HPL1005-1N6
HPL1005-1N6
    SUSUMU
    固定电感器 0402 1.6nH ±0.2nH 1.07A 120mΩ 7GHz 15@300MHz
HPL1005-1N6 数据手册
Components Precision thin film chip inductors ■ HPL series Features ● Highly precise chip inductors: inductance tolerance +/-0.1nH for 0603 size ● High Q and high current ● Small temperature coefficient of inductance: 0 to -200ppm/°C Applications ● Automotive electronics, high frequency circuitries such as wireless communication devices and base stations Specifications *All made to order. ▪ Dimensions unit:mm L Dimension (inch) HPL0603 (0201) HPL1005 (0402) L 0.60±0.05 1.00±0.10 W 0.30±0.05 0.50±0.10 A 0.07±0.05 0.15±0.15 B 0.12±0.05 0.25±0.20 T 0.28±0.05 0.40±0.10 W A T B ▪ Electrical characteristics Series name HPL0603 Inductance range 6.2 ~ 10 1.0 ~ 9.1 10 ~ 18 ±0.1nH(E02) ○ ー ○ ー ±0.2nH ○ ー ○ ー ±2% ー ○ ー ○ at 300MHz ー ー at 500MHz 10 10 ~ 8 at 800MHz 17 ~14 16 ~ 14 35 ~ 25 25 ~ 20 at 1.5GHz 25 ~18 20 ~ 18 50 ~ 30 30 ~ 25 Inductance value offered Self-resonance frequency(GHz) E-24 10 ~6.0 3.5 DC resistance(Ω)typ. 0.1 ~ 0.8 0.8 ~ 1.5 Rated current(A) 0.5 ~ 0.2 0.2 ~ 0.15 Operating temperature Packaging 10,000pcs 20 ~ 15 15 ~ 13 ー ー 7.0 ~ 4.0 HPL series Q value High frequency surface mount components Inductance tolerance HPL1005 1.0 ~ 5.6 3.5 0.01 ~ 0.4 0.5 ~ 0.8 1.8 ~ 0.34 0.3 ~ 0.24  −40 ~ 125 ℃ ○ ○ ・Mesured at 500MHz in case of HPL0603, at 300MHz in case of HPL1005. Part numbering system HPL 1005 - 1N0 (-E02) Designates tighter inductance tolerance Inductance value(1N0=1.0nH) Size Part code 24
HPL1005-1N6
物料型号:HPL系列,包括HPL0603(0603尺寸)和HPL1005(0402尺寸)。
器件简介:这些是高精度的芯片电感器,具有高Q值和高电流承载能力,以及小的温度系数。
引脚分配:文档中没有提供具体的引脚分配信息,但通常这类表面贴装元件不需要引脚分配
参数特性: - 尺寸:HPL0603的长宽分别为0.60±0.05mm和0.30±0.05mm,HPL1005的长宽分别为1.00±0.10mm和0.50±0.10mm。 - 电感范围:HPL0603为1.0~5.6nH,HPL1005为1.0~9.1nH。 - 电感公差:±0.1nH(E02)、±0.2nH、±2%。 - Q值:在不同频率下,HPL0603的Q值范围为20~10,HPL1005的Q值范围为15~13。 - 自谐振频率:HPL0603为10~6.0GHz,HPL1005为7.0~4.0GHz。 - DC电阻:HPL0603的典型值为0.1~0.8欧姆,HPL1005的典型值为0.8~1.5欧姆。 - 额定电流:HPL0603为0.5~0.2A,HPL1005为0.2~0.15A。 - 工作温度范围:-40~125°C。
功能详解:这些电感器适用于汽车电子、无线通信设备和基站等高频电路。
应用信息:适用于要求高精度和高Q值的高频应用。
封装信息:每包含10,000件。
HPL1005-1N6 价格&库存
很抱歉,暂时无法提供与“HPL1005-1N6”相匹配的价格&库存,您可以联系我们找货
