ESD4501P3
ESD4501P3
    LEIDITECH(雷卯电子)
    DFN2020-3
    雷卯 DFN2020-3 6000W 4.5V
ESD4501P3 数据手册
ESD4501P3 1-Line High Power TVS Diode Features ● 6000W peak pulse power (8/20 μs) ● Low leakage: nA level ● Low operating voltage: 4.5V ● Ultra low clamping voltage ● One power line protects ● Complies with following standards: Dimensions DFN2020-3 – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV Pin Configuration – IEC61000-4-5 (Lightning) 250A (8/20μs) ● ● RoHS Compliant Lead Finish: NiPdAu Applications ● ● ● ● Power Management Industrial Application Power Supply Protection Many other portable devices Mechanical Characteristics ● ● ● ● ● ● ● Package: DFN2020-3 Lead Finish: NiPdAu Case Material: “Green” Molding Compound UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 6000 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESD4501P3 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking ESD4501P3 Rev : 01.06.2018 93P VRWM (V) VBR (V) IT (mA) 4.5 4.8 1 VC @150A 14 2/4 (Max) 22 (@A) 300 IR μA (Max) C (Pf) (Typ.) 5 700 www.leiditech.com ESD4501P3 Typical Performance Characteristics (TA=25°C unless otherwise Specified) Vc-Clamping Voltage(V) CJ-Junction Capacitance (pF) 800 700 600 500 400 300 200 25 20 15 10 5 100 0 0 0 1 2 3 VR—Reverse Voltage(V) 4 0 5 50 100 150 200 250 300 Ipp-Peak Pulse Current(A) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage Ppp-peak pulse power(W) 1000 Voltage (V) 100 10 1 0.1 -20 0.1 1 10 100 0 20 1000 120 120 100 100 80 60 40 20 0 50 75 100 125 150 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) Power Derating Curve Rev : 01.06.2018 80 IEC61000−4−2 Pulse Waveform Ipp-Peak Pulse Current-%of Ipp % of Rated Power Peak Pulse Power vs. Pulse Time 25 60 Time (nS) Tp-Pulse time(us) 0 40 8 X 20us Pulse Waveform 3/4 www.leiditech.com ESD4501P3 DFN2020-3 Package Outline Drawing Suggested Land Pattern Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD4501P3 价格&库存
很抱歉,暂时无法提供与“ESD4501P3”相匹配的价格&库存,您可以联系我们找货
