ESD0888C
ESD0888C
    LEIDITECH(雷卯电子)
    DFN0603
    雷卯 DFN0603 40W 5V
ESD0888C 数据手册
ESD0888C 1-Line Ultra Small Bi-directional TVS Diode Features  Ultra small package: 0.6x0.3x0.3mm  low capacitance  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 5V  Low clamping voltage  2-Pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±22kV Dimensions DFN0603 0.6 0.3 - 0.3 – IEC61000-4-5 (Lightning) 3.5A (8/20μs)  RoHS Compliant Pin Configuration Applications  Cellular Handsets and Accessories  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, USB 2.0, LCD Displays Mechanical Characteristics  Package: DFN0603-2 (0.6x0.3x0.3mm)  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 40 Unit W ±25 Kv VESD ±22 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2021 1/4 www.leiditech.com ESD0888C Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD0888C Rev : 01.06.2021 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A A 5 6 1 8 2/4 (Max) 12 (@A) 3.5 IR μA (Max) 0.2 C (Pf) (Typ.) 5 www.leiditech.com ESD0888C Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve 200 Voltage (V) 150 TA = 25OC Corrected for 20dB attenuator 1M Ohm 100 50 0 -50 -20 0 20 Time (ns) 40 60 80 ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2021 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD0888C DFN0603 Package Outline Drawing DIMENSIONS e D h SYM h MIN NOM MAX A 0.230 0.330 A1 0.000 0.020 0.050 b 0.215 0.245 0.275 c 0.120 0.150 0.180 D 0.550 0.600 0.650 - b E - MILLIMETERS L A Bottom View A1 c e 0.355 BSC E 0.250 L 0.160 h 0.300 0.350 0.190 0.220 0.079 BSC Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.30 0.012 Y1 0.25 0.010 Y2 0.15 0.006 Y3 0.40 0.016 Z 0.65 0.026 Y1 Y2 Z ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2021 4/4 www.leiditech.com
ESD0888C 价格&库存
很抱歉,暂时无法提供与“ESD0888C”相匹配的价格&库存,您可以联系我们找货
