SMDA24P2
SMDA24P2
    LEIDITECH(雷卯电子)
    DFN2020SP2
    雷卯 DFN2020-2 2800W 24V
SMDA24P2 数据手册
SMDA24P2 HIGH SURGE TVS DIODE FOR LATCH-UP PROTECTION Features ● 2800 Watts Peak Pulse Power per Line (tp=8/20µs) ● Protects One Unidirectional Line ● Low Clamping Voltage ● Working Voltages : 24V ● Low Leakage Current ● IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact) ● IEC61000-4-4 (EFT) 40A (5/50ηs) ● IEC61000-4-5 (LIGHTING) 58A (8/20μs) Dimensions DFN2020SP2 Applications ● Cellular Phones ● ADSL and VDSL ● Parallel & Serial Port Protection ● Personal Digital Assistant (PDA) ● Microcontroller Input Protection ● Charager Protection Pin Configuration Mechanical Characteristics ● DFN2020SP2 Package ● Molding Compound Flammability Rating : UL 94V-O ● Quantity Per Reel : 3,000pcs ● Reel Size : 7 inch ● Lead Finish : Lead Free Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 2800 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/5 www.leiditech.com SMDA24P2 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SMDA24P2 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A SMDA24SP2 24 26.7 1 29.5 (Max) 48.5 (@A) 58 IR μA (Max) C (Pf) (Typ.) 1 - TYPIC CHARACTERISTICS Figure 2. Power Derating Curve Figure 1. 8 x 20μs Waveform Figure 3. Clamping Voltage vs. Peak Pulse Current (tp=8/20us) Rev : 01.06.2015 2/5 www.leiditech.com SMDA24P2 TYPIC CHARACTERISTICS Figure 4. Typic Reverse Leakage vs. Temperature Figure 5. Typic Breakdown Voltage vs. Temperature Rev : 01.06.2015 3/5 www.leiditech.com SMDA24P2 Transmission Line Pulse (TLP) Transmission Line Pulse (TLP) is a measurement technique used in the Electrostatic Discharge (ESD) arena to characterize performance attributes of devices under ESD stresses. TLP is able to obtain current versus voltage (I−V) curves in which each data point is obtained with a 100 ns long pulse, with currents up to 40 A. TLP was first used in the ESD field to study human body model (HBM) in integrated circuits, but it is an equally valid tool in the field of system level ESD. The applicability of TLP to system level ESD is illustrated in Figure 1, which compares an 8 kV IEC 61000−4−2 current waveform with TLP current pulses of 8 and 16 A. The current levels and time duration for the pulses are similar and the initial rise time for the TLP pulse is comparable to the rise time of the IEC 61000−4−2’s initial current spike. This application note will give a basic introduction to TLP measurements and explain the datasheet parameters extracted from TLP for SDI Technology’s protection products. Comparison of a Current Waveform of IEC 61000−4−2 with TLP Pulses at 8 and 16 A. The IEC 61000−4−2 ESD waveforms is true to the Standard and is shown here as captured on an oscilloscope. The points A, B, and C show the points on the waveforms specified in IEC 61000−4−2. Figure 6. TLP Characteristic Rev : 01.06.2015 4/5 www.leiditech.com SMDA24P2 DFN2020SP2 PACKAGE OUTLINE & DIMENSIONS Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 5/5 www.leiditech.com
SMDA24P2 价格&库存
很抱歉,暂时无法提供与“SMDA24P2”相匹配的价格&库存,您可以联系我们找货
