ULC0721C
ULC0721C
    LEIDITECH(雷卯电子)
    DFN0603
    雷卯 DFN0603 100W 7V
ULC0721C 数据手册
ULC0721C 1-Line Bi-directional TVS Diode Features  Ultra small package: 0.6x0.3x0.3mm  low capacitance  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 7V  Low clamping voltage  2-Pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV Dimensions DFN0603 0.6 0.3 - 0.3 – IEC61000-4-5 (Lightning) 4A (8/20 μs)  RoHS Compliant Pin Configuration Applications • • Cellular Handsets and Accessories Display Ports • MDDI Ports • USB Ports • • Digital Visual Interface (DVI) PCI Express and Serial SATA Ports Mechanical Characteristics  Package: DFN0603 ( 0.6x0.3x0.3mm)  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 100 W ±30 Kv VESD ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2019 1/4 www.leiditech.com ULC0721C Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ULC0721C Rev : 01.06.2019 Device Marking VRWM (V) VBR (V) IT (mA) LR 7 8.5 1 VC @1A 14 2/4 (Max) 25 (@A) 4 IR μA (Max) C (Pf) (Typ.) 0.2 0.3 www.leiditech.com ULC0721C Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve ESD Clamping Voltage 8 X 20μs Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev : 01.06.2019 3/4 www.leiditech.com ULC0721C DFN0603 Package Outline Drawing DIMENSIONS MILLIMETERS SYM MIN A 0.230 A1 0.000 0.020 0.050 b 0.215 0.245 0.275 c 0.120 0.150 0.180 D 0.550 0.600 0.650 e NOM MAX 0.330 0.355 BSC E 0.250 0.300 0.350 L 0.160 0.190 0.220 h 0.079 BSC Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.30 0.012 Y1 0.25 0.010 Y2 0.15 0.006 Y3 0.40 0.016 Z 0.65 0.026 Y1 Y2 Z ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2019 4/4 www.leiditech.com
ULC0721C
物料型号: - ULC07210和ULC0721C
器件简介: - 这些是单线双向TVS二极管,具有超小封装尺寸(0.6x0.3x0.3mm),低电容,保护数据线或电源线,超低漏电流(纳安级别),工作电压为7V,低钳位电压,2引脚无引线封装。
引脚分配: - 引脚连接图在文档中提供,但未在摘要中显示。
参数特性: - 符合IEC 61000-4-2(ESD)空气放电:±30kV,接触放电:±30kV;IEC61000-4-4A(8/20μs)5(闪电)标准。 - 符合RoHS标准。
功能详解: - 适用于手机和配件、显示端口、MDDI端口、USB端口、数字视觉接口(DVI)、PCI Express和串行SATA端口。
应用信息: - 包括机械特性、封装尺寸、湿度敏感度等级、终端连接和标记信息。
封装信息: - 封装类型为DFN0603(0.6x0.3x0.3mm),封装材料为“绿色”模塑化合物,湿度敏感度等级为J-STD-020的3级。
电气特性: - 包括工作温度范围(-55至+125°C)、存储温度范围(-55至+150°C)、最大脉冲功率(8/20秒)、ESD保护等级等。
典型性能特性: - 包括反向电压与结电容的关系、峰值脉冲电流与脉冲时间的关系、钳位电压与峰值脉冲电流的关系、功率降额曲线等。
封装轮廓图: - 提供了DFN0603封装的详细尺寸和建议的焊盘图案。
联系信息: - 上海雷迪泰克电子有限公司,提供了电子邮件、电话和传真联系方式。
ULC0721C 价格&库存
很抱歉,暂时无法提供与“ULC0721C”相匹配的价格&库存,您可以联系我们找货
