SD1201P4-3
1-Line High Power TVS Diode
Features
4000W peak pulse power (8/20µs)
Low leakage: nA level
Low operating voltage: 12V
Ultra low clamping voltage
One power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 80A (5/50ns)
Dimensions DFN2020-3
– IEC61000-4-5 (Lightning) 130A (8/20μs)
Pin Configuration
RoHS Compliant
Applications
Power Management
Industrial Application
Power Supply Protection
3
1, 2
Mechanical Characteristics
Package: DFN2020-3
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
4000
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2014
1/4
www.leiditech.com
SD1201P4-3
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
SD1201P4-3
Rev : 01.06.2014
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
12P
12
14
1
VC
@20A
18
2/4
(Max)
30
(@A)
130
IR
μA
(Max)
1
C
(Pf)
(Typ.)
450
www.leiditech.com
SD1201P4-3
Typical Performance Characteristics (T A=25°C unless otherwise Specified)
10
Peak Pulse Power_Ppp (W)
1200
Capacitance_Cj (pF)
1000
800
600
400
200
4
6
8
1
0.1
0.01
0.1
Reverse Voltage_VR (V)
1
10
100
1000
Pulse Duration_tp (us)
Peak Pulse Power vs. Pulse Time
Junction Capacitance vs. Reverse Voltage
120
100
16
% of Rated Power
Clamping Voltage_Vc (V)
18
14
12
10
8
6
4
80
60
40
80
120
160
200
Peak Pulse Current_Ipp (A)
Clamping Voltage vs. Peak Pulse Current
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
100
% of Peak Pulse Current
90
80
70
60
50
40
30
Time_t(uS)
60
80
ESD Clamping Voltage
8 X 20us Pulse Waveform
8 kV Contact per IEC61000−4−2
Rev : 01.06.2014
3/4
www.leiditech.com
SD1201P4-3
DFN2020-3 Package Outline Drawing
Suggested Land Pattern
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
4/4
www.leiditech.com
很抱歉,暂时无法提供与“SD1201P4-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.67507
- 50+0.53365
- 150+0.46295
- 500+0.40991
- 3000+0.36743
- 6000+0.34623
