SD4501P4-3
SD4501P4-3
    LEIDITECH(雷卯电子)
    DFN2020-3
SD4501P4-3 数据手册
SD4501P4-3 1-Line High Power TVS Diode Features ● ● ● ● ● ● 6000W peak pulse power (8/20) Low leakage: nA level Low operating voltage: 4.5V Ultra low clamping voltage One power line protects Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 80A (5/50ns) Dimensions DFN2020-3 – IEC61000-4-5 (Lightning) 200A (8/20μs) ● Pin Configuration RoHS Compliant Applications ● ● ● Power Management Industrial Application Power Supply Protection 3 1, 2 Mechanical Characteristics ● ● ● ● ● ● ● Package: DFN2020-3 Lead Finish: NiPdAu Case Material: “Green” Molding Compound UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 6000 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com SD4501P4-3 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SD4501P4-3 Rev : 01.06.2014 Device Marking 93P VRWM (V) VBR (V) IT (mA) 4.5 4.8 1 VC @50A 10 2/4 (Max) 30 (@A) 200 IR μA (Max) C (Pf) (Typ.) 6 650 www.leiditech.com SD4501P4-3 Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time 120 % of Rated Power 100 80 60 40 20 0 0 Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 X 20us Pulse Waveform Rev : 01.06.2014 3/4 www.leiditech.com SD4501P4-3 DFN2020-3 Package Outline Drawing Suggested Land Pattern Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
SD4501P4-3 价格&库存
很抱歉,暂时无法提供与“SD4501P4-3”相匹配的价格&库存,您可以联系我们找货
