SD0701P4-3
SD0701P4-3
    LEIDITECH(雷卯电子)
    DFN2020-3
    雷卯 DFN2020-3 4000W 7V
SD0701P4-3 数据手册
SD0701P4-3 1-Line High Power TVS Diode Features ● ● ● ● ● ● 4000W peak pulse power (8/20µs) Low leakage: nA level Low operating voltage: 7V Ultra low clamping voltage One power line protects Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 80A (5/50ns) Dimensions DFN2020-3 – IEC61000-4-5 (Lightning) 180A (8/20μs) ● Pin Configuration RoHS Compliant Applications ● ● ● Power Management Industrial Application Power Supply Protection 3 1, 2 Mechanical Characteristics ● ● ● ● ● ● ● Package: DFN2020-3 Lead Finish: NiPdAu Case Material: “Green” Molding Compound UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 4000 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com SD0701P4-3 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SD0701P4-3 Rev : 01.06.2014 Device Marking VRWM (V) 73P 7 VBR (V) 7.5 IT (mA) VC @20A 1 10 2/4 (Max) 22 (@A) 180 IR μA (Max) 1 C (Pf) (Typ.) 1500 www.leiditech.com SD0701P4-3 Typical Performance Characteristics (T A=25°C unless otherwise Specified) 10 Peak Pulse Power_Ppp (W) 1200 Capacitance_Cj (pF) 1000 800 600 400 200 0 0 2 4 6 8 1 0.1 0.01 0.1 Reverse Voltage_VR (V) 1 10 100 1000 Pulse Duration_tp (us) Peak Pulse Power vs. Pulse Time Junction Capacitance vs. Reverse Voltage 120 100 16 % of Rated Power Clamping Voltage_Vc (V) 18 14 12 10 8 6 4 80 60 40 20 2 0 0 40 80 120 160 200 0 0 Peak Pulse Current_Ipp (A) Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 X 20us Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev : 01.06.2014 3/4 www.leiditech.com SD0701P4-3 DFN2020-3 Package Outline Drawing Suggested Land Pattern Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
SD0701P4-3
物料型号:SD0701P4-3
器件简介: - 该器件是一款1线高功率TVS二极管,具有以下特点: - 符合IEC61000-4-4(EFT)标准,能承受80A(5/50ns)的浪涌电流 - 具有超低的钳位电压 - 低工作电压:7V - 峰值脉冲功率:4000W(8/20µs) - 符合IEC 61000-4-2(ESD)标准,空气放电:±30kV,接触放电:±30kV - 符合IEC61000-4-5(雷击)标准,180A(8/20μs) - 符合RoHS标准
引脚分配: - 引脚配置为1, 2, 3
参数特性: - 绝对最大额定值(环境温度Tamb=25°C,除非另有说明): - 峰值脉冲功率(8/20 s):4000W - ESD(空气放电):±30kV - 工作温度范围:-55至+125°C - 存储温度范围:-55至+150°C
功能详解: - 电气特性(环境温度TA=25°C,除非另有说明): - 工作电压(VRWM):73V - 反向击穿电压(VBR):7V - 漏电流(Ir):7.5mA - 20A时的钳位电压(Vc @20A):10V - 最大漏电流(IR):180uA - 典型电容(C):1500pF
应用信息: - 应用领域包括电源管理、工业应用和电源保护
封装信息: - 封装类型:DFN2020-3 - 引脚表面处理:NiPdAu - 外壳材料:绿色模塑化合物 - UL可燃性分类等级:94V-0 - 湿度敏感性等级:根据J-STD-020标准为3级
SD0701P4-3 价格&库存
很抱歉,暂时无法提供与“SD0701P4-3”相匹配的价格&库存,您可以联系我们找货
