SD1501P4-3
SD1501P4-3
    LEIDITECH(雷卯电子)
    DFN2020-3
SD1501P4-3 数据手册
SD1501P4-3 1-Line High Power TVS Diode Features ● 6500W peak pulse power (8/20uS) ● Low leakage: nA level ● Operating voltage: 15V ● Ultra low clamping voltage ● One power line protects ● Complies with following standards: Dimensions DFN2020-3 – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 180A (8/20uS) ● RoHS Compliant Pin Configuration Applications ● ● ● Power Management Industrial Application Power Supply Protection 3 1, 2 Mechanical Characteristics ● ● ● ● ● ● ● Package: DFN2020-3 Lead Finish: NiPdAu Case Material: “Green” Molding Compound UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 6500 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com SD1501P4-3 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) N15A 15 16.5 1 SD1501P4-3 Rev : 01.06.2018 VC @20A 21 2/4 (Max) 36 (@A) 180 IR μA (Max) C (Pf) (Typ.) 1 480 www.leiditech.com SD1501P4-3 Typical Performance Characteristics (T A=25°C unless otherwise Specified) Rev : 01.06.2018 3/4 www.leiditech.com SD1501P4-3 DFN2020-3 Package Outline Drawing Suggested Land Pattern Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
SD1501P4-3 价格&库存
很抱歉,暂时无法提供与“SD1501P4-3”相匹配的价格&库存,您可以联系我们找货
