature Rise (° C)
Temperature rise vs. total loss
30.0
HCMA1104-R20-R
HCMA1104-R36-R
HCMA1104-R45-R
HCMA1104-R56-R
HCMA1104-R90-R
20.0
10.0
HCMA1104-1R0-R
30.0
HCMA1104-1R5-R
20.0
HCMA1104-3R3-R/ HCMA11044R7-R/HCMA1104-220-R
10.0
HCMA1104-2R2-R/ HCMA1104100-R
0.0
0.0
0.0
0.5
1.0
Total Loss (W)
1.5
2.0
0.0
0.5
1.0
1.5
2.0
Total Loss (W)
3
HCMA1104
Core loss vs. Bp-p
HCMA1104-R20-R to HCMA1104-R90-R
10,000
1 MHz
500 kHz
300 kHz
200KHz
1000
Core Loss (mW)
100 kHz
50 kH z
25 kH z
100
10
1
0.1
100
1 000
10, 000
B p-p (Gauss)
HCMA1104-1R0-R to HCMA1104-220-R
10,000
1MHz
500 kHz
300 kHz
200 kHz
1000
Core Loss (mW)
100 kHz
50 kH z
25 kH z
100
10
1
0.1
100
1 000
B p-p (Gauss)
4
10, 000
HCMA1104
Inductance characteristics
HCMA1104-R36-R
HCMA1104-R20-R
100%
100%
90%
80%
80%
% of OC L
% of OC L
90%
70%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
80
90
1 00
40
50
I DC (A)
HCMA1104-R45-R
100%
60
70
80
90
1 00
I DC (A )
HCMA1104-R56-R
100%
90%
80%
80%
% of OC L
% of OC L
90%
70%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
10
I DC (A )
30
40
I DC (A )
50
60
70
HCMA1104-1R0-R
HCMA1104-R90-R
100 %
100 %
90%
90%
80%
% of OCL
% of OC L
80%
70%
60%
70%
60%
50%
50%
40%
I DC (A )
40
50
60
40%
10
15
Idc (A)
25
30
35
40
5
HCMA1104
HCMA1104-1R5-R
9 0%
90%
8 0%
80%
7 0%
70%
6 0%
60%
5 0%
50%
4 0%
HCMA1104-2R2-R
100%
% of OCL
% of OCL
100%
40%
10
15
Idc (A)
30
2
4
6
8
10 12 14 16 18 20 22 24 26 28
Idc (A)
HCMA1104-3R3-R
100%
HCMA1104-4R7-R
100%
90%
9 0%
%of OCL
% of OCL
80%
70%
60%
8 0%
7 0%
6 0%
50%
5 0%
40%
6
4
8
10
12
14
16
18
4 0%
Idc (A)
HCMA1104-100-R
100%
2
4
8
6
Idc (A)
10
12
14
16
18
HCMA1104-220-R
110%
100%
9 0%
90%
8 0%
%of OCL
%of OCL
7 0%
80%
70%
6 0%
60%
5 0%
4 0%
6
50%
4
6
8
Idc (A)
10
12
14
16
40%
4
Idc (A)
6
8
10
HCMA1104
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCMA1104-2R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 850+13.19367850+1.70630
- 国内价格 香港价格
- 850+7.89393850+1.02090
