PESD11B8V0
PESD11B8V0
    LEIDITECH(雷卯电子)
    雷卯 201 100W 8V
PESD11B8V0 数据手册
PESD11B8V0 1-Line Bi-directional Low Capacitance TVS Diode Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 8V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±18kV Contact discharge: ±15kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 40A (5/50μs) RoHS Compliant Dimensions 0201 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: 0201 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:15,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Ppp VESD Value Unit 100 W ±18 Kv ±15 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev  01.06.2015 1/4 www.leiditech.com PESD11B8V0 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number PESD11B8V0 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A E 8 17 1 9.3 (Max) 23 (@A) IR μA (Max) C (Pf) (Typ.) 0.5 4 1 Characteristic Curves Power derating curve Ppk = ƒ (TA) Non-repetitive peak pulse power Ppk = ƒ (tp) 10 3 110 % W 10 2 10 1 P pk or I pp P pk 90 D= 0 D= .005 D= .01 D= .02 D= .05 D= .1 D= .2 D= .5 80 70 60 50 40 30 20 10 10 0 -8 -7 -6 -5 -4 -3 -2 10 10 10 10 10 10 10 s 10 0 tp Rev : 01.06.2015 0 0 25 50 75 100 °C 150 TA 2/4 www.leiditech.com PESD11B8V0 Characteristic Curves Reverse current IR = ƒ(VR) Diode capacitance CT = ƒ (VR) TA = Parameter f = 1MHz 10 1 7 pF nA TA = 85°C 5 IR CT 10 0 4 TA = 25°C 3 10 -1 2 1 10 -2 0 2 4 6 8 10 V 0 0 14 2 4 VR 6 8 10 12 V 15 VR Connector Application example 1 line, bi-directional Protected data line with signal levels -8V up to +14V (bi-directional) I/O ESD sensitive device 2 1 Rev : 01.06.2015 The protection diode should be placed very close to the location where the ESD or other transients can occur to keep loops and inductances as small as possible. Pin 1 should be connected directly to a ground plane on the board . 3/4 www.leiditech.com PESD11B8V0 Dimensions C A F D E B G D .007 (0.19) 0.012 (0.3) .011 (0.28) Unit: inch (mm) Inches Dimension MIN 0.023 0.011 0.009 0.005 0.009 0.009 0.0002 A B C D E F G Millimeters MAX 0.025 0.013 0.12 0.006 0.010 0.010 0.0006 MIN 0.595 0.295 0.245 0.145 0.245 0.245 0.005 MAX 0.645 0.345 0.301 0.155 0.255 0.255 0.015 Standard Packing Reel ø180 mm = 15.000 Pieces/Reel Reel ø330 mm = 50.000 Pieces/Reel (optional) 0.5 1.16 Cathode marking 8 4 0.76 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 4/4 www.leiditech.com
PESD11B8V0 价格&库存
很抱歉,暂时无法提供与“PESD11B8V0”相匹配的价格&库存,您可以联系我们找货
