ESD0721C
ESD0721C
    LEIDITECH(雷卯电子)
    DFN0603
    雷卯 DFN0603 80W 7V
ESD0721C 数据手册
ESD0721C 1-Line Bi-directional TVS Diode Features  Ultra small package: 0.6x0.3x0.3mm  low capacitance  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 7V  Low clamping voltage  2-Pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV Dimensions DFN0603 0.6 0.3 - 0.3 – IEC61000-4-5 (Lightning) 5A (8/20 μs)  RoHS Compliant Pin Configuration Applications  Cellular Handsets and Accessories  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, LCD Displays Mechanical Characteristics  Package: DFN0603-2 (0.6x0.3x0.3mm)  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 80 Unit W ±30 Kv VESD ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2019 1/4 www.leiditech.com ESD0721C Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD0721C Rev : 01.06.2019 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 7A 7 7.5 1 9 2/4 (Max) 16 (@A) 5 IR μA (Max) C (Pf) (Typ.) 0.2 15 www.leiditech.com ESD0721C Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current (tp = 8/20μs) Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2019 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD0721C DFN0603 Package Outline Drawing DIMENSIONS e D h SYM h MIN NOM MAX A 0.230 0.330 A1 0.000 0.020 0.050 b 0.215 0.245 0.275 c 0.120 0.150 0.180 D 0.550 0.600 0.650 - b E - MILLIMETERS L A Bottom View A1 c e 0.355 BSC E 0.250 L 0.160 h 0.300 0.350 0.190 0.220 0.079 BSC Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.30 0.012 Y1 0.25 0.010 Y2 0.15 0.006 Y3 0.40 0.016 Z 0.65 0.026 Y1 Y2 Z ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2019 4/4 www.leiditech.com
ESD0721C 价格&库存
很抱歉,暂时无法提供与“ESD0721C”相匹配的价格&库存,您可以联系我们找货
