ESD0521CH
1-Line Ultra Small Bi-directional TVS Diode
Features
Ultra small package: 0.6x0.3x0.3mm
low capacitance
Protects one data or power line
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
2-Pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
Dimensions DFN0603
0.6
0.3
0.3
– IEC61000-4-5 (Lightning) 9 A (8/20 μs)
RoHS Compliant
Pin Configuration
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, USB 2.0, LCD Displays
Mechanical Characteristics
Package: DFN0603-2 (0.6x0.3x0.3mm)
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
90
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2019
1/4
www.leiditech.com
ESD0521CH
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
ESD0521CH
Rev : 01.06.2019
Device
Marking
VRWM
(V)
C
5
VBR
(V)
5.8
IT
(mA)
VC
@1A
1
7
2/4
(Max)
8.5
(@A)
IR
μA
(Max)
C
(Pf)
(Typ.)
9
0.2
15
www.leiditech.com
ESD0521CH
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
14
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
16
14
12
10
8
6
4
2
12
10
8
6
4
2
2
3
4
1
VR—Reverse Voltage(V)
2
3
4
5
6
7
8
9
10
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
10
Voltage (V)
Peak Power_Ppp(kW)
100
1
0.1
-20
0.01
0.1
1
10
120
120
100
100
80
60
40
75
100
125
150
100
80
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
Rev : 01.06.2019
80
IEC61000−4−2 Pulse Waveform
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
Peak Pulse Power vs. Pulse Time
25
60
Time (nS)
Pulse Duration_tp(uS)
3/4
www.leiditech.com
ESD0521CH
DFN0603 Package Outline Drawing
DIMENSIONS
e
D
h
SYM
h
MIN
NOM
MAX
A
0.230
0.330
A1
0.000
0.020
0.050
b
0.215
0.245
0.275
c
0.120
0.150
0.180
D
0.550
0.600
0.650
b
E
MILLIMETERS
L
A
Bottom View
A1
c
e
0.355 BSC
E
0.250
L
0.160
h
0.300
0.350
0.190
0.220
0.079 BSC
Suggested Land Pattern
SYM
Y3
MILLIMETERS
INCHES
X
0.30
0.012
Y1
0.25
0.010
Y2
0.15
0.006
Y3
0.40
0.016
Z
0.65
0.026
Y1
Y2
Z
DIMENSIONS
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2019
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESD0521CH”相匹配的价格&库存,您可以联系我们找货
