SRV05-4W1
SRV05-4W1
    LEIDITECH(雷卯电子)
    SOT26
    雷卯 SOT-26 300W 5V
SRV05-4W1 数据手册
SRV05-4W1 LOW CAPACITANCE TVS DIODE ARRAY Features ● ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 12A (8/20μs) RoHS Compliant Dimensions SOT-26 AEC -Q101 qualified. Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100/1000 Ethernet Mechanical Characteristics ● Package: SOT-26 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 300 W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/8 www.leiditech.com SRV05-4W1 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) SV05 5 6 1 SRV05 -4W1 Rev : 01.06.2018 VC @1A 15 2/8 (Max) 25 (@A) 12 IR μA (Max) 0.5 C (Pf) (Typ.) 1.5 www.leiditech.com SRV05-4W1 Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance_Cj (pF) 5 4 Line to GND 3 2 Line to Line 1 0 0 1 2 3 4 Reverse Voltage_VR (V) 5 Peak Pulse Power vs. Pulse Time 30 120 25 100 % of Rated Power Clamping Voltage_Vc (V) Junction Capacitance vs. Reverse Voltage 20 15 10 5 80 60 40 20 0 0 0 3 6 9 12 Peak Pulse Current_Ipp (A) 15 0 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve Clamping Voltage vs. Peak Pulse Current 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev : 01.06.2018 3/8 www.leiditech.com SRV05-4W1 Typical Application The SRV05-4W1 is designed to protect four data lines from transient over -voltages by clamping them to fixed reference. When the voltage on the protected line exceeds the reference voltage (plus diode VF) the steering diodes are for ward biased, conducting the transient current away from the sensitive circuitry. Data lines are connected at pins 1, 3, 4 and 6. The negative reference (REF1) is connected at pin 2. This pin should be connected directly to a ground plane on the board for best results. The path length is kept as short as possible to minimize parasitic inductance. The positive reference (REF2) is connected at pin 5. I/O 1 To Protected IC I/O 2 6 1 2 5 3 4 VCC I/O 3 I/O 4 To Protected IC SRV05-4W1 on Video Interface Application VCC 6 5 4 1 2 3 VCC 6 1 Rev : 01.06.2018 5 2 4 3 4/8 www.leiditech.com SRV05-4W1 SRV05-4W1 on USB Port Application Vbus D+ D- USB Port Vbus 6 5 4 1 2 3 GND USB Controller Vbus D+ D- USB Port GND SRV05-4W1 on SIM Port Application I/O Clock Reset SIM Vcc GND Rev : 01.06.2018 6 5 4 1 2 3 5/8 www.leiditech.com SRV05-4W1 SRV05-4W1 on Digital Visual Interface (DVI) Application PC Graphics Card Flat Panel Display 5 2 3 4 3 1 6 2 6 1 5 RX0RX0+ 4 TX0TX0+ 5 2 3 4 3 LCD 1 6 2 6 1 5 RX1RX1+ RX2RX2+ 4 TX1TX1+ TX2TX2+ VGA TCTC+ RCRC+ DM Transmitter TMDS Receiver SRV05-4W1 on Ethernet 10/100 (Differential mode) Application TX+ TX+ TX- TXRX+ RJ45 Connector Coupling Transformer RX+ RX- RX1 6 2 5 3 4 VCC GND Rev : 01.06.2018 6/8 www.leiditech.com SRV05-4W1 SRV05-4W1 on T1/E1 Interface Application R1 RTIP RRING VCC T1 R2 6 5 4 1 2 3 T1/E1 Tranceiver R3 TTIP TRING Rev : 01.06.2018 T2 R4 7/8 www.leiditech.com SRV05-4W1 SOT-26 Package Outline & Dimensions Inches Symbol Min. A θ Nom. Max. Min. Nom. Max. 0.035 - 0.057 0.90 - 1.45 A1 0.000 - 0.006 0.00 - 0.15 A2 0.035 0.045 0.051 0.90 1.15 1.30 b 0.010 - 0.020 0.25 - 0.50 - 0.009 0.08 - 0.22 c 0.003 D 0.110 0.114 0.122 2.80 2.90 3.10 E1 0.060 0.063 0.069 1.50 1.60 1.75 E 0.110 BSC 2.80 BSC e 0.037 BSC 0.95 BSC e1 0.075 BSC 1.90 BSC L 0.012 0.018 0.024 0.30 0.45 0.60 L1 θ Soldering Footprint Millimeters (0.024) 0° - (0.60) 10° 0° - 10° aaa 0.004 0.10 bbb 0.008 0.20 ccc 0.008 0.20 Symbol Inches Millimeters C (0.098) (2.50) G 0.055 1.40 P 0.037 0.95 X 0.024 0.60 Y 0.043 1.10 Z 0.141 3.60 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 8/8 www.leiditech.com
SRV05-4W1 价格&库存
很抱歉,暂时无法提供与“SRV05-4W1”相匹配的价格&库存,您可以联系我们找货
